Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
74ALVCH16500
18-bit universal bus transceiver (3-State)
Product specification
Supersedes data of 1998 Aug 31
IC24 Data Handbook
1998 Sep 24
FEATURES
74ALVCH16500
DESCRIPTION
• Complies with JEDEC standard no. 8-1A
• CMOS low power consumption
• Direct interface with TTL levels
• Current drive ± 24 mA at 3.0 V
• All inputs have bushold circuitry
• Output drive capability 50Ω transmission lines @ 85°C
• MULTIBYTETM flow-through standard pin-out architecture
• Low inductance multiple VCC and ground pins for minimum noise
The 74ALVCH16500 is a high-performance CMOS product.
This device is an 18-bit universal transceiver featuring non-inverting
3-State bus compatible outputs in both send and receive directions.
Data flow in each direction is controlled by output enable (OEAB and
OEBA), latch enable (LEAB and LEBA), and clock (CPAB and CPBA)
inputs. For A-to-B data flow, the device operates in the transparent
mode when LEAB is High. When LEAB is Low, the A data is latched if
CPAB is held at a High or Low logic level. If LEAB is Low, the A-bus
data is stored in the latch/flip-flop on the High-to-Low transition of
CPAB. When OEAB is High, the outputs are active. When OEAB is
Low, the outputs are in the high-impedance state.
Data flow for B-to-A is similar to that of A-to-B but uses OEBA, LEBA
and CPBA. The output enables are complimentary (OEAB is active
High, and OEBA is active Low).
and ground bounce
To ensure the high impedance state during power up or power
down, OEBA should be tied to VCC through a pullup resistor and
OEAB should be tied to GND through a pulldown resistor; the
minimum value of the resistor is determined by the
current-sinking/current-sourcing capability of the driver.
Active bus-hold circuitry is provided to hold unused or floating data
inputs at a valid logic level.
QUICK REFERENCE DATA
GND = 0V; Tamb = 25°C; tr = tf = 2.5ns
SYMBOL
PARAMETER
CONDITIONS
TYPICAL
UNIT
3.1
2.9
ns
tPHL/tPLH
Propagation delay
An, Bn to Bn, An
CI/O
Input/output capacitance
8.0
pF
CI
Input capacitance
4.0
pF
CPD
Power dissipation
dissi ation capacitance
ca acitance per
er latch
VCC = 2.5V, CL = 30pF
VCC = 3.3V, CL = 50pF
VI = GND to VCC1
Outputs enabled
21
Outputs disabled
3
pF
F
NOTES:
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + (CL × VCC2 × fo) where: fi = input frequency in MHz; CL = output load capacitance in pF;
fo = output frequency in MHz; VCC = supply voltage in V; (CL × VCC2 × fo) = sum of outputs.
ORDERING INFORMATION
PACKAGES
56-Pin Plastic TSSOP Type II
1998 Sep 24
TEMPERATURE RANGE
OUTSIDE NORTH AMERICA
DWG NUMBER
–40°C to +85°C
74ALVCH16500 DGG
SOT364-1
2
8533-2125 20079
PIN CONFIGURATION
PIN DESCRIPTION
OEAB
1
56 GND
LEAB
2
55 CPAB
A0
3
54 A0
GND
4
53 GND
A1
5
52 B1
A2
6
51 B2
VCC
7
50 VCC
A3
8
49 B3
A4
9
48 B4
A5
10
47 B5
GND 11
46 GND
A6 12
45 B6
13
44 B7
A8 14
43 B8
A7
74ALVCH16500
A9 15
42 B9
A10 16
41 B10
A11
17
40 B11
GND
18
39 GND
A12
19
38 B12
A13 20
37 B13
A14
21
36 B14
VCC
22
35 VCC
A15
23
34 B15
A16 24
33 B16
PIN NUMBER
SYMBOL
1
OEAB
Output enable A-to-B
2
LEAB
Latch enable A-to-B
3, 5, 6, 8, 9,
10, 12, 13, 14,
15, 16, 17, 19,
20, 21, 23, 24,
26
A0 to A17
Data inputs/outputs
4, 11, 18, 25,
29, 32, 39, 46,
53, 56
GND
Ground (0V)
7, 22, 35, 50
VCC
Positive supply voltage
27
OEBA
Output enable B-to-A
28
LEBA
Latch enable B-to-A
30
CPBA
Clock input B-to-A
54, 52, 51, 49,
48, 47, 45, 44,
43, 42, 41, 40,
38, 37, 36, 34,
33, 31
B0 to B17
Data inputs/outputs
55
CPAB
Clock input A-to-B
BUS HOLD CIRCUIT
VCC
Data Input
GND
25
32 GND
A17
26
31 B17
OEBA
27
30 CPBA
LEBA 28
29 GND
To internal circuit
SW00044
SW00080
1998 Sep 24
NAME AND FUNCTION
3
LOGIC SYMBOL
LOGIC SYMBOL (IEEE/IEC)
3
5
A0
A1
B0
B1
54
52
6
8
9
10
A2
A3
A4
A5
B2
B3
B4
B5
51
49
48
47
12
13
14
15
A6
A7
A8
A9
16
17
19
23
24
26
74ALVCH16500
B6
B7
B8
B9
45
44
43
42
A10
A11
A12
A13
B10
B11
B12
B13
41
40
38
37
A14
A15
A16
A17
B14
B15
B16
B17
36
34
33
31
1
2
OEAB
LEAB
OEBA
LEBA
27
28
55
CPAB
CPBA
30
OEAB
1
CPAB
56
LEAB
2
OEAB
27
CPBA
30
LEBA
28
EN1
2C3
C3
G2
EN4
5C6
C6
G5
A0
3D
1
1
4
1
6D
54
B0
A1
5
52
B1
A2
6
51
B2
A3
8
49
B3
9
48
B4
A5
10
47
B5
A6
12
45
B6
A7
13
44
B7
A8
14
43
B8
A9
15
42
B9
A10
16
41
B10
A11
17
40
B11
A12
19
38
B12
A13
B13
A14
21
36
B14
A15
23
34
B15
A16
24
33
B16
A17
26
31
B17
A4
SW00081
3
SW00082
1998 Sep 24
4
74ALVCH16500
LOGIC DIAGRAM (one section)
OEAB
CPBA
LEBA
CPAB
LEAB
OEBA
C1
C1
1D
1D
Bn
An
C1
C1
1D
1D
18 IDENTICAL CHANNELS
SW00090
FUNCTION TABLE
INPUTS
OUTPUTS
OEAB
LEAB
CPAB
An
OPERATING MODE
Bn
L
H
X
X
Z
Disabled
H
H
X
H
H
Transparent
H
H
X
L
L
H
X
h
H
H
X
I
L
H
L
h
H
H
L
I
L
H
L
H or L
X
H
H
L
H or L
X
L
NOTE: A-to-B data flow is shown; B-to-A flow is similar but uses OEBA, LEBA, and CPBA.
H = High voltage level
h = High voltage level one set-up time prior to the Enable or Clock transition
L = Low voltage level
I = Low voltage level one set-up time prior to the Enable or Clock transition
NC= No Change
X = Don’t care
Z = High Impedance ”off” state
↓ = High-to-Low Enable or Clock transition
1998 Sep 24
5
Latch data & dis
display
lay
Clock data & display
dis lay
Hold data & dis
display
lay
74ALVCH16500
RECOMMENDED OPERATING CONDITIONS
LIMITS
SYMBOL
VCC
PARAMETER
CONDITIONS
UNIT
MIN
MAX
DC supply voltage 2.5V range (for max. speed
performance @ 30 pF output load)
2.3
2.7
DC supply voltage 3.3V range (for max. speed
performance @ 50 pF output load)
3.0
3.6
V
VI
DC Input voltage range
VCC
V
VO
DC output voltage range
VCC
V
–40
+85
°C
ns/V
Tamb
Operating free-air temperature range
tr, tf
Input rise and fall times
VCC = 2.3 to 3.0V
VCC = 3.0 to 3.6V
ABSOLUTE MAXIMUM RATINGS
In accordance with the Absolute Maximum Rating System (IEC 134)
Voltages are referenced to GND (ground = 0V)
SYMBOL
VCC
IIK
PARAMETER
CONDITIONS
DC supply voltage
DC input diode current
VI 0
DC output diode current
VO VCC or VO 0
DC output voltage
Note 1
IO
DC output source or sink current
VO = 0 to VCC
DC VCC or GND current
Storage temperature range
For temperature range: –40 to +125 °C
above +55°C derate linearly with 8 mW/K
NOTE:
1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
1998 Sep 24
–50
mA
–0.5 to VCC +0.5
VO
Power dissipation per package
–plastic thin-medium-shrink (TSSOP)
V
For data inputs1
IOK
PTOT
–0.5 to +4.6
–0.5 to +4.6
DC in
input
ut voltage
Tstg
UNIT
For control pins1
VI
IGND, ICC
RATING
6
V
50
mA
–0.5 to VCC +0.5
V
50
mA
100
mA
–65 to +150
°C
600
mW
74ALVCH16500
DC ELECTRICAL CHARACTERISTICS
Over recommended operating conditions. Voltage are referenced to GND (ground = 0 V).
LIMITS
SYMBOL
PARAMETER
VIH
HIGH level Input voltage
VIL
LOW level Input voltage
VOH
O
HIGH level output voltage
TEST CONDITIONS
Temp = -40°C to +85°C
MIN
TYP1
VCC = 2.3 to 2.7V
1.7
1.2
VCC = 2.7 to 3.6V
2.0
1.5
UNIT
MAX
V
VCC = 2.3 to 2.7V
1.2
0.7
VCC = 2.7 to 3.6V
1.5
0.8
V
3 to 3
6V; VI = VIH or VIL; IO = –100µA
100µA
VCC = 2
2.3
3.6V;
02
VCC0.2
VCC
VCC = 2.3V; VI = VIH or VIL; IO = –6mA
VCC0.3
VCC0.08
VCC = 2.3V; VI = VIH or VIL; IO = –12mA
VCC0.6
VCC0.26
VCC = 2.7V; VI = VIH or VIL; IO = –12mA
VCC0.5
VCC0.14
VCC = 3.0V; VI = VIH or VIL; IO = –12mA
VCC0.6
VCC0.09
VCC = 3.0V; VI = VIH or VIL; IO = –24mA
VCC1.0
VCC0.28
V
VCC = 2
2.3
3 to 3
3.6V;
6V; VI = VIH or VIL; IO = 100µA
GND
0 20
0.20
V
VCC = 2.3V; VI = VIH or VIL; IO = 6mA
0.07
0.40
V
VCC = 2.3V; VI = VIH or VIL; IO = 12mA
0.15
0.70
VCC = 2.7V; VI = VIH or VIL; IO = 12mA
0.14
0.40
VCC = 3.0V; VI = VIH or VIL; IO = 24mA
0.27
0.55
Input leakage
g current
VCC = 2
2.3
3 to 3
3.6V;
6V;
VI = VCC or GND
0.1
5
µA
µ
IOZ
3-State output OFF-state current
VCC = 2.7 to 3.6V; VI = VIH or VIL;
VO = VCC or GND
0.1
10
µA
ICC
Quiescent supply current
VCC = 2.3 to 3.6V; VI = VCC or GND; IO = 0
0.2
40
µA
∆ICC
Additional quiescent supply current
VCC = 2.3V to 3.6V; VI = VCC – 0.6V; IO = 0
150
750
µA
IBHL
Bus hold LOW sustaining current
IBHH
Bus hold HIGH sustaining current
IBHLO
Bus hold LOW overdrive current
VCC = 3.6V2
500
µA
IBHHO
Bus hold HIGH overdrive current
VCC = 3.6V2
–500
µA
VOL
II
LOW level output voltage
VCC = 2.3V; VI = 0.7V2
45
0.8V2
75
150
VCC = 2.3V; VI = 1.7V2
–45
2.0V2
–75
VCC = 3.0V; VI =
VCC = 3.0V; VI =
NOTES:
1. All typical values are at Tamb = 25°C.
2. Valid for data inputs of bus hold parts.
1998 Sep 24
7
–175
V
µA
µA
74ALVCH16500
AC CHARACTERISTICS FOR VCC = 2.3V TO 2.7V RANGE
GND = 0V; tr = tf ≤ 2.0ns; CL = 30pF
LIMITS
SYMBOL
PARAMETER
TYP1
MAX
1.0
3.1
5.2
1.0
3.6
6.2
1.0
3.7
6.6
1.0
3.1
6.2
1.0
2.7
5.7
1.0
2.8
5.4
1.0
2.7
6.1
3.3
0.8
3.3
2.0
1.7
0.1
Set-up time
An, Bn to LEAB, LEBA
1.9
0.1
Hold time
An, Bn to CPAB, CPBA
1.7
0.2
Hold time
2.0
0.2
Maximum clock frequency
150
333
Propagation delay
LEAB, LEBA to Bn, An
1, 2
Propagation delay
CPAB, CPBA to Bn, An
tPZH/tPZL
tPHZ/tPLZ
tW
tSU
S
th
fMAX
3-State output enable time
OEBA to An
3
OEAB to Bn
OEBA to An
OEAB to Bn
Pulse width HIGH
LEAB, LEBA
ns
2
Pulse width HIGH or LOW
CPAB, CPBA
Set-up time
ns
4
ns
4
8
ns
ns
3
NOTE:
1. All typical values are at VCC = 2.5V and Tamb = 25°C.
1998 Sep 24
UNIT
MIN
Propagation delay
An, Bn to Bn, An
tPHL/tPLH
VCC = 2.5V ± 0.2V
WAVEFORM
ns
MHz
74ALVCH16500
AC CHARACTERISTICS FOR VCC = 3.0V TO 3.6V RANGE AND VCC = 2.7V
GND = 0V; tr = tf = 2.5ns; CL = 50pF
LIMITS
SYMBOL
PARAMETER
WAVEFORM
tPHZ/tPLZ
tW
tSU
S
th
fMAX
1.0
2.9
1.0
VCC = 2.7V
3.1
4.7
3.1
4.9
3.4
5.5
1.1
3.3
5.5
3.8
6.6
1.0
2.8
5.2
3.3
6.2
1.0
2.5
4.6
2.7
5.4
1.0
3.2
4.3
3.3
4.6
1.5
3.2
5.0
3.6
5.7
3.3
0.9
3.3
0.7
3.3
1.1
3.3
1.4
1.3
0.2
1.4
0.1
Set-up time
1.4
0.3
1.6
–0.2
Hold time
1.3
–0.1
1.6
0.3
Hold time
1.5
0.1
1.8
0.1
150
340
150
333
Propagation delay
1, 2
OEBA to An
3
3
ns
3-State output disable tiime
OEAB to Bn
LE pulse width
LEAB, LEBA to CPAB, CPBA
2
ns
LE pulse width HIGH or LOW
CPAB, CPBA
Set-up time
ns
ns
OEAB to Bn
3-State output disable time
OEBA to An
MIN
UNIT
4.2
4
ns
4
ns
NOTE:
1. All typical values are at VCC = 3.3V and Tamb = 25°C.
1998 Sep 24
MAX
MAX
Propagation delay
tPZH/tPZL
TYP1
TYP
Propagation delay
An, Bn to Bn, An
tPHL/tPLH
VCC = 3.3V ±0.3V
MIN
9
MHz
74ALVCH16500
AC WAVEFORMS
VCC = 2.3 TO 2.7 V RANGE
1. VM = 0.5 V
2. VX = VOL + 0.15V
3. VY = VOH – 0.15V
4. VI = VCC
5. VOL and VOH are the typical output voltage drop that occur with
the output load.
VCC = 3.0 TO 3.6 V RANGE AND VCC = 2.7 V
1. VM = 1.5 V
2. VX = VOL + 0.3V
3. VY = VOH – 0.3V
4. VI = 2.7 V
the output load.
OEAB
INPUT
VM
VM
OEBA
INPUT
tPLZ
tPZL
VCC
OUTPUT
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VI
An, Bn
INPUT
tPZH
VOH
VM
VY
OUTPUT
HIGH-to-OFF
OFF-to-HIGH
GND
tPHL
GND
tPLH
outputs
enabled
VOH
Bn, An
OUTPUT
VM
outputs
disabled
outputs
enabled
SW00085
VM
Waveform 3. 3-State enable and disable times
ÉÉÉ ÉÉÉÉÉÉÉÉ
ÉÉÉ
ÉÉÉ ÉÉÉÉÉÉÉÉ
ÉÉÉ
ÉÉÉ ÉÉÉÉÉÉÉÉ
ÉÉÉ
VOL
VI
SW00083
An, Bn
INPUT
Waveform 1. Input (An, Bn) to output (Bn, An) propagation
times
VM
GND
th
tSU
CPXX
INPUT
VI
VI
CPXX, LEXX
INPUT
VM
LEXX
INPUT
GND
VOH
An, Bn
OUTPUT
VM
GND
NOTE: The unshaded areas indicate when the input is permitted to change for
predictable output performance.
tW
tPHL
SW00093
tPLH
Waveform 4. Data set-up and hold times for the An and Bn
inputs to the LEAB, LEBA, CPAB and CPBA inputs
VM
VOL
SW00084
Waveform 2. Latch enable input (LEAB, LEBA) and clock pulse
input (CPAB, CPBA) to output (An, Bn) propagation delays and
latch enable pulse width
1998 Sep 24
th
tSU
10
TEST CIRCUIT
S1
VCC
RL = 500 Ω
VO
VI
PULSE
GENERATOR
2 * VCC
Open
GND
D.U.T.
RT
RL = 500 Ω
CL
Test Circuit for switching times
DEFINITIONS
RL = Load resistor
CL = Load capacitance includes jig and probe capacitance
RT = Termination resistance should be equal to ZOUT of pulse generators.
SWITCH POSITION
TEST
tPLH/tPHL
S1
Open
tPLZ/tPZL
2 VCC
tPHZ/tPZH
GND
VCC
VI
< 2.7V
VCC
2.7–3.6V
2.7V
SV00906
Waveform 5. Load circuitry for switching times
1998 Sep 24
11
74ALVCH16500
18–Bit Universal Bus Transceiver
74ALVCH16500
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1mm
1998 Sep 24
12
SOT364-1
74ALVCH16500
NOTES
1998 Sep 24
13
74ALVCH16500
DEFINITIONS
Data Sheet Identification
Product Status
Definition
Objective Specification
Formative or in Design
This data sheet contains the design target or goal specifications for product development. Specifications
may change in any manner without notice.
Preliminary Specification
Preproduction Product
This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips
Semiconductors reserves the right to make changes at any time without notice in order to improve design
and supply the best possible product.
Product Specification
Full Production
This data sheet contains Final Specifications. Philips Semiconductors reserves the right to make changes
at any time without notice, in order to improve design and supply the best possible product.
Philips Semiconductors and Philips Electronics North America Corporation reserve the right to make changes, without notice, in the products,
including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips
Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright,
or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask
work right infringement, unless otherwise specified. Applications that are described herein for any of these products are for illustrative purposes
only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing
or modification.
LIFE SUPPORT APPLICATIONS
Philips Semiconductors and Philips Electronics North America Corporation Products are not designed for use in life support appliances, devices,
or systems where malfunction of a Philips Semiconductors and Philips Electronics North America Corporation Product can reasonably be expected
to result in a personal injury. Philips Semiconductors and Philips Electronics North America Corporation customers using or selling Philips
Semiconductors and Philips Electronics North America Corporation Products for use in such applications do so at their own risk and agree to fully
indemnify Philips Semiconductors and Philips Electronics North America Corporation for any damages resulting from such improper use or sale.
Copyright Philips Electronics North America Corporation 1998
All rights reserved. Printed in U.S.A.
811 East Arques Avenue
P.O. Box 3409
Sunnyvale, California 94088–3409
Telephone 800-234-7381
Date of release: 08-98
Document order number:
1998 Aug 31
14
9397–750–04802
