电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
74ALVCH16373DGG,51
74ALVCH16373DGG,51
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    IC 16BIT D TRANSP LATCH 48TSSOP
74ALVCH16373DGG,51 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74ALVCH16373 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Rev. 6 — 10 July 2012 Product data sheet 1. General description The 74ALVCH16373 is 16-bit D-type transparent latch featuring separate D-type inputs for each latch and 3-state outputs for bus oriented applications. Incorporates bus hold data inputs which eliminate the need for external pull-up or pull-down resistors to hold unused inputs. One latch enable (LE) input and one output enable (OE) are provided per 8-bit section. The 74ALVCH16373 consists of 2 sections of eight D-type transparent latches with 3-state true outputs. When LE is HIGH, data at the nDn inputs enter the latches. In this condition the latches are transparent, therefore a latch output will change each time its corresponding D-input changes. When LE is LOW, the latches store the information that was present at the nDn inputs at a set-up time preceding the LOW-to-HIGH transition of LE. When OE is LOW, the contents of the eight latches are available at the outputs. When OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE input does not affect the state of the latches. 2. Features and benefits          Wide supply voltage range from 1.2 V to 3.6 V Complies with JEDEC standard JESD8-B CMOS low power consumption MULTIBYTE flow-through standard pin-out architecture Low inductance multiple VCC and GND pins for minimum noise and ground bounce Direct interface with TTL levels All data inputs have bus hold Output drive capability 50  transmission lines at 85 C Current drive 24 mA at VCC = 3.0 V 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 3. Ordering information Table 1. Ordering information Type number 74ALVCH16373DL Temperature range 40 C to +85 C 74ALVCH16373DGG 40 C to +85 C Package Name Description Version SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 4. Functional diagram Fig 1. 1 24 1OE 2OE 47 1D0 1Q0 2 46 1D1 1Q1 3 44 1D2 1Q2 5 43 1D3 1Q3 6 41 1D4 1Q4 8 40 1D5 1Q5 9 38 1D6 1Q6 11 37 1D7 1Q7 12 36 2D0 2Q0 13 35 2D1 2Q1 14 33 2D2 2Q2 16 32 2D3 2Q3 17 30 2D4 2Q4 19 29 2D5 2Q5 20 27 2D6 2Q6 22 26 2D7 2Q7 23 1LE 2LE 48 25 001aam007 Logic symbol 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 2 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 1OE 1LE 2OE 2LE 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 1 48 24 25 47 1EN C1 2EN C4 3D 2 1 46 3 44 5 43 6 41 8 40 9 38 11 37 12 36 4D 13 2 35 14 33 16 32 17 30 19 29 20 27 22 26 23 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 001aam009 Fig 2. IEC logic symbol VCC data input to internal circuit mna705 Fig 3. Bus hold circuit 1D0 D Q 1Q0 2D0 D Q LATCH 1 LATCH 9 LE LE LE 1LE 2LE 1OE 2OE to 7 other channels 2Q0 LE to 7 other channels 001aam010 Fig 4. Logic diagram 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 3 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 5. Pinning information 5.1 Pinning 74ALVCH16373 1OE 1 48 1LE 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 31 VCC 2Q4 19 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2LE 001aam008 Fig 5. Pin configuration 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 4 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 24 output enable input (active LOW) 1Q0 to 1Q7 2, 3, 5, 6, 8, 9, 11, 12 data outputs 2Q0 to 2Q7 13, 14, 16, 17, 19, 20, 22, 23 data outputs GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 positive supply voltage 1D0 to 1D7 47, 46, 44, 43, 41, 40, 38, 37 data inputs 2D0 to 2D7 36, 35, 33, 32, 30, 29, 27, 26 data inputs 1LE, 2LE 48, 25 latch enable input (active HIGH) 6. Functional description 6.1 Function table Table 3. Function table[1] Inputs nOE nLE Internal latches Outputs nQn Operating mode enable and read register (transparent mode) nDn L H L L L L H H H H L L l L L L L h H H latch and read register (hold mode) H L l L Z latch register and disable outputs H L h H Z [1] H = HIGH voltage level; L = LOW voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH LE transition; I = LOW voltage level one set-up time prior to the LOW-to-HIGH LE transition; Z = high-impedance OFF-state. 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 5 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0 V 50 - mA VI input voltage control inputs [1] 0.5 +4.6 V data inputs [1] 0.5 VCC + 0.5 V - 50 mA output clamping current IOK Conditions VO > VCC or VO < 0 V Min Max Unit 0.5 +4.6 V 0.5 VCC + 0.5 V - 50 mA supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation VO output voltage IO output current ICC [1] VO = 0 V to VCC Tamb = 40 C to +125 C SSOP48 package [2] - 850 mW TSSOP48 package [3] - 600 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 C the value of Ptot derates linearly with 11.3 mW/K. [3] Above 55 C the value of Ptot derates linearly with 8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage maximum speed performance VI input voltage Min Typ Max Unit CL = 30 pF 2.3 - 2.7 V CL = 50 pF 3.0 - 3.6 V low voltage applications 1.2 - 3.6 V data inputs 0 - VCC V control inputs 0 - 5.5 V 0 - VCC V 40 - +85 C VO output voltage Tamb ambient temperature t/V input transition rise and fall rate VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 74ALVCH16373 Product data sheet in free air All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 6 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C VIH VIL VOH VOL II IOZ ILIZ ICC HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current OFF-state output current VCC = 1.2 V VCC - - V VCC = 1.8 V 0.7VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 2.0 1.5 - V 0 V VCC = 1.2 V - - VCC = 1.8 V - 0.9 VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V IO = 100 A; VCC = 1.8 V to 3.6 V VCC  0.2 VCC - V IO = 6 mA; VCC = 1.8 V VCC  0.4 VCC  0.1 - V IO = 6 mA; VCC = 2.3 V VCC  0.3 VCC  0.08 - V IO = 12 mA; VCC = 2.3 V VCC  0.5 VCC  0.17 - V IO = 12 mA; VCC = 2.7 V VCC  0.5 VCC  0.14 - V IO = 18 mA; VCC = 2.3 V VCC  0.6 VCC  0.26 - V IO = 24 mA; VCC = 3.0 V VCC  1.0 VCC  0.28 - V IO = 100 A; VCC = 1.8 V to 3.6 V - 0 0.20 V IO = 6 mA; VCC = 1.8 V - 0.09 0.30 V IO = 6 mA; VCC = 2.3 V - 0.07 0.20 V VI = VIH or VIL VI = VIH or VIL IO = 12 mA; VCC = 2.3 V - 0.15 0.40 V IO = 12 mA; VCC = 2.7 V - 0.14 0.40 V IO = 18 mA; VCC = 2.3 V - 0.23 0.60 V IO = 24 mA; VCC = 3.0 V - 0.27 0.55 V control input; VI = 5.5 V or GND - 0.1 5 A data input; VI = VCC or GND - 0.1 5 A VCC = 1.8 V to 2.7 V - 0.1 5 A VCC = 2.7 V to 3.6 V - 0.1 10 A VCC = 1.8 V to 2.7 V - 0.1 10 A VCC = 3.6 V - 0.1 15 A VCC = 1.8 V to 2.7 V - 0.2 40 A VCC = 2.7 V to 3.6 V - 0.2 40 A VCC = 1.8 V to 3.6 V VI = VIH or VIL; VO = VCC or GND OFF-state input leakage current VI = VCC or GND supply current VI = VCC or GND; IO = 0 A; 74ALVCH16373 Product data sheet 0.2VCC V All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 7 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 2.7 V to 3.6 V bus hold LOW current IBHL IBHH IBHLO IBHHO bus hold HIGH current bus hold LOW overdrive current bus hold HIGH overdrive current Min Max Unit per control input - 5 500 A per data I/O input - 150 750 A VCC = 2.3 V; VI = 0.7 V [2] 45 - - A VCC = 3.0 V; VI = 0.8 V [2] 75 150 - A VCC = 2.3 V; VI = 1.7 V [2] 45 - - A VCC = 3.0 V; VI = 2.0 V [2] 75 175 - A VCC = 2.7 V [2] 300 - - A VCC = 3.6 V [2] 450 - - A VCC = 2.7 V [2] 300 - - A VCC = 3.6 V [2] 450 - - A - 5.0 - pF Max Unit input capacitance CI Typ[1] [1] All typical values are measured at Tamb = 25 C. [2] Valid for data inputs of bus hold parts only. 10. Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V); test circuit Figure 10. Symbol Parameter Conditions Min Typ[1] Tamb = 40 C to +85 C tpd propagation delay nDn to nQn; see Figure 6 [2] VCC = 1.2 V - 8.8 - ns VCC = 1.8 V 1.5 3.2 5.7 ns 1.0 2.1 3.9 ns 1.0 2.3 3.7 ns 1.0 2.1 3.3 ns - 7.4 - ns 1.5 3.4 5.9 ns VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V [4] nLE to nQn; see Figure 7 [2] VCC = 1.2 V VCC = 1.8 V VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V ten enable time VCC = 3.0 V to 3.6 V [4] nOE to nQn; see Figure 8 [2] 3.9 ns 2.2 3.5 ns 1.0 2.2 3.2 ns VCC = 1.2 V - 8.9 - ns 1.5 4.0 7.3 ns 1.0 2.6 5.2 ns 1.0 2.9 4.9 ns 1.0 2.3 4.2 ns [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V Product data sheet 2.2 VCC = 1.8 V VCC = 2.3 V to 2.7 V 74ALVCH16373 1.0 1.0 All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 [4] © NXP B.V. 2012. All rights reserved. 8 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Table 7. Dynamic characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V); test circuit Figure 10. Symbol tdis Parameter disable time Conditions nOE to nQn; see Figure 8 VCC = 1.2 V VCC = 1.8 V VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V pulse width tW [4] VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V set-up time [4] VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V hold time [4] VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V power dissipation capacitance [1] [2] - 8.9 - 1.5 3.2 5.6 ns 1.0 2.2 4.1 ns 1.0 3.1 4.7 ns 1.0 2.8 4.1 ns 3.5 1.0 - ns 3.0 1.0 - ns 3.0 1.0 - ns 2.5 1.0 - ns 1.0 0.1 - ns 1.0 0.1 - ns 1.0 0.1 - ns 1.0 0.0 - ns 1.2 0.1 - ns 1.5 0.2 - ns 1.5 0.4 - ns 1.2 0.2 - ns Unit ns nDn to nLE; see Figure 9 VCC = 1.8 V CPD Max nDn to nLE; see Figure 9 VCC = 1.8 V th Typ[1] nLE HIGH; see Figure 7 VCC = 1.8 V tsu Min [2] per flip-flop; VI = GND to VCC [4] [5] outputs enabled - 16 - pF outputs disabled - 10 - pF All typical values are measured at Tamb = 25 C. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] Typical values are measured at VCC = 2.5 V. [4] Typical values are measured at VCC = 3.3 V. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 9 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 11. Waveforms VI nDn input VM VM tPHL tPLH GND VOH nQn output VM VM VOL 001aam011 Measurement points are given in Table 8. VOL and VOH are typical output levels that occur with the output load. Fig 6. Propagation delay, input (nDn) to data output (nQn) VI nLE input VM VM VM GND tW tPHL tPLH VOH nQn output VM VM VOL 001aam012 Measurement points are given in Table 8. VOL and VOH are typical output levels that occur with the output load. Fig 7. Propagation delay, latch enable input (nLE) to data output (nQn), and pulse width VI nOE input VM VM GND tPLZ tPZL VCC nQn output LOW-to-OFF OFF-to-LOW VM VX VOL tPZH tPHZ VOH VY nQn output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled 001aal795 Measurement points are given in Table 8. VOL and VOH are typical output levels that occur with the output load. Fig 8. 3-state enable and disable times 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 10 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state VI nDn input VM GND th tsu th tsu VI nLE input VM GND 001aam013 The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 9. Table 8. Data setup and hold times for input (nDn) to input (nLE) Measurement points Supply voltage Input VCC VI Output VM VM VX VY 2.3 V to 2.7 V and < 2.3 V VCC 0.5  VCC 0.5  VCC VOL + 0.15 V VOH  0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 11 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 12. Test information VEXT VCC VI RL VO G DUT RT CL RL mna616 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 10. Load circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 2.3 V to 2.7 V and < 2.3 V VCC  2.0 ns 30 pF 500  open 2  VCC GND 2.7 V 2.7 V 2.5 ns 50 pF 500  open 2  VCC GND 3.0 V to 3.6 V 2.7 V 2.5 ns 50 pF 500  open 2  VCC GND 74ALVCH16373 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 12 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 13. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Fig 11. Package outline SOT370-1 (SSOP48) 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 13 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 E D A X c HE y v M A Z 48 25 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 detail X 24 w M bp e 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 12.6 12.4 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.8 0.4 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT362-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 12. Package outline SOT362-1 (TSSOP48) 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 14 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 14. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test TTL Transistor-Transistor Logic 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVCH16373 v.6 20120710 Product data sheet - 74ALVCH16373 v.5 - 74ALVCH16373 v.4 Modifications: 74ALVCH16373 v.5 Modifications: • Table 8 corrected (errata). 20111117 • Product data sheet Legal pages updated. 74ALVCH16373 v.4 20100531 Product data sheet - 74ALVCH16373 v.3 74ALVCH16373 v.3 19990920 Product specification - 74ALVCH16373 v.2 74ALVCH16373 v.2 19980629 Product specification - 74ALVCH16373 v.1 74ALVCH16373 v.1 19970321 Product specification - - 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 15 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74ALVCH16373 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 16 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 July 2012 © NXP B.V. 2012. All rights reserved. 17 of 18 74ALVCH16373 NXP Semiconductors 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 18. Contents 1 2 3 4 5 5.1 5.2 6 6.1 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 5 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Test information . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2012. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 10 July 2012 Document identifier: 74ALVCH16373
74ALVCH16373DGG,51 价格&库存
很抱歉,暂时无法提供与“74ALVCH16373DGG,51”相匹配的价格&库存,您可以联系我们找货
