3110KL-04W-B70-E00
3110KL-04W-B70-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X25MM 12VDC WIRE
3110KL-04W-B70-E00 数据手册
3110KL (80 X 25L) NMBTC.COM / 248.919.2250 For New Designs we Recommend 08025SA (Pa) In H2O 70 .28 .24 60 .20 50 .16 40 .12 30 Ps .08 20 .04 10 Auto Restart/Polarity Protection 10M � or over with a DC500V Megge Megger Static Pressure AC 700V 1s B70 Class: -10�C ~ +60�C C (Operating (Operating) B10 ~B60 Class: -10�C ~ +70�C C (Operating (Operating) All Class: -40�C ~ +70�C C (Storage) (Storage (non-condensing environment environment)) B70 B60 B50 B40 B30 B20 B10 (m3/min) 0 ROTATION AIR NAME PLATE 0.8 1.0 1.2 1.4 7 14 21 28 Air Flow 35 42 49 58 ) 3. 1.0 9 (� .169 4 – (�4.3 ± 0.2) 2.81 (71.5) 3.03 (77.0) INLET SIDE / OUTLET SIDE Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire: UL1007, AWG24, +Red, -Black 2.81 (71.5 ± 0.3) 3.15 (80.0 ± 0.3) .98 (25.0 ± 0.3) 0.6 3.03 (77.0) 2.81 (71.5) .169 4 – (�4.3 ± 0.2) 11.8 (300) min inch Units: (mm) 0.4 CFM 100,000 Hours (E00) 70,000 Hours (G00,D00) 60,000 Hours (C00, F00) 2.81 (71.5 ± 0.3) 3.15 (80.0 ± 0.3) 25°C 25°C 25°C 0.2 Rated Operating V Voltag e V Voltag e Noise Mass (V) (V) (A)*1 (W)*1 (min-1)*1 3110KL-04W-B10- Product No. X00 (Pa)*1 (dB)*1 12 6.0 ~ 13.8 0.10 1.20 2150 24.7 0.70 (g) .07 16.7 22.0 3110KL-04W-B20- X00 12 6.0 ~ 13.8 0.11 1.32 2400 28.2 95 0.80 .08 21.6 25.0 3110KL-04W-B30- X00 12 6.0 ~ 13.8 0.17 2.04 2700 95 31.8 0.90 .10 26.5 28.0 95 3110KL-04W-B40- X00 12 6.0 ~ 13.8 0.20 2.40 3110KL-04W-B50- X00 12 6.0 ~ 13.8 0.23 2.76 3000 35.3 1.00 .13 32.3 31.0 95 3250 38.8 1.10 .15 37.2 34.0 3110KL-04W-B60- X00 12 6.0 ~ 13.0 0.26 95 3.12 3400 40.2 1.14 .16 40.2 35.0 3110KL-04W-B70- X00 12 6.0 ~ 13.8 95 0.29 3.86 4000 45.9 1.30 .26 64.4 40.0 3110KL-05W-B10- X00 24 95 10.0 ~ 27.6 0.06 1.44 2150 24.7 0.70 .07 16.7 22.0 95 3110KL-05W-B20- X00 3110KL-05W-B30- X00 24 10.0 ~ 27.6 0.07 1.68 2400 28.2 0.80 .08 21.6 25.0 95 24 10.0 ~ 27.6 0.08 1.92 2700 31.8 0.90 .10 26.5 28.0 3110KL-05W-B40- 95 X00 24 10.0 ~ 27.6 0.10 2.40 3000 35.3 1.00 .13 32.3 31.0 95 3110KL-05W-B50- X00 24 10.0 ~ 27.6 0.12 2.88 3250 38.8 1.10 .15 37.2 34.0 95 3110KL-05W-B60- X00 24 10.0 ~ 26.4 0.14 3.36 3400 40.2 1.14 .16 40.2 35.0 95 MODEL Rotation: Clockwise Current Input Speed Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure CFM*1 (m3/min)*1 in H2O *1: Average A Values in Free Air V
3110KL-04W-B70-E00
物料型号:3110KL系列,包括不同型号如3110KL-04W-B10-, 3110KL-04W-B20-, 3110KL-05W-B10-等。
器件简介:DC轴流风扇,用于新设计推荐型号08025SA。
引脚分配:文档中未提供具体引脚分配信息。
参数特性:包括额定电压、工作电压、电流、输入功率、转速、最大气流、最大静压、噪音和质量等。
功能详解:文档中未提供具体功能详解
应用信息:适用于需要DC轴流风扇的应用场景。
封装信息:外壳材料为黑色塑料(94V-0),叶轮材料为黑色塑料(94V-0),轴承为球轴承,导线为UL1007,AWG24,红色为正,黑色为负。
3110KL-04W-B70-E00 价格&库存
很抱歉,暂时无法提供与“3110KL-04W-B70-E00”相匹配的价格&库存,您可以联系我们找货
