Li98
Thermal Tape
Version 4.05122019
Thermal Tape
Li98 thermal tapes are double-sided thermal interface tapes and provide exceptional
bonding properties between electronic components and heat sinks, eliminating the
need for mechanical fasteners. Li98 can be offered in various formats such as sheets,
rolls and die cut parts depending on the applications and have proven reliability
under various mechanical, thermal, and environmental stresses.
Features
Good adhesion (Acrylic PSA)
Great reliability
Cost effective with great performance
Easy to assemble
Applications
Electronic components: IC, CPU, MOS
LED, M/B, P/S, Heat Sink
LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc.
DDR II Module, DVD Applications, Hand-set applications, etc.
Properties
REACH Compliant
ROHS Compliant
Property
Li98
Li98C
Colour
Liner Colour
Thickness
Thermal Conductivity
Unit
Tolerance
Test Method
Visual
Green
Red
0.15
0.25
0.15
0.25
0.18
mm
ASTM D374
0.0059
0.00984
0.0059
0.00984
0.00709
inch
ASTM D374
0.95
0.95
1.8
1.8
2
W/mK
±0.10%
ASTM
D5470
°C
Continuous Working Temperature
White
-30 to 120
Short Time Using Temperature
200
Density
Tensile Strength
Li98CN
White
1.85
200
Glass Transition Temperature
1.8
400
200
-30
400
-27
°C
g/cm3
±1.3
ASTM D792
psi
ASTM D412
-30
°C
Initial Tack
10
8
14
12
15
cm
PSTC-6
Lap Shear Strength
61
55
55
50
55
N/cm2
ASTM
D1002
Die Shear Strength 25 °C
120
109
109
100
100
N/cm2
±0.2
Die Shear Strength 80 °C
69
68
55
N/cm2
Holding Power 1000g 25 °C
68
>10000
Holding Power 1000g 80 °C
min
PSTC-7
min
PSTC-7
90° Peeling Strength
>10
>12
>6
>8
>8
N/in
ASTM
D3330
Dielectric Breakdown Voltage
(AC)
2
3
2
3
5
kV
±0.10%
ASTM D149
(DC)
3
4
3
4
6
kV
±0.10%
ASTM D149
Reinforcement Carrier
Fiberglass Mesh
Shelf Life
(can be requalified for further 12)
12
months
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
Skype: tglobal.technology
VAT #: GB 116 662 714
Thermal Impedance vs Pressure vs Deflection
Li98
Thermal Tape
Standard Weights & Dimensional Tolerance
Thickness (mm)
Tolerance (mm)
0.3
±0.03
0.5
±0.05
0.25
0.8
±0.08
Weights (g)
Size
Thickness (mm)
0.15
100x100
2.78
4.63
1.0
±0.1
150x150
6.24
10.41
1.2
±0.12
300x300
24.98
41.63
1.5
±0.15
320x320
28.42
47.36
2.0
±0.2
2.5 - 3.5
±0.25
Die-Cut
Thickness
Tolerances
Data
4.0 - 4.5
±0.3
±0.35
Digi-Key Part
T-Global Part
5.0
1168-1715-ND
LP0001/01-Li98-0.15
6.0 - 8.0
±0.4
1168-1908-ND
LP0007/01-Li98-0.25
9.0
±0.45
1168-1867-ND
LP0003/01-Li98-0.25
10.0
±0.5
1168-1845-ND
TG-CPCB1-Li98-0.15
>10.0
±0.5
1168-1843-ND
TG-CPCB2-Li98-0.15
1168-1841-ND
TG-CPCB3-Li98-0.15
1168-1847-ND
LP0001/01-Li98-0.25
1168-1857-ND
LP0002/01-Li98-0.25
1168-1907-ND
LP0007/01-Li98-0.15
1168-1763-ND
LP0003/01-Li98-0.15
1168-1718-ND
LP0002/01-Li98-0.15
1168-1766-ND
LP0004/01-Li98-0.15
1168-1769-ND
LP0005/01-Li98-0.15
1168-1877-ND
LP0004/01-Li98-0.25
1168-1772-ND
LP0006/01-Li98-0.15
1168-1887-ND
LP0005/01-Li98-0.25
1168-1897-ND
LP0006/01-Li98-0.25
Digi-Key Part
T-Global Part
1168-1715-ND
LP0001/01-Li98-0.15
1168-1908-ND
LP0007/01-Li98-0.25
1168-1867-ND
LP0003/01-Li98-0.25
1168-1845-ND
TG-CPCB1-Li98-0.15
1168-1843-ND
TG-CPCB2-Li98-0.15
1168-1841-ND
TG-CPCB3-Li98-0.15
Thickness
Material
0.0007”
Acrylic
(0.178mm) Elastomer
Adhesive
Backing
Carrier
Thermal
Conductivity
Both
sides
Fiberglass
2.0 W/m-K
* Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application.
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our
control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the
suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation,
or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are
assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing or future patents covering any product or material or its use.
Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
LI98-150-150-0.15-0 价格&库存
很抱歉,暂时无法提供与“LI98-150-150-0.15-0”相匹配的价格&库存,您可以联系我们找货
