PC93
Non-Silicone Thermal Conductive Pad
Version 2.160819
PC93 is a soft, non-silicone thermal interface pad designed to replace traditional
thermal pads in silicone-sensitive applications. Typical uses include, set-top boxes,
optical and automotive projects. PC93 can be provided in a range of different
thicknesses and formats depending on the end use.
Features
Low contact thermal impedance
Good thermal conductivity
Silicone free
Long term stability
Applications
Electronic components: IC, CPU, MOS
LED, M/B, P/S, Heat Sink
LCD TV, Notebook PC, PC Telecom Device, Wireless Hub, etc.
DDR II Module, DVD Applications, Hand-set applications, etc.
Properties
REACH Compliant
ROHS Compliant
Property
PC93
Unit
Tolerance
Colour
Grey
Visual
Thickness (Available thickness range)
0.50 - 5.0
mm
ASTM D374
0.0197 - 0.1969
inch
ASTM D374
Thermal Conductivity
2.1
W/mK
± 10%
ASTM D5470
Flammability Rating
V-0
UL 94
Dielectric Breakdown Voltage
10.2
kV/mm
±1
ASTM D149
Weight Loss
‹1
ASTM E595
Density
2.1
g/cm³
± 0.2
ASTM D792
Working Temperature
-30 to +125
˚C
Volume Resistance
›10
Ohm-cm
ASTM D257
Elongation
350
ASTM D412
Tensile Strength
1
Kgf/mm²
ASTM D412
Hardness
55
Shore 00
± 10
ASTM D2240
10
Thermal Impedance vs Pressure vs Deflection
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
VAT #: GB 116 662 714
Test Method
Pressure (psi)
R(°C-in²/W)
Deflection (%)
10
1.01
16
32
40
0.74
43
PC93
Standard Weights & Dimensional Tolerance
Size
Thickness
(mm)
0.50
0.80
1.00
1.50
2.00
2.50
3.00
3.50
4.00
4.50
5.00
100x100
10.50
16.80
21.00
31.50
42.00
52.50
63.00
73.50
84.00
94.50
105.00
150x150
23.63
37.80
47.25
70.88
94.50
118.13
141.75
165.38
189.00
212.63
236.25
300x300
94.50
151.20
189.00
283.50
378.00
472.50
567.00
661.50
756.00
850.50
945.00
320x320
107.52
172.03
215.04
322.56
430.08
537.60
645.12
752.64
860.16
967.68
1,075.20
* All measurements in mm
Die-Cut
Thickness
Tolerances
Thickness (mm)
Tolerance (mm)
0.3
±0.03
0.5
±0.05
0.8
±0.08
1.0
±0.1
1.2
±0.12
1.5
±0.15
2.0
±0.2
2.5 - 3.5
±0.25
4.0 - 4.5
±0.3
5.0
±0.35
6.0 - 8.0
±0.4
9.0
±0.45
10.0
±0.5
>10.0
±0.5
* Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application.
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our
control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the
suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation,
or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are
assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing or future patents covering any product or material or its use.
Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com
很抱歉,暂时无法提供与“PC93-20-10-0.25”相匹配的价格&库存,您可以联系我们找货
