74ALVCH162601DGG,1
74ALVCH162601DGG,1
    NEXPERIA(安世)
    TSSOP56_14X6.1MM
    IC UNIV BUS TXRX 18BIT 56TSSOP
74ALVCH162601DGG,1 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS DATA SHEET 74ALVCH162601 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state Product specification File under Integrated Circuits, IC24 1999 Oct 14 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 FEATURES DESCRIPTION • Complies with JEDEC standard no. 8-1A The 74ALVCH162601 is an 18-bit universal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. Data flow in each direction is controlled by output enable (OEAB and OEBA), and clock (CPAB and CPBA) inputs. For A-to-B data flow, the device operates in the transparent mode when LEAB is HIGH. When LEAB is LOW, the A data is latched if CPAB is held at a HIGH or LOW logic level. If LEAB is LOW, the A-bus data is stored in the latch/flip-flop on the LOW-to-HIGH transition of CPAB. When OEAB is LOW, the outputs are active. When OEAB is HIGH, the outputs are in the high-impedance state. The clocks can be controlled with the clock-enable inputs (CEBA/CEAB). • CMOS low power consumption • Direct interface with TTL levels • MULTIBYTE flow-through standard pin-out architecture • Low inductance multiple VCC and ground pins for minimum noise and ground bounce • All data inputs have bus hold circuitry Data flow for B-to-A is similar to that of A-to-B but uses OEBA, LEBA and CPBA. To ensure the high-impedance state during power-down, OEBA and OEAB should be tied to VCC through a pull-up resistor, the minimum value of the resistor is determined by the current-sinking/current-sourcing capability of the driver. • Integrated 30 Ω termination resistors. The 74ALVCH162601 is designed with 30 Ω series resistors in both HIGH or LOW output stage. Active bus hold circuitry is provided to hold unused or floating data inputs at a valid logic level. QUICK REFERENCE DATA Ground = 0; Tamb = 25 °C; tr = tf = 2.5 ns. SYMBOL tPHL/tPLH PARAMETER propagation delay An, Bn to Bn, An CONDITIONS TYPICAL UNIT CL = 30 pF; VCC = 2.5 V 4.0 ns CL = 50 pF; VCC = 3.3 V 3.1 ns CI/O input/output capacitance 8.0 pF CI input capacitance 4.0 pF CPD power dissipation capacitance per latch outputs enabled 21 pF outputs disabled 3 pF notes 1 and 2 Notes 1. CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; ∑ (CL × VCC2 × fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in Volts. 2. The condition is VI = GND to VCC. 1999 Oct 14 2 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 FUNCTION TABLE See note 1. INPUTS OUTPUTS STATUS CEXX OEXX LEXX CPXX An, Bn X H X X X Z disabled X X L L H H X X H L H L transparent H L L X X NC L L L L L L ↑ ↑ h l H L L L L L L L L H X X NC hold clock and display hold Note 1. XX = AB for A-to-B direction, BA for B-to-A direction; H = HIGH voltage level; L = LOW voltage level; h = HIGH state must be present one set-up time before the LOW-to-HIGH transition of CPXX; l = LOW state must be present one set-up time before the LOW-to-HIGH transition of CPXX; X = don’t care; ↑ = LOW-to-HIGH level transition; NC = no change; Z = high-impedance OFF-state. ORDERING INFORMATION PACKAGE TYPE NUMBER 74ALVCH162601DGG 1999 Oct 14 TEMPERATURE RANGE PINS PACKAGE MATERIAL CODE −40 to +85 °C 56 TSSOP plastic SOT364-1 3 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 PINNING PIN SYMBOL DESCRIPTION 1 OEAB output enable A-to-B 2 LEAB latch enable A-to-B 3, 5, 6, 8, 9, 10, 12, 13, 14, 15, A0 to A17 16, 17, 19, 20, 21, 23, 24, 26 data inputs/outputs 4, 11, 18, 25, 32, 39, 46, 53 GND ground (0 V) 7, 22, 35, 50 VCC DC supply voltage 27 OEBA output enable B-to-A 28 LEBA latch enable B-to-A 29 CEBA clock enable B-to-A 30 CPBA clock input B-to-A 31, 33, 34, 36, 37, 38, 40, 41, 42, 43, 44, 45, 47, 48, 49, 51, 52, 54 B17 to B0 data inputs/outputs 55 CPAB clock input A-to-B 56 CEAB clock enable A-to-B 1999 Oct 14 4 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 handbook, halfpage OEAB 1 56 CEAB LEAB 2 55 CPAB A0 3 54 B0 GND 4 53 GND A1 5 52 B1 A2 6 51 B2 VCC 7 50 VCC A3 8 49 B3 A4 9 48 B4 A5 10 47 B5 handbook, halfpage data input to internal circuit MNA291 46 GND GND 11 A6 12 45 B6 A7 13 44 B7 Fig.2 Bus hold circuit. 43 B8 A8 14 162601 A9 15 42 B9 A10 16 41 B10 A11 17 40 B11 GND 18 39 GND A12 19 38 B12 A13 20 37 B13 A14 21 36 B14 VCC 22 35 VCC A15 23 34 B15 A16 24 33 B16 GND 25 32 GND A17 26 31 B17 OEBA 27 30 CPBA LEBA 28 29 CEBA MNA287 Fig.1 Pin configuration. 1999 Oct 14 VCC 5 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state handbook, full pagewidth 74ALVCH162601 OEAB CEAB LEAB CPAB CPBA LEBA CEBA OEBA CE C1 Bn CP 1D An CE C1 CP 1D 18 IDENTICAL CHANNELS MNA289 Fig.3 Logic diagram (one section). 1999 Oct 14 6 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state handbook, halfpage OEAB CEAB CPAB LEAB 1 EN1 56 G2 55 2 2C3 handbook, halfpage C3 CEBA CPBA LEBA 27 29 28 6 EN4 8 G5 30 3 5 G2 OEBA 74ALVCH162601 9 5C6 C6 10 G5 12 13 A0 3 3D 4 A1 A2 1 54 6D 5 52 6 51 A3 8 9 A4 10 A5 12 A6 13 A7 14 A8 15 A9 16 A10 17 A11 19 A12 20 A13 21 A14 23 A15 24 A16 26 A17 14 B0 49 48 47 45 44 43 42 15 B1 16 B2 17 B3 19 B4 20 B5 21 B6 23 B7 24 B8 26 B9 41 B10 40 B11 38 B12 37 B13 36 B14 34 B15 33 B16 31 B17 1 2 55 56 A0 B0 A1 B1 A2 B2 A3 B3 A4 B4 A5 B5 A6 B6 A7 B7 A8 B8 A9 B9 A10 B10 A11 B11 A12 B12 A13 B13 A14 B14 A15 B15 A16 B16 A17 B17 OEAB OEBA LEAB LEBA CPAB CPBA CEAB CEBA MNA288 MNA290 Fig.4 IEC logic symbol. 1999 Oct 14 Fig.5 Logic symbol. 7 54 52 51 49 48 47 45 44 43 42 41 40 38 37 36 34 33 31 27 28 30 29 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 RECOMMENDED OPERATING CONDITIONS SYMBOL VCC PARAMETER CONDITIONS MIN. TYP. MAX. UNIT DC supply voltage for max. speed performance CL = 30 pF 2.3 2.5 2.7 V for max. speed performance CL = 50 pF 3.0 3.3 3.6 V 1.2 2.4 3.6 V VI DC input voltage for low-voltage applications 0 − VCC V VO DC output voltage 0 − VCC V Tamb operating ambient temperature in free air −40 − +85 °C tr, tf input rise and fall times VCC = 2.3 to 3.0 V 0 − 20 ns/V VCC = 3.0 to 3.6 V 0 − 10 ns/V LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 134); voltages are referenced to GND (ground = 0 V). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VCC DC supply voltage −0.5 +4.6 V IIK DC input diode current VI < 0 − −50 mA VI DC input voltage note 1 −0.5 +4.6 V mA IOK DC output diode current VO > VCC or VO < 0 − ±50 VO DC output voltage note 1 −0.5 VCC + 0.5 V IO DC output source or sink current VO = 0 to VCC − ±50 mA ICC, IGND DC VCC or GND current − ±100 mA Tstg storage temperature −65 +150 °C Ptot power dissipation − 600 mW for temperature range: −40 to +125 °C; note 2 Notes 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 2. Above 55 °C the value of Ptot derates linearly with 8 mW/K. 1999 Oct 14 8 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 DC CHARACTERISTICS Over recommended operating conditions; voltages are referenced to GND (ground = 0 V). Tamb = −40 TO +85 °C TEST CONDITIONS SYMBOL PARAMETER VI (V) VIH VIL VOH VOL OTHER HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH or VIL VIH or VIL VCC (V) TYP.(1) MIN. UNIT MAX. 2.3 to 2.7 1.7 1.2 − 2.7 to 3.6 2.0 1.5 − 2.3 to 2.7 − 1.2 0.7 2.7 to 3.6 − 1.5 0.8 IO = −100 µA 2.3 to 3.6 VCC − 0.2 VCC − IO = −4 mA 2.3 VCC − 0.4 VCC − 0.11 − IO = −6 mA 2.3 VCC − 0.6 VCC − 0.17 − IO = −4 mA 2.7 VCC − 0.5 VCC − 0.09 − IO = −8 mA 2.7 VCC − 0.7 VCC − 0.19 − IO = −6 mA 3.0 VCC − 0.6 VCC − 0.13 − IO = −12 mA 3.0 VCC − 1.0 VCC − 0.27 − V V V IO = 100 µA 2.3 to 3.6 − GND 0.20 IO = 4 mA 2.3 − 0.07 0.40 IO = 6 mA 2.3 − 0.11 0.55 IO = 4 mA 2.7 − 0.06 0.40 IO = 8 mA 2.7 − 0.13 0.60 IO = 6 mA 3.0 − 0.09 0.55 IO = 12 mA 3.0 − 0.19 0.80 2.3 to 3.6 − 0.1 5 µA V Il input leakage current VCC or GND IOZ 3-state output OFF-state current VIH or VIL VO = VCC or GND 2.3 to 3.6 − 0.1 10 µA ICC quiescent supply voltage VCC or GND IO = 0 2.3 to 3.6 − 0.2 40 µA ∆ICC additional quiescent supply VCC − 0.6 current given per data I/O pin with bus hold IO = 0 2.3 to 3.6 − 150 750 µA IBHL bus hold LOW sustaining current 0.7(2) 2.3(2) 45 − − µA 0.8(2) 3.0(2) 75 150 − bus hold HIGH sustaining current 1.7(2) 2.3(2) −45 2.0(2) 3.0(2) −75 −175 − 500 − − µA −500 − − µA IBHH IBHLO bus hold LOW overdrive current 3.6(2) IBHHO bus hold LOW overdrive current 3.6(2) Notes 1. All typical values are measured at Tamb = 25 °C. 2. Valid for data inputs of bus hold parts. 1999 Oct 14 9 − µA Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 AC CHARACTERISTICS FOR VCC = 2.3 TO 2.7 V Ground = 0 V; tr = tf ≤ 2.0 ns; CL = 30 pF. TEST CONDITIONS SYMBOL PARAMETER WAVEFORMS tPHL/tPLH VCC (V) Tamb = −40 TO +85 °C MIN. TYP.(1) UNIT MAX. propagation delay An, Bn to Bn, An see Figs 6 and 10 2.3 to 2.7 1.3 4.0 5.3 ns propagation delay LEAB, LEBA to Bn, An see Figs 7 and 10 2.3 to 2.7 1.0 4.5 6.0 ns propagation delay CPAB, CPBA to Bn, An see Figs 7 and 10 2.3 to 2.7 1.5 4.7 6.4 ns tPZH/tPZL 3-state output enable time OEAB, OEBA to Bn, An see Figs 8 and 10 2.3 to 2.7 1.6 3.9 6.1 ns tPHZ/tPLZ 3-state output disable time OEAB, OEBA to Bn, An see Figs 8 and 10 2.3 to 2.7 1.8 2.6 5.7 ns tW clock pulse width HIGH LEAB see Figs 7 and 10 or LEBA 2.3 to 2.7 3.3 1.6 − ns clock pulse width HIGH or LOW CPAB or CPBA see Figs 7 and 10 2.3 to 2.7 3.3 2.0 − ns set-up time An, Bn to CPAB, CPBA see Figs 9 and 10 2.3 to 2.7 +2.3 −0.2 − ns set-up time An, Bn to LEAB, LEBA see Figs 9 and 10 2.3 to 2.7 1.3 0.1 − ns 2.3 to 2.7 +2.0 −0.4 − ns tsu set-up time CEAB, CEBA to CPAB, CPBA th hold time An, Bn to CPAB, CPBA see Figs 9 and 10 2.3 to 2.7 1.2 0.3 − ns hold time An, Bn to LEAB, LEBA see Figs 9 and 10 2.3 to 2.7 1.3 0.2 − ns 2.3 to 2.7 1.1 0.4 − ns 2.3 to 2.7 150 190 − MHz hold time CEAB, CEBA to CPAB, CPBA fmax maximum clock pulse frequency see Figs 7 and 10 Note 1. All typical values are measured at Tamb = 25 °C and VCC = 2.5 V. 1999 Oct 14 10 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 AC CHARACTERISTICS FOR VCC = 2.7 V AND VCC = 3.0 TO 3.6 V Ground = 0 V; tr = tf ≤ 2.5 ns; CL = 50 pF. Tamb = −40 TO +85 °C TEST CONDITIONS SYMBOL PARAMETER WAVEFORMS tPHL/tPLH tPZH/tPZL tPHZ/tPLZ tW tsu propagation delay An, Bn to Bn, An see Figs 6 and 10 propagation delay LEAB, LEBA to Bn, An see Figs 7 and 10 propagation delay CPAB, CPBA to Bn, An see Figs 7 and 10 3-state output enable time OEAB, OEBA to Bn, An see Figs 8 and 10 3-state output disable time OEAB, OEBA to Bn, An see Figs 8 and 10 clock pulse width LEAB, LEBA to CPAB, CPBA see Figs 7 and 10 clock pulse width HIGH or LOW CPAB, CPBA see Figs 7 and 10 set-up time An, Bn to CPAB, CPBA see Figs 9 and 10 set-up time An, Bn to LEAB, LEBA see Figs 9 and 10 hold time An, Bn to CPAB, CPBA see Figs 9 and 10 hold time An, Bn to LEAB, LEBA see Figs 9 and 10 hold time CEAB, CEBA to CPAB, CPBA fmax maximum clock pulse frequency see Figs 7 and 10 1. All typical values are measured at Tamb = 25 °C. 2. Typical values at VCC = 3.3 V. 1999 Oct 14 11 TYP.(1) UNIT MAX. 3.9 5.2 3.0 to 3.6 1.6 3.1(2) 4.5 2.7 − 4.3 5.9 3.0 to 3.6 1.5 3.5(2) 5.1 2.7 − 4.5 6.3 3.0 to 3.6 1.6 3.7(2) 5.5 2.7 − 3.9 6.7 3.0 to 3.6 1.6 3.1(2) 5.7 2.7 − 3.2 5.3 3.0 to 3.6 1.8 2.9(2) 4.8 2.7 3.3 0.7 − 3.3 0.9(2) − 2.7 3.3 1.2 − 3.0 to 3.6 3.3 0.9(2) − 2.7 2.4 0.0 − 3.0 to 3.6 +2.1 −0.2(2) − 2.7 +1.2 −0.2 − 3.0 to 3.6 1.1 0.3(2) − 2.7 +2.0 −0.7 − 3.0 to 3.6 +1.7 −0.2(2) − 2.7 1.1 0.3 − 3.0 to 3.6 +1.0 −0.1(2) − 2.7 1.6 0.1 − 3.0 to 3.6 1.4 0.1(2) − 2.7 1.2 0.6 − 3.0 to 3.6 1.1 0.4(2) − 2.7 150 190 − 150 240(2) − 3.0 to 3.6 Notes MIN. − 2.7 3.0 to 3.6 set-up time CEAB, CEBA to CPAB, CPBA th VCC (V) ns ns ns ns ns ns ns ns ns ns ns ns ns MHz Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 AC WAVEFORMS handbook, halfpage VI An, Bn VM input GND tPHL tPLH VOH Bn, An VM output VOL MNA292 Fig.6 The input An, Bn to output Bn, An propagation delay times. Notes: VCC = 2.3 to 2.7 V VM = 0.5VCC; VX = VOL + 150 mV; VY = VOH − 150 mV; VI = VCC; VOL and VOH are typical output voltage drop that occur with the output load. Notes: VCC = 3.0 to 3.6 V and VCC = 2.7 V VM = 1.5 V; VX = VOL + 300 mV; VY = VOH − 300 mV; VI = 2.7 V; VOL and VOH are typical output voltage drop that occur with the output load. 1999 Oct 14 12 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 1/fmax handbook, full pagewidth VI LEXX, CPXX input VM VM GND tW tPHL tPLH VOH VM Bn, An output VOL Fig.7 MNA293 Latch enable input LEAB, LEBA and clock input CPAB, CPBA to output Bn, An propagation delay times; pulse width and fmax of CPAB, CPBA. VI handbook, full pagewidth OEXX input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ tPZH VOH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled MNA294 Fig.8 3-state enable and disable times. 1999 Oct 14 13 Philips Semiconductors Product specification 18-bit universal bus transceiver with 30 Ω termination resistor; 3-state 74ALVCH162601 VI handbook, full pagewidth VM An, Bn input GND th th tsu tsu VI VM CPXX, LEXX input MNA295 GND The shaded areas indicate when the input is permitted to change for predictable output performance. Fig.9 Data set-up and hold times for An and Bn inputs to LEAB, LEBA, CPAB or CPBA inputs. S1 handbook, full pagewidth VCC PULSE GENERATOR VI RL 500 Ω VO 2 × VCC open GND D.U.T. CL 50 pF RT RL 500 Ω MNA296 TEST S1 VCC Definitions for test circuit. CL = load capacitance including jig and probe capacitance (See Chapter “AC characteristics”). RL = load resistance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. VI tPLH/tPHL open tPLZ/tPZL 2 × VCC
74ALVCH162601DGG,1 价格&库存
很抱歉,暂时无法提供与“74ALVCH162601DGG,1”相匹配的价格&库存,您可以联系我们找货
