R150A1-051-D0760
R150A1-051-D0760
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 172.7X50.8MM 48VDC
R150A1-051-D0760 数据手册
NE W ! R150 (150 X Ø172 X 51L) NMBTC.COM / 818.341.3355 Characteristic Curves In H2O (Pa) 6 Static Pressure High Power Fans 5   4 1600 9,300rpm 1400 6,300rpm 1200 1000 3 2 1 800 600 400 200 0 0 100 200 200 General Specifications 300 400 400 500 600 600 [CFM] [m3/h] 800 Air Flow Outline Motor Protection: inch Units: (mm) Locked Rotor, Reverse Polarity ROTATION Insulation Resistance: 0.161 (8-F4.1 ) Dielectric Withstand Voltage: AC 700V 1 minute Allowable Ambient Temperature Range: 11.42 Min 290 6.80 (F172.7 ) -30°C ~ +70°C (Operating) -40°C ~ +80°C (Storage) 6.30 (F162 ± 0.2) 10M Ω min measured with 500V DC between all leads shorted together and case 0.32 8-8.2 DEPTH 0.3 0.161 (8-R4.1) NAME PLATE AIR Expected Life Failure Rate: 10% 40°C 70,000 Hours (L10) 55 .5˚ .5˚ 0.34 (4-8.8) 55 5.91 (150) Material 2.00 (50.8 ± 0.2) Casing : Aluminum Impeller : Plastic Bearing : Ball Bearing Lead Wire : UL3266, AWG22, +Red, -Black, Speed Control = Yellow, Speed Signal = White Specifications MODEL 1.3 x.x Rated Voltage Operating Current Voltage Input Speed Power Max. Air Flow Max. Static (V) (V) (A)*1 (W)*1 (min-1)*1 R150A3-051-D0790 48 30 ~ 72 4.10 196.8 9300 544 15.41 6.21 R150A1-051-D0760 48 30 ~ 72 1.50 72.0 6300 365 10.33 3.48 Rotation: Clockwise Airflow Outlet: Air Out Over Struts Noise Mass Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 1550 85 1000 870 73 1000 *1: Average Values in Free Air and Rated Voltage Condition 0.35 (4-9)
R150A1-051-D0760 价格&库存
很抱歉,暂时无法提供与“R150A1-051-D0760”相匹配的价格&库存,您可以联系我们找货
