H48-2-5.5-5-3.2-1A
H48-2-5.5-5-3.2-1A
    T-GLOBAL
    H48-25.5X5X3.2MMW/ADH
H48-2-5.5-5-3.2-1A 数据手册
H48-2 Thermal Conductive Pad Version 3.140318 Thermal Conductive Pad H48-2 is a silicone based thermal pad which has been designed for both efficient heat transfer away from critical devices and ease of manufacture. H48-2 can be provided in a range of formats and thicknesses, such as standard sheets, rolls or die cuts. Additionally, H48-2 may be provided with either one of two sided adhesive to further facilitate manufacturing processes. Features Good thermal conductivity Ultra-soft and high compressibility Natural tack Easy to assemble Good insulator Shock and vibration absorber Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property H48-2 Unit Tolerance Test Method Colour Dark Red - - Visual Thickness (Available thickness range) 0.1 - 10 mm - ASTM D374 0.012 - 0.7874 inch - ASTM D374 Thermal Conductivity 2.2 W/mK ±0.22 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 5 kV/mm ±0.5 ASTM D149 Weight Loss 1011 Ohmcm - ASTM D257 Elongation 282 % - ASTM D412 Tensile Strength 7 Kgf/cm ±2 ASTM D412 Hardness 25 Shore A ±2.5 ASTM D2240 Shelf Life 36 months - - Shelf Life with adhesive (can be requalified for a further 12) 12 months - - 3 Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 2 H48-2 Thermal Conductive Pad Standard Weights & Dimensional Tolerance Size 0.10 0.20 0.30 0.50 0.80 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 100x100 2.43 4.86 7.29 12.15 19.44 24.30 36.45 48.60 60.75 72.90 85.05 97.20 109.35 150x150 5.47 10.94 16.40 27.34 43.74 54.68 82.01 109.35 136.69 164.03 191.36 218.70 246.04 300x300 21.87 43.74 65.61 109.35 174.96 218.70 328.05 437.40 546.75 656.10 765.45 874.80 984.15 320x320 24.88 49.77 74.65 124.42 199.07 248.83 373.25 497.66 622.08 746.50 870.91 995.33 1,119.74 7.50 8.00 8.50 9.00 9.50 10.00 Thickness (mm) Size Weights (g) Thickness (mm) 5.00 5.50 6.00 6.50 7.00 100x100 121.50 133.65 145.80 157.95 170.10 182.25 194.40 206.55 218.70 230.85 243.00 150x150 273.38 300.71 328.05 355.39 382.73 410.06 437.40 464.74 492.08 519.41 546.75 300x300 1,093.50 1,202.85 1,312.20 1,421.55 1,530.90 1,640.25 1,749.60 1,858.95 1,968.30 2,077.65 2,187.00 320x320 1,244.16 1,368.58 1,492.99 1,617.41 1,741.82 1,866.24 1,990.66 2,115.07 2,239.49 2,363.90 2,488.32 Data Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
H48-2-5.5-5-3.2-1A
物料型号:H48-2 Thermal Conductive Pad
器件简介:H48-2是一种基于硅的热垫,设计用于高效地从关键设备转移热量,同时便于制造。它可以提供标准片材、卷材或模切形式,厚度范围从0.1到10毫米,并可选择单双面胶带。
引脚分配:文档中未提及引脚分配,因为H48-2是一种热导垫,不是电子元件。
参数特性: - 颜色:深红色 - 厚度:0.1-10毫米或0.012-0.7874英寸 - 热导率:2.2 W/mK,公差±0.22 - 阻燃等级:V-0 - 介电强度:5 KV/mm,公差±0.5 - 重量损失:<1% - 密度:2.43 g/cm²,公差±0.2 - 工作温度范围:-40至200摄氏度 - 体积电阻:>10^11 Ohm-cm - 伸长率:282% - 拉伸强度:7 Kgf/cm²,公差±2 - 硬度:25 Shore A,公差±2.5 - 保质期:36个月,带胶带的保质期为12个月,可重新认证延长12个月
功能详解:H48-2具有良好的热导性、超软性、高压缩性、天然粘性、易于组装、良好的绝缘性、以及作为震动和冲击吸收器。
应用信息:适用于电子元件(如IC、CPU、MOS)、LED、主板、电源、散热器、LCD、电视、笔记本电脑、个人电脑、电信设备、无线设备等。
封装信息:提供了不同尺寸和厚度的标准重量和尺寸公差表,以及模切件的公差信息。
H48-2-5.5-5-3.2-1A 价格&库存
很抱歉,暂时无法提供与“H48-2-5.5-5-3.2-1A”相匹配的价格&库存,您可以联系我们找货
