GP2000-D13.5-L30-0.3 数据手册
GP2000
Thermally Conductive Tubes
Features
Usable over a wide temperature range
Simplified processing and reduced operating costs
Complies with UL standards
Properties
Property
GP2000D11-L25-0.3
GP2000D11-L30-0.3
GP2000D13.5-L25-0.3
GP2000D13.5-L30-0.3
Test Method
Colour
Green
Green
Green
Green
Visual
Base
Silicone Rubber
Silicone Rubber
Silicone Rubber
Silicone Rubber
Thickness (mm)
0.3
0.3
0.3
0.3
Diameter / Length
11mm / 25mm
11mm / 30mm
13.5mm / 25mm
13.5mm / 30mm
Op. Temp. Range (ºC)
-55 to 180
-55 to 180
-55 to 180
-55 to 180
Density (g/cm )
2.52
2.52
2.52
2.52
ASTM D792
Thermal Conductivity (W/mk)
1.3
1.3
1.3
1.3
ASTM D5470
3
Shore A
80
80
80
80
ASTM D2240
Breakdown Voltage AC (V)
5000
5000
5000
5000
ASTM D149
Breakdown Voltage DC (V)
7000
7000
7000
7000
ASTM D149
Dielectric Constant (1000 Hz)
5.7
5.7
5.7
5.7
ASTM D150
Volume Resistivity (Ohm-cm)
›1012
›1012
›1012
›1012
ASTM D257
TML (%)
‹0.2%
‹0.2%
‹0.2%
‹0.2%
ASTM E595
Tensile Strength (PSI)
200
200
200
200
ASTM D412
Elongation (%)
60
60
60
60
ASTM D412
UL Flammability
V-0
V-0
V-0
V-0
UL 94
Limited Warranty
High Thermal Conductivity Tubes are guaranteed against detachment, under normal use, for 5 years from the purchase date.
The User shall be solely responsible for determining the suitability of TC Tubes for the intended use, and the user assumes all risks and liabilities whatsoever in connection there with. Neither seller nor manufacturer shall be liable either in tort or in contract for any loss damage, including loss of profits
or revenue arising out of the use or the inability to use the product.
Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
GP2000-D13.5-L30-0.3 价格&库存
很抱歉,暂时无法提供与“GP2000-D13.5-L30-0.3”相匹配的价格&库存,您可以联系我们找货
