R172A5-051-D0760
R172A5-051-D0760
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 172.7X50.8MM 48VDC
R172A5-051-D0760 数据手册
NE W ! R172 (Ø172 X 51L) NMBTC.COM / 818.341.3355 Characteristic Curves In H2O (Pa) 1600 6 6,300rpm 1200 4 1000 3 800 600 2 400 1 200 0 100 0 200 200 General Specifications 400 300 400 600 Air Flow 500 600 800 1,000 700 [CFM] [m3/h] High Power Fans 5 Static Pressure 9,300rpm 1400 Outline Motor Protection: inch Units: (mm) Locked Rotor, Reverse Polarity ROTATION Insulation Resistance: 10M Ω min measured with 500V DC between all leads shorted together and case 0.319 (3-8.1) 0.161 (8-F4.1 ) 0.159 (3-R4.05 ) Dielectric Withstand Voltage: AC 700V 1 minute Allowable Ambient Temperature Range: DEPTH 0.3 11.42 Min 290 6.38 (F162 ± 0.2 ) -30°C ~ +70°C (Operating) -40°C ~ +80°C (Storage) Failure Rate: 10% 40°C 70,000 Hours (L10) 0.2 (5. 2 8 DE 0.01 ) PT 1 H 0.3 Expected Life AIR NAME PLATE 0.11 ) (R2.9 .5˚ 55 .5˚ 55 0.35 (4-9) 6.80 (F172.7 ) Material 2.00 (50.8 ± 0.2) 0.34 (4-8.8) Casing : Aluminum Impeller : Plastic Bearing : Ball Bearing Lead Wire : UL3266, AWG22, +Red, -Black, Speed Control = Yellow, Speed Signal = White Specifications Rated Voltage MODEL Operating Current Voltage Input Speed Power Max. Air Flow Max. Static (V) (V) (A)*1 (W)*1 (min-1)*1 R172A0-051-D0790 48 30 ~ 72 4.40 211.2 9300 604 17.11 6.05 R172A5-051-D0760 48 30 ~ 72 1.60 76.8 6300 409 11.58 3.02 Rotation: Clockwise Airflow Outlet: Air Out Over Struts Noise Mass Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 1510 82 1050 755 74 1050 *1: Average Values in Free Air and Rated Voltage Condition x.x
R172A5-051-D0760 价格&库存
很抱歉,暂时无法提供与“R172A5-051-D0760”相匹配的价格&库存,您可以联系我们找货
