F225A4-092-D0530
F225A4-092-D0530
    NMBTECHNOLOGIESCORPORATION
    FAN IMP MTRZD 225X99MM 24VDC
F225A4-092-D0530 数据手册
NE W ! F225 (Ø225 X 99L) NMBTC.COM / 818.341.3355 Characteristic Curves In H2O (Pa) 900 2,900rpm 700 600 Static Pressure Impellers 3,600rpm 800 3 500 2 400 300 1 200 100 0 100 0 200 200 300 400 400 600 500 800 600 700 1,000 1,200 800 [CFM] [m3/h] Air Flow General Specifications Outline Motor Protection: inch Units: (mm) Locked Rotor, Reverse Polarity ROTATION Insulation Resistance: 10M Ω min measured with 500V DC between all leads shorted together and case 15˚ 3.78 (4xM4 P.C.D. 96.0) -30°C ~ +70°C (Operating) -40°C ~ +80°C (Storage) Expected Life 5.95 (F151.2) 5.70 (F145.0) 8.86 (F225.0 ) 4.53 (F115.0) 90 ˚ Dielectric Withstand Voltage: AC 700V 1 minute Allowable Ambient Temperature Range: 3.90 (99.0) 3.62 (92.0) 90 25.61 (650 ± 20 ) 1. R3 18 0 ˚ 0.63 (16.1) 0.23 (6.0 ) Failure Rate: 10% 40°C 70,000 Hours (L10) Material Impeller : Plastic Bearing : Ball Bearing Lead Wire : UL1015, AWG18, +Red, -Black, Speed Control = Yellow, Speed Signal = White Specifications Rated Voltage MODEL 1.7 x.x Operating Current Voltage Input Speed Power Max. Air Flow Max. Static (V) (V) (A)*1 (W)*1 (min-1)*1 F225A2-092-D0730 48 30 ~ 72 4.15 201.6 3600 763 21.61 3.44 F225A3-092-D0720 48 30 ~ 72 2.15 105.6 2900 618 17.50 2.30 F225A4-092-D0530 24 18 ~ 30 7.20 172.8 3600 763 21.61 F225A5-092-D0520 24 18 ~ 30 3.85 93.6 2900 611 17.50 Rotation: Clockwise *1: Average Values in Free Air and Rated Voltage Condition Noise Mass Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 860 79 2100 575 74 2100 3.44 860 79 2100 2.30 575 74 2100 1.38 (35.2)
F225A4-092-D0530 价格&库存
很抱歉,暂时无法提供与“F225A4-092-D0530”相匹配的价格&库存,您可以联系我们找货
