TG6050
Ultra-Soft Thermal Conductive Pad
Version 2.130218
TG6050 is an ultra-soft, silicone based thermal interface material. TG6050 has a
low thermal impedance, conforms readily to surfaces due to its low hardness and
provides a high dielectric breakdown voltage. TG6050 can be provided in various
thicknesses and formats, such as custom die cuts, standard sheets or log rolls
depending on the end application.
Features
Superior thermal conductivity
Highly compressible
Naturally tacky
Low Shore 00 hardness
Low oil bleed
Electrically insulating
Applications
Electronic components: IC, CPU, MOS
LED, M/B, P/S, Heat Sink
LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc.
DDR II Module, DVD Applications, Hand-set applications, etc.
Properties
REACH Compliant
ROHS Compliant
Property
TG6050
Unit
Tolerance
Test Method
Colour
Red
Visual
0.5 - 5.0
mm
ASTM D374
0.0197 - 0.0787
Inch
ASTM D374
Thermal Conductivity
6
W/mK
±0.6
ASTM D5470
Flammability Rating
V-0
UL 94
Dielectric Breakdown Voltage
13
kV/mm
±1.3
ASTM D149
Weight Loss
‹1
ASTM E595
Thickness
Density
3.2
g/cm³
±0.2
ASTM D792
Working Temperature
-45 to 200
˚C
Volume Resistance
›10¹²
Ohm-cm
ASTM D257
Elongation
50
±13
ASTM D412
Tensile Strength
0.5
Kgf/cm²
±2
ASTM D412
Hardness
60
Shore 00
±15
ASTM D2240
Shelf Life
36
months
Shelf Life with adhesive
(can be requalified for further
12)
12
months
Thermal Impedance vs Pressure vs Deflection
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
Skype: tglobal.technology
VAT #: GB 116 662 714
TG6050
Standard Weights & Dimensional Tolerance
Size
Thickness
(mm)
0.50
0.80
1.00
1.50
2.00
2.50
3.00
3.50
4.00
4.50
5.00
100x100
16.00
25.60
32.00
48.00
64.00
80.00
96.00
112.00
128.00
144.00
160.00
150x150
36.00
57.60
72.00
108.00 144.00 180.00 216.00
252.00
288.00
324.00
360.00
300x300
144.00 230.40 288.00 432.00 576.00 720.00 864.00 1,008.00 1,152.00 1,296.00 1,440.00
320x320
163.84 262.14 327.68 491.52 655.36 819.20 983.04 1,146.88 1,310.72 1,474.56 1,638.40
* All measurements in mm
Die-Cut
Thickness
Tolerances
Thickness (mm)
Tolerance (mm)
0.3
±0.03
0.5
±0.05
0.8
±0.08
1.0
±0.1
1.2
±0.12
1.5
±0.15
2.0
±0.2
2.5 - 3.5
±0.25
4.0 - 4.5
±0.3
5.0
±0.35
6.0 - 8.0
±0.4
9.0
±0.45
10.0
±0.5
>10.0
±0.5
Data
* Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application.
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our
control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the
suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation,
or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are
assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing or future patents covering any product or material or its use.
Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
很抱歉,暂时无法提供与“TG6050-24-21.01-1”相匹配的价格&库存,您可以联系我们找货
