9WS0912M402
9WS0912M402
    SANYODENKI
    FAN92X25MM12VDCIP54
9WS0912M402 数据手册
Splash Proof Fan IP54 92×92×25 mm San Ace 92WS 9WS type ■ General Specifications ・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 547. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Yellow Sensor ・ Mass ……………………………………………… 150 g ・ Ingress protection …………………………… IP54 ■ Specifications The models listed below have ribs and pulse sensors. Rated voltage Operating voltage range Rated current Rated input Model no. [V] 9WS0912H401 9WS0912F401 9WS0912M401 9WS0912L401 9WS0924H401 9WS0924F401 9WS0924M401 9WS0924L401 [V] 12 10.2 to 13.8 24 20.4 to 27.6 Rated speed Max. airflow Max. static pressure [A] [W] [min-1] [m³/min] [CFM] [Pa] 0.17 0.13 0.1 0.06 0.1 0.07 0.06 0.05 2.04 1.56 1.2 0.72 2.4 1.68 1.44 1.2 2850 2450 2100 1700 2850 2450 2100 1700 1.38 1.18 1.01 0.8 1.38 1.18 1.01 0.8 48.7 41.7 35.7 28.2 48.7 41.7 35.7 28.2 45.1 32.3 23.5 16.7 45.1 32.3 23.5 16.7 SPL [inchH²O] Operating temperature Expected life [dB (A)] [˚C] [h] 33 30 27 23 33 30 27 23 -20 to +70 40000/60˚C 0.181 0.13 0.094 0.067 0.181 0.13 0.094 0.067 The following sensor and control options are available for selection. Available for all models. Without sensor Differs according to the model. Refer to the table on p. 581. Lock sensor ■ Airflow - Static Pressure Characteristics 9WS0912H401 9WS0912F401 With pulse sensor Operating voltage range (inch H2O) (Pa) 0.15 0.10 0.05 0 50 13.8 V 40 12 V 30 10.2 V 20 10 0 0.5 0 296 (inch H2O) (Pa) 1.0 20 40 風量 Airflow 1.5 2.0 60 (m3/min) 80 (CFM) 0.15 50 0.14 13.8 V 40 12 V 30 0.10 10.2 V 20 0.05 0 0.12 Static静圧 pressure 0.20 0.20 With pulse sensor Operating voltage range (inch H2O) (Pa) 60 Static静圧 pressure Static静圧 pressure 0.25 9WS0912M401 With pulse sensor Operating voltage range 10 13.8 V 30 0.10 0.08 12 V 20 0.06 0.04 10.2 V 10 0.02 0 0.5 0 10 20 1.0 30 風量 Airflow 40 1.5 50 (m3/min) 60 (CFM) 0 0 0.5 0 10 20 1.0 30 風量 Airflow 40 1.5 (m3/min) 50 (CFM) ■ Airflow - Static Pressure Characteristics 9WS0924H401 Operating voltage range Operating voltage range 0.08 20 0.06 15 0.04 10 0.02 5 0 0 Static静圧 pressure Static静圧 pressure 13.8 V 12 V 10.2 V 10 9WS0924M401 20 30 風量 Airflow 40 30 20.4 V 20 10 0 0.5 1.0 20 1.5 40 風量 Airflow 2.0 60 (m3/min) 80 (CFM) 27.6 V 40 24 V 30 0.10 20.4 V 20 0.05 0 10 0 0.5 0 10 20 1.0 30 風量 Airflow 40 1.5 50 (m3/min) 60 (CFM) With pulse sensor Operating voltage range 0.10 25 0.08 20 0.06 15 0.04 10 0.02 5 0 0 27.6 V 27.6 V 30 Static静圧 pressure Static静圧 pressure 24 V 0.15 50 (inch H2O) (Pa) 0.10 24 V 20 0.06 20.4 V 10 0.02 0 40 9WS0924L401 With pulse sensor 0.14 0.04 0.05 27.6 V 0 (inch H2O) (Pa) 0.08 0.10 0.20 50 (CFM) Operating voltage range 0.12 0.15 0 0.2 0.4 0.6 0.8 1.0 1.2 (m3/min) 0 0.20 (inch H2O) (Pa) 60 Static静圧 pressure 0.25 25 With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 0.10 9WS0924F401 With pulse sensor DC With pulse sensor 0 0.5 0 10 20 1.0 30 風量 Airflow 40 1.5 (m3/min) 50 24 V 20.4 V 0.2 0.4 0.6 0.8 1.0 1.2 (m3/min) 0 (CFM) 10 20 30 風量 Airflow 40 (CFM) ■ Dimensions (unit: mm) Lead wire リード線 AWG24 UL 1007 82.5±0.3 92±0.5 4-ø4.3±0.3 Mounting 取付用穴hole +30 300 0 (10) 82.5±0.3 92±0.5 回転方向 Rotating direction (4) (4) 25±0.5 Airflow direction 風吹出方向 297 Splash Proof Fan 92 mm sq. 9WS0912L401 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 4-ø4.5 82.5±0.3 89 02 ø1 82.5±0.3 89 ■ Options Finger guards Model no.: 109-099E, 109-099H, 109-099C 298 page: p. 532 Resin finger guards Model no.: 109-1001G page: p. 539
9WS0912M402 价格&库存
很抱歉,暂时无法提供与“9WS0912M402”相匹配的价格&库存,您可以联系我们找货
