GT15-60-30-0.23
GT15-60-30-0.23
    T-GLOBAL
    GT1560X30X0.23MM
GT15-60-30-0.23 数据手册
GT15 Thermal Conductivity Glassfiber Reinforcement Features Smooth surface & low thermal contact resistance Exceptional thermal performance at lower application pressures (20psi~400psi) Usable over a wide temperture range Electrically isolating Complies with UL standards Properties Property GT15 Unit Test Method Colour Yellow - Visual Reinforcement Fiberglass - - Thickness 0.23 (mm) - Op. Temp. Range -45 to 180 ˚C - Density 2.35 g/cm Thermal Conductivity 1.5 W/mK ASTM D5470 Hardness 75 Shore A ASTM D2240 3 ASTM D792 Breakdown Voltage AC 4000 V ASTM D149 Breakdown Voltage DC 6000 V ASTM D149 Dielectric Constant 5.8 1000 Hz ASTM D150 Thermal Impedance t=0.23mm ˚C in 2/W 20psi 0.70 psi ASTM D5470 t=0.23mm 50psi 0.61 psi ASTM D5470 t=0.23mm 100psi 0.49 psi ASTM D5470 t=0.23mm 200psi 0.43 psi ASTM D5470 t=0.23mm 400psi 0.40 psi ASTM D5470 TML ‹ 0.2 % % ASTM E595 Tensile Strength 200 psi ASTM D412 Elongation 60 % ASTM D412 UL Flammability V-0 - UL 94 Limited Warranty High Thermal Conductivity Glassfiber Reinforcement is guaranteed against detachment, under normal use, for 5 years from the purchase date. User shall be solely responsible for determining the suitability of TIM for the intended use, and the user assumes all risks and liabilities whatsoever in connection there with. Neither seller nor manufacturer shall be liable either in tort or in contract for any loss damage, including loss of profits or revenue arising out of the use or the inability to use a product. Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
GT15-60-30-0.23
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并将其转换为电信号。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压范围为3V至5.5V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号,并将其转换为电信号输出。
6. 应用信息:EL817广泛应用于电视、空调等家用电器的红外遥控。
7. 封装信息:EL817采用SOP-8封装。
GT15-60-30-0.23 价格&库存
很抱歉,暂时无法提供与“GT15-60-30-0.23”相匹配的价格&库存,您可以联系我们找货
