GT20-30-25-0.23
GT20-30-25-0.23
    T-GLOBAL
    GT2030X25X0.23MM
GT20-30-25-0.23 数据手册
GT20 High Thermal Conductivity Glassfiber Reinforcement Features Smooth surface & low thermal contact resistance Exceptional thermal performance at lower application pressures (20psi~400psi) Usable over a wide temperture range Simplified processing and reduced operating costs Complies with UL standards Properties Property GT20 Unit Test Method Colour Green - Visual Reinforcement Fiberglass - - Thickness 0.23 (mm) - Op. Temp. Range -45 to 180 ˚C - Density 2.52 g/cm Thermal Conductivity 2 W/mK ASTM D5470 Hardness 80 Shore A ASTM D2240 3 ASTM D792 Breakdown Voltage AC 4000 V ASTM D149 Breakdown Voltage DC 6000 V ASTM D149 Dielectric Constant 5.7 1000 Hz ASTM D150 Thermal Impedance t=0.23mm ˚C in 2/W 20psi 0.60 psi ASTM D5470 t=0.23mm 50psi 0.43 psi ASTM D5470 t=0.23mm 100psi 0.35 psi ASTM D5470 t=0.23mm 200psi 0.32 psi ASTM D5470 t=0.23mm 400psi 0.30 psi ASTM D5470 TML ‹ 0.2 % % ASTM E595 Tensile Strength 200 psi ASTM D412 Elongation 60 % ASTM D412 UL Flammability V-0 - UL 94 Limited Warranty High Thermal Conductivity Glassfiber Reinforcement is guaranteed against detachment, under normal use, for 5 years from the purchase date. User shall be solely responsible for determining the suitability of TIM for the intended use, and the user assumes all risks and liabilities whatsoever in connection there with. Neither seller nor manufacturer shall be liable either in tort or in contract for any loss damage, including loss of profits or revenue arising out of the use or the inability to use a product. Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
GT20-30-25-0.23
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
GT20-30-25-0.23 价格&库存
很抱歉,暂时无法提供与“GT20-30-25-0.23”相匹配的价格&库存,您可以联系我们找货
