4715RL-07W-B79-E00
4715RL-07W-B79-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 120X38MM 48VDC WIRE
4715RL-07W-B79-E00 数据手册
4715RL (120 X 38L) NMBTC.COM / 818.341.3355 General Specifications Expected Life Motor Protection: Failure Rate: 10% 25°C 80,000 Hours (E00) Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +60°C (Operating) -40°C ~ +60°C (Storage) (non-condensing environment) Outline Characteristic Curves inch Units: (mm) P-Q Curve .197 (5.0 ) 1.49 (38.0± 0.5) Ps 4.13 (105.0± 0.5) 4.72 (120.0 ± 0.5) .197 (5.0 ) 400 1.40 350 Speed Curve 8000 7000 B80 1.20 300 1.00 250 0.80 200 0.60 150 0.40 100 2000 0.20 50 1000 0.00 0 B70 6000 B60 5000 B80 4000 B70 3000 B60 0 0. .56 LOT NO. 0 20 1.68 40 60 2.80 3.92 5.04 6.16 (m3/min) 7.28 CFM 80 100 120 140 160 180 200 220 240 260 Air Flow Panel Cut-outs Material 4.63 (117.6) 4.13 (105.0) Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG24, +Red, -Black .169 (4 – F4.3) 4 5.0 28) (F1 4.63 (117.6) 8 4.8 24) (F1 4.13 (105.0) .169 (4 – F4.3) 4.13 (105.0) 4.63 (117.6) 4.63 (117.6) 1.60 Speed Static Pressure 4.13 (105.0± 0.5) 4.72 (120.0± 0.5) NAME PLATE (Pa) 4.13 (105.0) INLET SIDE OUTLET SIDE Rated Operating Current Input Speed Max. Max. Static Noise MODEL Voltage Voltage Power Air Flow Pressure Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 4715RL-05W-B60- EXX 24 18.0 ~ 27.6 1.00 24.00 4715RL-05W-B70- EXX 24 18.0 ~ 27.6 1.50 36.00 4715RL-05W-B80- EXX 24 18.0 ~ 27.6 1.80 4715RL-07W-B60- EXX 48 40.0 ~ 55.2 4715RL-07W-B70- EXX 48 4715RL-07W-B80- EXX 48 Rotation: Clockwise DC Axial Fans .169 (8 F4.3± 0.3) AIR In H2O 11.8 min (300) ROTATION Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 5000 188.2 5.30 0.94 235 62.0 370 5600 208.0 5.80 1.18 290 65.0 370 43.20 6000 224.6 6.36 1.37 340 66.5 370 0.55 26.40 5000 188.2 5.30 0.94 235 62.0 370 40.0 ~ 55.2 0.70 33.60 5600 208.0 5.80 1.18 290 65.0 370 40.0 ~ 55.0 0.90 43.20 6000 224.6 6.36 1.37 340 66.5 370 Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air X.X
4715RL-07W-B79-E00 价格&库存
很抱歉,暂时无法提供与“4715RL-07W-B79-E00”相匹配的价格&库存,您可以联系我们找货
