175-6-330P
175-6-330P
    WAKEFIELD-VETTE
    THERMALPAD
175-6-330P 数据手册
THERMAL INTERFACE PRODUCTS Thermal Compounds, Adhesives & Interface Materials ...... 140–145 High Performance Thermal Compound ........................... 140 General & Thermal High Performance Epoxy .................... 146–155 performance of both standard and custom heat dissipation components. Included are thermal joint compounds; filled epoxy systems; adhesives; thermally conductive insulating wafers, washers, pads and mounting hardware. THERMAL INTERFACE PRODUCTS Cost-effective accessory products that facilitate installation and improve the thermal THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS THERMAL COMPOUNDS, ADHESIVES & INTERFACE MATERIALS THERMAL COMPOUNDS, ADHESIVES & INTERFACE MATERIALS 120 SERIES 126 SERIES The 120 Series Silicone Oil-Based Thermal Joint Compound fills the minute air gap between mating surfaces with a grease-like material containing zinc oxide in a silicone oil carrier. It possesses an excellent thermal resistance of only 0.05°C/W for a 0.001 in. film with an area of one square inch. There is no measurable increase in case temperature of a mounted semiconductor on a heat sink after the 6-month stabilization period (Time versus Thermal Resistivity graph below). 120 SERIES - THERMAL JOINT COMPOUND TYPICAL VALUES FOR THERMAL RESISTANCE, CASE TO SINK (Øcs) WHEN THERMAL JOINT COMPOUNDS ARE USED Case Style Characteristics Mounting Torque in inch • pounds (N•M) TO-3 8 (0.9) TO-66 9 (0.9) TO-220 8 (0.9) 0.19 (4.8) stud x 0.44 (11.2) hex 15 (1.7) 0.25 (6.4) stud x 0.69 (17.5) hex 30 (3.39) 0.38 (9.7) stud x 1.06 (26.9) hex 75 (8.47) 0.50 (12.7) stud x 1.06 (26.9) hex 125 (14.12) 0.75 (19.1) stud x 1.25 (31.8) hex 600 (67.79) Characteristic Typical Thermal Resistance (°C/W) 0.09 0.14 0.50 0.16 0.10 0.07 0.07 0.052 Volume Resistivity Dielectric Strength Specific Gravity Thermal Conductivity @ 36°C Thermal Resistivity (P) Bleed, % after 24 hrs @ 200°C Evaporation, % after 24 hrs @ 200°C Color Shelf life Operating Temperature Range (°C) Description 5 X 1014 ohm-cm 225 volts/mil 2.1 min. 0.735 W/(m)(K) 5.1(Btu) (in.)/(hr)(ft2)(°F) 56 (°C)(in.)/watt 0.5 0.5 opaque white 5 years -40/+200 The 126 Series is a nontoxic, synthetic, ester-based (nonsilicone) Thermal Joint Compound with metal oxide fillers designed to enhance thermal performance characteristics of plastic and metal package devices exceeding that of silicone-based compounds. Solved are problems associated with contamination of wave solder baths and migration of silicone-based products. Shelf life: 5 years. 126 SERIES THERMAL JOINT COMPOUND Characteristics Description Appearance Solids Content, wt % Thermal Conductivity at 36°C Interface Thermal Resistance Bleed, 24 hrs at 200°C, wt% Evaporation, 24 hrs at 200°C, wt% Volume Resistivity Dielectric Strength Specific Gravity @ 60°F Penetration Operating Range 120-SA 120-2 120-5 120-8 120-80 120-320 HIGH PERFORMANCE THERMAL COMPOUND 122 SERIES 122 Series Thermal Joint Compound is a stable, silicone based, thixotropic paste developed to provide premium performance at an affordable price. It is formulated to significantly reduce contact thermal resistance where power densities are concentrated in devices such as flip chip, reduced die size, and ‘overclock’ microprocessors. When applied as a thin film between a Wakefield-Vette heat sink and device it possesses superior thermal conductivity compared to traditional ‘grease’. It is compatible with automated or manual dispensing methods and is fully RoHS compliant. 122 SERIES THERMAL JOINT COMPOUND 122 SERIES - ORDER GUIDE Typical Characteristics Series - P/N Container Size 122-10CC 122-2 122-30CC 10cc syringe 2 oz (0.06 kg) jar 30cc syringe 140 Smooth Gray paste 2.5 W / m °K, 17.3 (Btu) (in.)/(hr) (ft2) (°F) 0.02 °C in 2 / W 0.015 wt%, 24 hrs at 200°C 0.150 wt%, 24 hrs at 200°C 1.4 x 1010 ohm-cm 225 volts/mil 2.23 (gm/cc) at 25°C -40°C to 205°C 5 years 126-2 126-4 126-4S 126-5LB Container Size 2 oz (0.6 kg) jar 4 oz (0.11 kg) tube 4 oz (0.11 kg) syringe 5 lb (2.27 kg) can DELTABOND™152 DELTABOND™ 152 Appearance Thermal Conductivity Thermal Resistance Bleed Evaporation Volume Resistivity Dielectric Strength Specific Gravity Operating Range Shelf Life Series - P/N DeltaBond™ 152 adhesive is ideal for general cementing; thermally bonding semiconductors and components to chassis or heat sinks, while electrically isolating one from the other; fabricating heat sinks or thermal links; and for all permanent bonding of assemblies which require high thermally conductive interfaces. It produces a rigid, high strength bond to most materials when cured. DeltaBond™ 152 is available in bi-packs, kits, and quarts. Order one bottle of hardener A-4 or B-4 per one quart of DeltaBond™ 152 separately. Shelf life: 152KA 1 year, all others 2 years. Container Size 4 gram plastic pak 2 oz (0.06 kg) jar 5 oz (0.14 kg) tube 8 oz (0.23 kg) jar 5 lb (2.27 kg) can 20 lb (9.08 kg) can Description 126 SERIES - ORDER GUIDE DELTABOND™ 152 120 SERIES - ORDER GUIDE Series - P/N Smooth, white homogeneous paste 65% min .69 W / m 0K, 4.8 (Btu)(in.)/(hr) (ft2) (°F) 0.043°C/W TO-3 at 0.0008 thick film 0.09% max 0.6 max 2.3 x 1012 ohms-cm 200 volts/mil 2.93 (gm/cc) 280 to 320 -40°C to 200°C Characteristics Hardener Type Mixing Proportions and Working Properties Typical Properties Fully Cured A4 Characteristics B4 Thermal conductivity - W/(m) (°K) 0.836 0.908 (Btu) (in.)/(hr) (ft2) (°F) 5.8 6.3 Thermal resistivity - (°C) (in.) watt 47 42 Bond shear strength 77°F 2,900 2,300 1 in. overlap - psi 125°F 2,200 2,000 etched aluminum to etched aluminum 212°F 400 800 Heat distortion point - °F 130 225 Minimum dielectric strength, v/mil, 0.125 in. sample 400 400 Max operation Continuous 65 150 temp - °C Intermittent 100 190 NOTES: A4 Parts of hardener per 100 parts of resin by weight 7.5 *Working Time - at 77°F 45 min †Initial cure time 77°F 8 hrs 150°F 45 min 250°F 20 min ‡Post-cure time at a temp in °F 4 hrs @200°F ‡Alternate room temp. aging 4 days time at 77°F Working consistency (77°F) viscous liquid Working viscosity (77°F) cps 25,000 B4 3.5 30 min 6 hrs 30 min 15 min 4 hrs @ 200°F 4 days paste — DELTABOND™152 Ordering Guide - Resin and Hardener * Since the hardener/resin reaction is Resin Hardener Model exothermic, it is important that batch Number P art No. Container Part Number |size be matched to hardener speed. Working times given are for approximate 152-1A Bi-Pack (1 oz) Included in PIN 152-1 A (“A-4”) Type batch sizes: A—200 gms, B—200 gms. DeltaBond™ 152 152-1B Bi-Pack (1 oz) Included in P/N 152-1 B (“B-4”) Type Larger batch sizes will greatly reduce 152-KA Kit (7 oz Resin, 0.5 oz Hardener) lncluded in P/N 152-KA working time. 1 52-Q 1 quart (4 lbs) A-4 (0.316 lb), B-4 (0.14 lb), (order 1 only) ** For optimum electrical properties, dry All hardener part numbers: A-4, B-4 parts for 15 minutes at 150°F (65°C) or 30 minutes at 75°F (24°C) to slowly evaporate the thinner and then final cure for 4 hours at 275°F (135°C). † After initial cure, material may be handled, removed from fixture, etc., but has not yet achieved full properties and should be room temperature aged or post-cured as shown to achieve full physical and electrical properties. ‡ After initial cure, material may be brought to full physical and electrical properties during post-cure or may be room temperature aged for charted length of time to achieve same full properties. The information contained herein is based on data believed to be reliable but we do not assume responsibility for accuracy. All such information is used at the customer’s own risk, conditions of use being beyond our control. 141 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS THERMAL COMPOUNDS, ADHESIVES & INTERFACE MATERIALS DELTABOND™ 154 DELTABOND™ 153 DeltaCast™ 153 is a pourable casting resin having thermal expansion characteristics similar to aluminum and copper allowing assemblies to operate over a very wide temperature range. Ideal for encapsulating components and assemblies, this series’ major advantages and uses include potted systems (virtually indestructible), protecting components and systems from moisture and contaminants, securing proprietary circuitry, mechanical support of devices, removal of heat from hot components and the assembly equalizing temperatures, and high voltage isolation. DeltaCast™ 153 is available in quarts and gallons. Order one bottle of hardener A4 or B4 per one quart of DeltaCast™ 153 separately. Shelf life: 2 years. DELTACAST™153 DELTABOND™154 Ordering Guide - Resin and Hardener Model Part No. Number DeltaBond™ Resin 154-Q 1 Hardener Type Typical Properties Fully Cured A4 Thermal conductivity - W/(m) (°K) 0.836 (Btu) (in.)/(hr) (ft2) (°F) 5.8 Thermal resistivity - (°C) (in.) watt 47 Bond shear strength 77°F 2,500 1 in. overlap - psi 125°F — etched aluminum to etched aluminum 212°F — Heat distortion point - °F 130 Minimum dielectric strength, v/mil, 0.125 in. sample 400 Max operation Continuous 65 temp - °C Intermittent 100 Part Number A-4 (0.316 lb), B-4 (0.14 lb), (order 1 only) All hardener part numbers: A-4, B-4 Mixing Proportions and Working Properties B4 Characteristics A4 Parts of hardener per 100 parts 7.5 of resin by weight *Working Time - at 77°F 45 min † Initial cure time 77°F 8 hrs 150°F 45 min 250°F 20 min ‡Post-cure time at a temp in °F 4 hrs @200°F ‡Alternate room temp. aging 4 days time at 77°F Working consistency (77°F) heavy liquid Working viscosity (77°F) cps 10,000 0.908 6.3 42 1,900 — — 225 400 150 190 B4 DELTABOND™ 155 3.5 30 min 6 hrs 30 min 15 min 4 hrs @ 200°F 4 days DeItaBond™ 155 is an epoxy adhesive formulated for use within the semiconductor industry. An easy to mix spread thixotropic paste, it offers high heat transfer, low shrinkage, and a coefficient of thermal expansion comparable to that of copper and aluminum. This adhesive is principally used to form thermally conductive joints in fabricated heat sinks and between heat sinks and power devices. When used to bond semiconductors to heat sinks, it also serves as an electrical insulator. Its strong bond to a wide variety of substrates resists severe temperature cycling. DeItaBond™ 155 is only available in kit size. Simply squeeze out equal lengths and mix to uniform color. Shelf life: 1 year. viscous liquid 30,000 DELTABOND™ 155 Characteristics Typical Properties Fully Cured DELTACAST™153 DeltaCast™ 153 153-Q Hardener Part Number 1 quart (4 lbs) A-4 (0.316 lb), B-4 (0.14 lb), (order 1 only) All hardener part numbers: A-4, B-4 DELTABOND™ 154 DeltaBond™ 154 is a medium viscosity, aluminum-filled resin with the best thermal conductivity of this series.It is, however, neither a good electrical insulator nor conductor. Its principal application is that of a good thermal mechanical adhesive for applications such as bonding fins to base plates or structural mounting blocks or brackets to heat sinks. Order one bottle of hardener A4 or B4 per one quart of DeltaBond™ 154 separately. Shelf life: 2 years. Characteristics Mixing Proportions and Working Properties A4 B4 Parts of hardener per 100 parts of resin by weight 11.0 4.5 *Working Time - at 77°F 45 min 30 min † Initial cure time 77°F 8 hrs 6 hrs 150°F 45 min 30 min 250°F 20 min 15 min ‡Post-cure time at a temp in °F 4 hrs @200°F 4 hrs @ 200°F ‡Alternate room temp. aging 4 days 4 days time at 77°F Working consistency (77°F) viscous liquid paste Working viscosity (77°F) cps 25,000 — 0.836 5.8 47 2,600 — — 130 400 65 100 DELTABOND™ 155 Mixing Proportions and Working Properties Parts of hardener per 100 parts of resin *Working Time - at 77°F †Initial cure time 77°F 150°F 250°F ‡Post-cure time at a temp in °F ‡Alternate room temp. aging time at 77°F Working consistency (77°F) Working viscosity (77°F) cps DELTABOND™ 155 Model Number Resin Part No. Hardener Container Part Number (3 oz resin, 3 oz hardener) Included in P/N 155 Hardener Type Typical Properties Fully Cured A4 4 days paste paste * Since the hardener/resin reaction is exothermic, it is important that batch size be matched to hardener speed. Working times given are for approximate batch sizes: A—200 gms, B—200 gms. Larger batch sizes will greatly reduce working time. † After initial cure, material may be handled, removed from fixture, etc., but has not yet achieved full properties and should be room temperature aged or post-cured as shown to achieve full physical and electrical properties. B4 Thermal conductivity - W/(m) (°K) 1.053 1.154 (Btu) (in.)/(hr) (ft2) (°F) 7.3 8.0 Thermal resistivity - (°C) (in.) watt 37 34 Bond shear strength 77°F 3,000 2,400 1 in. overlap - psi 125°F 2,300 2,100 etched aluminum to etched aluminum 212°F 500 800 Heat distortion point - °F 130 225 Minimum dielectric strength, v/mil, 0.125 in. sample NA* NA* Max operation Continuous 65 150 temp - °C Intermittent 100 190 wakefield-vette.com by volume 100 90 min 8 hrs 45 min 20 min 4 hrs @ 200°F NOTES: Ordering Guide - Resin and Hardener DeltaBond™ 155 155 Kit DELTABOND™ 154 DELTABOND™ 154 Hardener Type DeltaBond™155 Thermal conductivity - W/(m) (°K) (Btu) (in.)/(hr) (ft2) (°F) Thermal resistivity - (°C) (in.) watt Bond shear strength 77°F 1 in. overlap - psi 125°F etched aluminum to etched aluminum 212°F Heat distortion point - °F Minimum dielectric strength, v/mil, 0.125 in. sample Max operation Continuous temp - °C Intermittent Ordering Guide - Resin and Hardener Resin Model Part No. Container Number 142 quart (2.5 lbs) DELTACAST™153 Characteristics Characteristics Hardener Container ‡ After initial cure, material may be brought to full physical and electrical properties during post-cure or may be room temperature aged for charted length of time to achieve same full properties. The information contained herein is based on data believed to be reliable but we do not assume responsibility for accuracy. All such information is used at the customer’s own risk, conditions of use being beyond our control. Contact us: (603) 635-2800 143 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS THERMAL COMPOUNDS, ADHESIVES & INTERFACE MATERIALS DELTABOND™ 156 DeltaBond™ 156 Thermally Conductive Adhesive is a modified acrylic adhesive designed for permanent mounting on components where heat must be effectively transmitted. Recommended for electromechanical assemblies to bond components and dissipate heat, it replaces mechanical fasteners and compressible pads, silicone grease, and epoxies; eliminates air entrapment, and other variables related to epoxy mixing. This soft paste requires no mixing and flows easily to allow thin bond lines. Primer activated, cure begins upon assembly. DeltaBond™ Activator fixtures at room temperature in less than 5 minutes. Full strength is developed in 4 to 12 hours and fillets become dry to the touch in 24 hours. It is not recommended to use this durable adhesive without the use of DeltaBond™ Activator. DeltaBond™ 156 is available in kit size; order 156-K (25 ml Syringe and Activator Kit). Shelf life: 1 year. DELTABOND™ 156 DELTABOND™ 156 Characteristics Typical Electrical Properties Typical Properties Fully Cured Test Description Results Test ASTM Temperature Range -65 to 300°F (-54 to 149°C) 300°F to (177°C) Intermittent Tensile Strength, at break 2360 psi Modulus 233,000 psi Elongation, at break 7.75% Outgassing 2.5% TLM 0.05% CVCM Coefficient of Thermal Expansion 7.1 x 10 -4 (cm/cm°C) Tensile Shear 2500psi Thermal Conductivity, K 3.47 Btu x in./hr ft2 °F (absolute at 86°F (30°C) (0.50 W/m °C) D638 D638 D638 E595 D1002 Note: The absolute thermal conductivity test was developed specifi­cally for measuring thermal properties of thin film adhesive bonds. Results Dielectric Strength 220 volts/mil Dielectric Constant, 77°F (25°C) 100 Hz 14.92 1000 Hz 14.26 1MM Hz 12.34 Dissipaton Factor, 77°F (25°C) 100 Hz 0.05 1000 Hz 0.03 1MM Hz 0.06 Volume Resistivity 5.2x1011 (ohms-cm) Surface Resistivity 8.6 x 1013 (ohms) ASTM D149 D150 Characteristics Material Thickness Color Tear Strength, lb/in. Typical100 Volume Resistivity, megohm-cm, Minimum Normal Breakdown Voltage, Minimum Dielectric Constant at 60 Hz and 100 V Maximum Continuous Use Temperature, °C Thermal Conductivity, cal/cm sec. °C, Minimum Thermal Resistance (TO-3), 1 in.2 °C/W Recommended Mounting Pressure, lb/in.2 DeltaBond™ 156 156-K Container Resin Kit Hardener Syringe - 0.85 fl oz - 25 ml - 2 oz net/0.44 oz fl contents bottle -12ml DeltaPads™ 173-7 Series DeltaPads™ 173-9 Series DeltaPads™ 174-9 Series Kapton® 175-6 Series 0.007 in. Gray 100 1.0 x 109 4,000 2.70 -60/+200 3 x 10-3 0.33 350/550 0.009 in. Gray 100 1.0 x 109 5,000 2.40 -60/+200 3 x 10-3 0.50 350/550 0.009 in. Tan 100 1.0 x 1013 5,000 2.50 -60/+200 1 x 10-2 0.25 350/550 0.006 in. Gray ASTM 0624 1 x 1013 6,000 5.5 @ 1,000 Hz -60/+200 1.2 x 10-3 0.40 350/550 Test Method Micrometer Visual ASTM D257 ASTM 0149 ASTM D 150 – – – Formula* D150 *P (pressure in psi) = D257 D257 T (torque [in.- lb] x N (number of fasteners) 0.2 x D (Thread Dia) x A (contact surface area square inches) 173-7 Series Ordering Guide - Resin and Hardener Part No. 175 SERIES The 173, 174, and 175 Series are highly efficient thermally conductive insulators designed for semiconductor interface to heat sinks. Their properties eliminate messy concerns associated with thermal greases. Note: DeltaBond™ Thermally Conductive Adhesive-High Strength contains a metallic filler which, in certain applications, may have an effect on electrical properties. Therefore, test each particular application to ensure that electrical properties are as required. Resin 173 & 174 SERIES GREASELESS THERMALLY CONDUCTIVE KAPTON® REINFORCED INSULATORS DELTABOND™ 156 Model Number DELTAPADS™ THERMALLY CONDUCTIVE INSULATORS TO-3, TO-66, TO-220,DO-4, DO-5 SHEET Hardener Part Number Included in kit hardener with brush applicator 4.2 oz total wt/kt 173-9 Series 174-9 Series No Adhesive Adhesive Backing No Adhesive No Adhesive 175-6 Series Greaseless – 173-7-220P 173-7-230P 173-7-240P – – – – – – – 173-7-1212P – – – 173-7-240A – ­– ­– – – – – – 173-9-210P – 173-9-230P 173-9-240P – – – – – – – 173-9-1212P – – – – – – 174-9-310P – – – – 174-9-1212P 175-6-210P 175-6-220P 175-6-230P 175-6-240P 175-6-250P 175-6-280P 175-6-310P 175-6-320P 175-6-330P 175-6-410P 175-6-610P – MECHANICAL DIMENSIONS NOTES: * Since the hardener/resin reaction is exothermic, it is important that batch size be matched to hardener speed. Working times given are for approximate batch sizes: A—200 gms, B—200 gms. Larger batch sizes will greatly reduce working time. † After initial cure, material may be handled, removed from fixture, etc., but has not yet achieved full properties and should be room temperature aged or post-cured as shown to achieve full physical and electrical properties. TO-66 TO-3 TO-220 D04/05 ‡ After initial cure, material may be brought to full physical and electrical properties during post-cure or may be room temperature aged for charted length of time to achieve same full properties. The information contained herein is based on data believed to be reliable but we do not assume responsibility for accuracy. All such information is used at the customer’s own risk, conditions of use being beyond our control. 144 wakefield-vette.com SHEET Dimensions: in. (mm) TO-5 DUAL TO-220 Contact us: (603) 635-2800 TO-66 (RECTANGLE) 145 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS GENERAL & THERMAL HIGH PERFORMANCE EPOXY BONDATHERM™ BONDATHERM™ CARTRIDGES KEY FEATURES OF THE BONDATHERM EQUALIZER KITS: • • • • • • Wakefield-Vette Part Number FEATURES • • • • • • • Eliminates improper ratios and mixing errors Reduces material waste Eliminates employee contact with resins Eliminates messy hand mixing and transferring Increases productivity  Resins are protected from moisture contamination Description Packaging BT-101-50M BT-102-50M BT-301-50M BT-301-200M Non-Sag 5 Minute BondaTherm Epoxy Adhesive Toughened, Flexible Adhesive System Fast Curing Thermally Conductive Adhesive Fast Curing Thermally Conductive Adhesive 50ml Dual Catridges 50ml Dual Catridges 50ml Dual Catridges 200ml Dual Catridges BT-01-50M BT-01-200M BT-02-50M BT-02-200M BondaTherm Equalizer Dispense Gun (50ml) BondaTherm Equalizer Dispense Gun (200ml) BondaTherm Equalizer Static Mixer (50ml) BondaTherm Equalizer Static Mixer (200ml) - BT-101-50M-EQZ BT-102-50M-EQZ BT-301-50M-EQZ BT-301-200M-EQZ Two Dual Cartridges (BT-101-50M), One Gun (BT-01-50M), Three Mixers (BT-02-50M) Two Dual Cartridges (BT-102-50M), One Gun (BT-01-50M), Three Mixers (BT-02-50M) Two Dual Cartridges (BT-301-50M), One Gun (BT-01-50M), Three Mixers (BT-02-50M) Two Dual Cartridges (BT-301-200M), One Gun (BT-01-200M), Three Mixers (BT-02-200M) Kit Kit Kit Kit BT-103-50M BT-302-50M 5 Minute Clear Bondatherm Epoxy Adhesive Fast Curing Aluminum Filled Bondatherm Epoxy Adhesive 50ml Dual Catridges 50ml Dual Catridges BT-401-H BT-402-H BT-403-H Silver Filled Bondatherm 2 gram Epoxy Hinge Packs Thermally Conductive Epoxy Potting UL Listed 100 gram Bondatherm Hinge Pack Aluminum Filled Bondatherm Epoxy Adhesive for Heat Sinks 100 gram Hinge Pack 2 gram hinge pack 100 gram hinge pack 100 gram hinge pack BONDATHERM™ CARTRIDGES BT-101-50M These high bond strength adhesives are clear 100% solids, two component, non-sag adhesives with a quick setting time of 5–46 minutes at room temperature. They are excellent for bonding plated metals, pewter, glass, wood, ceramic, felt, cement, gem stones, most plastics and rubbers. These adhesives were tested in our laboratory for flame retardancy properties. According to our test results they meet the requirements of UL94HB. APPLICATIONS: These unique adhesives are ideally suited for a wide range of electronic, electrical, industrial, structural, and jewelry applications. These adhesives are also an excellent choice for field repairs. They are offered in the popular BondaTherm Equalizer Kit dual barrel cartridge dispensing system and bulk packaging. 146 wakefield-vette.com Non-sag consistency High bond strength Fast room temperature cure – three speeds to choose from Water & chemical resistance Outstanding thermal shock resistance 1:1 mix ratio Impact resistance Specifications Color Mix ratio by volume Mixed viscosity, 25°C cps* Solids content, % Specific gravity, 25°C Semi-transparent (available in black) 1:01 Non-Sag 100 1.15 Shore D hardness 10-3005NS 10-3020NS 10-3046NS 86 72 65 Work Life, 25°C, minutes 10-3005NS 10-3020NS 10-3046NS 3-5 10-15 25-30 Handling time, 25°C, minutes 10-3005NS 10-3020NS 10-3046NS 15-20 30-35 55-60 Cure time, 25°C, hours 24-48 Coefficient of thermal expansion (in/in/°C) 60x10-6 Operating temperature range, °C Dielectric strength,V/mil Izod Impact ft-lb/in Dielectric constant, 1KHz at 25°C Dissipation factor, 1KHz at 25°C Volume resistivity, ohm-cm at 25°C BT-101-50M INSTRUCTIONS FOR USE: 1. Thoroughly mix equal parts of resin to catalyst by weight or volume. 2. Apply evenly to both surface(s) to be bonded. 3. Application to the substrates should be made within five minutes. Larger quantities and/or higher temperatures will reduce the working time. Avoid mixing large quantities and/or at high temperature due to the possibility of creating a high exothermic temperature. 4. Join the coated surfaces. Allow to cure at 60°F (16°C) or higher until adhesive is set. Heat may be added up to 200°F (93°C) to accelerate the cure. 5. Avoid moving parts during cure. Pressure to the substrates is recommended. Maximum shear strength is obtained with a 3-5 mil bond line. 50 to +130 420 2.7 4 0.017 2.0 x 1014 - Shear strength, psi Aluminum (etched) Cold rolled steel Copper Brass Stainless Steel Galvanized Steel ABS PVC 1,500 1,000 960 725 750 900 500 335 Polycarbonate Compression strength, psi 250 8,500 Adhesive coverage: a .005-inch bond line will yield approximately 320 sq. ft./gallon Contact us: (603) 635-2800 147 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS GENERAL & THERMAL HIGH PERFORMANCE EPOXY BT-102-50M A two component system that forms strong structural bonds at room temperature. This unique adhesive system provides high peel and shear strengths. This is excellent for bonding many metals and woods, most plastics and rubbers and masonry products. BT-102-50M is a toughened, flexible, and impact resistant epoxy adhesive. BT-102-50M is a two component system that forms strong structural bonds at room temperature. This unique adhesive system provides high peel and shear strengths. BT-102-50M is excellent for bonding many metals and woods, most plastics and rubbers and masonry products. This system is designed for electronic, aerospace and other demanding industrial applications. This product is available in the popular BondaTherm Equalizer dual barrel cartridge system. FEATURES • • • • • • Impact resistant Excellent electrical insulator High peel and shear Outstanding structural bonds Convenient 1:1 Ratio Retention of strength after environmental aging Typical Specifications Mixed viscosity, 25°C, cps 150,000 Specific gravity, 25°C, Resin Catalyst 1.32 1.2 Gel time, 100 grams, 25°C Tensile shear strength, psi Durometer, shore D Dielectric strength, V/mil Dielectric constant, 60 Hz Dissipation factor, 60 Hz Volume resistivity, ohm-cm Thermal conductivity, btu·in/hr·ft2·°F Coefficient of thermal expansion, per °C 70 minutes 2,600 70 410 4.4 0.02 1.1 x 1015 4 10 x 10-5 Adhesive coverage: a .005-inch bond line will yield approximately 320 sq. ft./gallon 148 INSTRUCTIONS FOR USE: 1. Surfaces must be clean and grease free. Use an oil free solvent such as acetone to wipe surfaces. Adhesion can be substantially increased by abrading the surfaces to be bonded with emery cloth, sand paper, carbide grinding tools, and sand blasting. A roughened, porous surface will produce the best results. Any oxidized metal films should be removed just prior to application of the epoxy adhesive mixture. 2. Thoroughly mix equal parts of resin and catalyst by volume. 3. Apply mixed product evenly to both surfaces. 4. Join the adhesive coated surfaces within 60 minutes of mixing resin and catalyst. 5. Cure according to one of the following schedules: 77°F 24-48 hours 150°F 2 hours 180°F 1 hour 200°F 30 minutes STORAGE, HANDLING, AND AVAILABILITY: • Store in a cool, dry place in original containers. • Keep containers closed and stir well before using. wakefield-vette.com BT-301-50M & BT-301-200M BONDATHERM™ CARTRIDGES BONDATHERM™ CARTRIDGES The BT-301-50M and BT-301-200M have simple 1:1 mix ratios and develop a 1,400 psi Lap Shear strength (aluminum to aluminum) in four hours at room temperature. After just twenty four hours the strength is over 2,200 psi. This is perfect for any thermally conductive applications. Both cartridges are a two component fast curing thermally conductive epoxy adhesive. These products are specifically formulated for use in the convenient BondaTherm Equalizer dual barrel cartridge system. The BT-301-50M and BT-301-200M offer fast heat dissipation for a wide range of electronic applications. The black resin and white hardener provide an excellent visual indication of a complete mix. FEATURES • • • • • Fast room temperature cure Thermally conductive Forms strong bonds to a variety of substrates Electrically insulating Vibration and impact resistant Typical Properties Color Resin Hardener Mixed Black White Dark Gray Viscosity, @25°C, cps Resin Hardener 70,000 70,000 Specific Gravity, @25°C Resin Hardener 1.5 1.5 Gel Time, 25°C, 15 grams 15 minutes Durometer, Shore D @25°C @70°C 80 50 Lapshear Strength (Al to Al), psi After 4 hours After 24 hours 1,413 2,231 Thermal Conductivity, W/m - °K Dielectric Strength, V/mil Dielectric Constant, 25°C, 100Hz Volume Resistivity, ohm-cm, 25°C 1.04 440 5.3 2.4 x 1012 Coefficient of Thermal Expansion, ppm/°C Below Tg Above Tg 45 175 Operating Temperature, °C -40 to +120 INSTRUCTIONS FOR USE: 1. Surfaces must be clean and grease free. Use an oil free solvent such as acetone to wipe surfaces. Adhesion can be substantially increased by abrading the surfaces to be bonded with emery cloth, sand paper, carbide grinding tools, and sand blasting. A roughened, porous surface will produce the best results. Any oxidized metal films should be removed just prior to application of the epoxy adhesive mixture. 2. Dispense material from BondaTherm Equalizer. Apply mixed product to substrate to be bonded. 3. Join substrates within 3-5 minutes. 4. Cure according to one of the following schedules: 5. 25°C 2-4 hours 65°C < 10 minutes STORAGE, HANDLING AND AVAILABILITY: • Store in a cool, dry place in original containers. • Please read and understand the Safety Data Sheet (SDS) before using this product. NOTES: 1. At room temperature, the BT-301-50M and BT-301-200M will reach handle cure within 1-2 hours. The lap shear strength is 1,413 psi after 4 hours. 2. This product is an adhesive and is not designed for potting and encapsulating applications. The BT-301-50M and BT301-200M are fast reacting epoxy systems and they will create a high exothermic temperature in large mass sizes (avoid mass sizes greater than 25 grams). Contact us: (603) 635-2800 149 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS GENERAL & THERMAL HIGH PERFORMANCE EPOXY BT-103-50M These high bond strength adhesives are clear 100% solids, two component, low viscosity adhesives with a quick setting time of 5-46 minutes at room temperature. They are excellent for bonding plated metals, pewter, glass, wood, ceramic, felt, cement, gem stones, most plastics, and rubbers. These adhesives were tested in our laboratory for flame retardancy properties. According to our test results they meet the requirements of UL94HB. These unique adhesives are ideally suited for a wide range of electronic, electrical, industrial, structural, and jewelry applications. These adhesives are also an excellent choice for field repairs. They are offered in the popular TriggerBond® dual barrel cartridge dispensing system and bulk packaging. FEATURES • • • • • • BONDATHERM HARDWARE BONDATHERM™ CARTRIDGES High bond strength Outstanding thermal shock resistance Water and chemical resistance Impact resistance 1:1 mix ratio Fast room temperature cure – three speeds to choose from Typical Specifications (10-3005) Color Mix ratio by volume Mixed viscosity, 25°C cps * Solids Content, % Clear (available in black) 1:01 12,000 100 Specific gravity, 25°C Shore D hardness 10-3005 10-3020 10-3046 1.15 86 72 65 Work Life, 25°C, minutes 10-3005 10-3020 10-3046 3-5 10-15 25-30 Handling time, 25°C, minutes 10-3005 10-3020 10-3046 15-20 30-35 55-60 Cure time, 25°C, hours Coefficient of thermal expansion (in/in/°C) Operating temperature range, °C Dielectric strength V/mil Izod Impact, ft-lb/in. Dielectric constant, 1KHz at 25°C 24-48 60x10-6 50 to +130 420 2.7 4.00 Dissipation factor, 1KHZ at 25°C Volume resistivity, ohm-cm at 25°C Shear strength, psi Aluminum (etched) Cold rolled Steel Copper Brass Stainless Steel Galvanized Steel ABS PVC Polycarbonate .017 2.0 x 1014 1,500 1,000 960 725 750 900 500 335 Compression strength, psi 250 INSTRUCTIONS FOR USE: 1. Thoroughly mix equal parts of resin to catalyst by weight or volume. 2. Apply evenly to both surface(s) to be bonded. 3. Application to the substrates should be made within five minutes. Larger quantities and/or higher temperatures will reduce the working time. 4. Avoid mixing large quantities and/or at high temperature due to the possibility of creating a high exothermic temperature. 5. Join the coated surfaces. Allow to cure at 60°F (16°C) or higher until adhesive is set. Heat may be added up to 200°F (93°C) to accelerate the cure. 6. Avoid moving parts during cure. Pressure to the substrates is recommended. Maximum shear strength is obtained with a 3-5 mil bond line. Wakefield-Vette Part Number Description BT-01-50M BT-01-200M BT-02-50M BT-02-200M BondaTherm Equalizer Dispense Gun (50ml) BondaTherm Equalizer Dispense Gun (200ml) BondaTherm Equalizer Static Mixer (50ml) BondaTherm Equalizer Static Mixer (200ml) BONDATHERM EQUALIZER GUN BT-01-50M BONDATHERM™ CARTRIDGES FOR USE W/ 200ML CARTRIDGES BT-01-200M BONDATHERM EQUALIZER STATIC MIXERS BT-02-50M FOR USE W/ 50ML CARTRIDGES FOR USE W/ 200ML CARTRIDGES BT-01-200M Adhesive coverage: a .005-inch bond line will yield approximately 320 sq. ft./gallon 150 wakefield-vette.com Contact us: (603) 635-2800 151 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS GENERAL & THERMAL HIGH PERFORMANCE EPOXY BONDATHERM EQUALIZER KIT™ Wakefield-Vette Part Number BT-101-50M-EQZ BT-102-50M-EQZ BT-301-50M-EQZ BT-301-200M-EQZ BONDATHERM HINGE PACKS Description Two Dual Cartridges (BT-101-50M), One Gun (BT-01-50M), Three Mixers (BT-02-50M) Two Dual Cartridges (BT-102-50M), One Gun (BT-01-50M), Three Mixers (BT-02-50M) Two Dual Cartridges (BT-301-50M), One Gun (BT-01-50M), Three Mixers (BT-02-50M) Two Dual Cartridges (BT-301-200M), One Gun (BT-01-200M), Three Mixers (BT-02-200M) (2) Dual Cartridges, (1) Dispense Gun, (3) Static Mixers Packaging Kit Kit Kit Kit BT-401-H BT-401-H is a two component epoxy adhesive filled with silver. This electrically conductive epoxy resin formulation offers continuity of conductivity with an electrical resistivity value of less than 1x10-4 ohm-cm. 40-3900 is also well known for its wide operating temperature range, -50 to + 170°C. BT-401-H is specifically designed for adhesive bonding in microelectronic and optoelectronic applications. Due to its excellent continuity, it has also been used extensively in applications such as micro-wave EMI and RFI shielding, in the assembly or repair of printed circuit boards, wave guides, electronic modules, flat cable, high frequency shields, connectors, circuitry, and as a cold solder. BT-401-H is formulated with pure silver (no alloys) and is designed in a convenient 1:1 mix ratio. Both the resin and hardener have silver powder dispersed. STORAGE, HANDLING, AND AVAILABILITY: • BT-401-H Resin and hardener should be stored at 25°C in original tightly sealed containers. Expected shelf life is twelve months in original unopened containers. • Filler settling is common with these products. Gently stir resin and hardener before using to make sure fillers are evenly dispersed. FEATURES • • • • • Electrically conductive Thermally conductive Room temperature cure Easy 1:1 mix ratio Good bond strength Typical Specifications 152 wakefield-vette.com Mix Ratio, by Weight Color Mixed Viscosity Pot Life, 100 gram mass @ 25°C 1:1 Silver Creamy Paste 1 Hour Specific Gravity, 25°C Resin Hardener 2.98 1.8 Hardness, Shore D Thermal Conductivity, W/m- °K Tensile Lapshear, psi (Al to Al) Flexural Strength, psi Volume Resistivity, ohm-cm Operating Temp. Range, °C 70 7.93 700 10,200 0.0001 50 to +170 Cure Schedule a) 24 hours @ 25°C b) 1 hour @ 65°C c) 15 minutes @ 90°C Contact us: (603) 635-2800 153 THERMAL INTERFACE PRODUCTS THERMAL INTERFACE PRODUCTS GENERAL & THERMAL HIGH PERFORMANCE EPOXY BT-402-H This system has been formulated to meet the stringent non-burning requirements of UL94 V-0. BT-402-H Black Epoxy is used with Catalyst 190 and are listed with Underwriter’s Laboratory for passing UL94 V-0. This system offers excellent heat transfer, low shrinkage, and outstanding insulation properties. BT-402-H Black with Catalyst 190 passes NASA’s outgassing requirements per ASTM E595-07. Other Catalyst’s are available as well (30, 150.). Typical applications for BT-402-H include encapsulating power supplies, transformers, coils, insulators, and sensors. This system is an excellent choice for applications requiring high thermal conductivity and flame retardancy. Typical Specifications 154 BONDATHERM HINGE PACKS BONDATHERM HINGE PACKS Viscosity @ 25°C cps, Resin Mixed with Cat. 190 Mixed with Cat. 30 Mixed with Cat. 150 60,000 28,000 17,000 1,500 Specific Gravity, 25°C Hardness, Shore D Color Tensile Strength, psi Linear Shrinkage, in/in Operating Temp. Range,°C Dielectric Strength, V/mil Dielectric Constant at 60 Hz Volume Resistivity, ohm-cm, 25°C Dissipation Factor, 60 Hz Thermal Conductivity, W/m- °K Compressive Strength, psi Coefficient of Expansion, in/in °F Heat Distortion, °C Outgassing 1.6 90 Black 9,850 0.002 60 to +200 485 5.6 1.5 x 1015 0.015 2.16 15,000 1.4 x 10-5 (with Cat. 190) %TML %CVCM 155 0.5 0.01 INSTRUCTIONS FOR USE: A. With Catalyst 190 listed with UL 94 V-0 (room temperature curing): 1. By weight, thoroughly mix 5 parts Catalyst 190 to 100 parts BT-402-H resin. 2. Degas and pour. Cure at room temperature for 12-24 hours at 25°C ambient. B. With Catalyst 30 listed with UL 94 V-0 and RTI Rating of 130°C (Heat curing - Recommended for higher operating temperature and physical property applications): 1. By weight, thoroughly mix 10 parts Catalyst 30 to 100 parts BT-402-H resin. 2. Pour and cure according to one of the following recommended cure schedules: a) 85°C (185°F) 3-4 hours b) 100°C (212°F) 2-3 hours For optimum performance, an additional 2 hours @ 365°F (185°C) is recommended. C. With Catalyst 150 (room temperature/heat curing): 1. By weight, thoroughly mix 17 parts Catalyst 150 to 100 parts BT-402-H resin. 2. Degas and pour. Cure at room temperature for 24 hours or for 2-3 hours at 35-40°C. wakefield-vette.com BT-403-H BT-403-H is a two component, aluminum filled epoxy system. This system is used for making heat resistant tools, parts, or bonds that require the highest thermal conductivity and heat resistance. We have developed this extremely conductive epoxy by formulating it with a unique combination of fillers, particle sizes and dispersion techniques. BT-403-H has good heat dissipation making this a popular choice for a variety of heat sink applications. Its viscosity is particularly suited for Fin bonding. BT-403-H passes NASA’s outgassing requirements per ASTM E-595-07. FEATURES • Excellent Thermal Conductivity • Superior Adhesion • Low Viscosity allows quick self leveling STORAGE, HANDLING, AND AVAILABILITY: • BT-401-H Resin and hardener should be stored at 25°C in original tightly sealed containers. Expected shelf life is twelve months in original unopened containers. • Filler settling is common with these products. Gently stir resin and hardener before using to make sure fillers are evenly dispersed. Typical Specifications Color Grey Viscosity, 25°C, Resin Mixed 130,000 8,000 Specific Gravity, 25°C Working time, 100 grams, 25°C 1.81 5 Hours Durometer, Shore D 25°C 100°C 90 65 Tensile Strength, psi, 25°C Aluminum 9,000 to Aluminum 1" overlap 2,500 Compressive Strength, PSI, 25°C Mix Ratio, by weight Operating temperature, °C Coefficent of Thermal Expansion, °C Thermal Conductivity, W/m- °K 18,500 100:10 -55 to 155 28 x 10-6 4.5 Outgassing % TML % CVCM 0.91 0.07 Contact us: (603) 635-2800 155
175-6-330P 价格&库存
很抱歉,暂时无法提供与“175-6-330P”相匹配的价格&库存,您可以联系我们找货
