TGX-74-18-0.5
TGX-74-18-0.5
    T-GLOBAL
    TGX74X18X0.5MM
TGX-74-18-0.5 数据手册
TG-X Ultra Soft Thermal Conductive Pad Version 3.121119 Ultra Soft Thermal Conductive Pad TG-X is our high performance silicone gap filler with a thermal conductivity of 12 W/mk. TG-X is highly conformable and can be supplied in either standard sheets or custom die-cut parts. TG-X is formulated to wet most surfaces and provide low thermal impedance for the most demanding of applications. Features High-end product with thermal conductivity of 12 W/mK Highly compressible Naturally tacky with low Shore 00 hardness Low oil bleed and electrically insulating Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property TG-X Unit Colour Grey - Tolerance Test Method - Visual Thickness (Available thickness range) 0.5 - 2.0 mm - ASTM D374 0.0197 - 0.0787 inch - ASTM D374 Thermal Conductivity 12 W/mK ±1.2 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 12 kV/mm ±1.2 ASTM D149 Weight Loss ‹1 % - ASTM E595 Density 3.4 g/cm³ ±0.2 ASTM D792 Working Temperature -45 to 200 ˚C - - Volume Resistance ›10¹¹ Ohm-cm - ASTM D257 Standard Shape 320-320mm Sheets - - Hardness 65 Shore 00 ±15 ASTM D2240 Shelf Life 36 months - - Shelf Life with adhesive (can be requalified for further 12) 12 months - - Standard Weights & Dimensional Tolerance Thickness (mm) Size 0.50 0.80 1.00 1.50 2.00 100x100 17.00 27.20 34.00 51.00 68.00 150x150 38.25 61.20 76.50 114.75 153.00 300x300 153.00 244.80 306.00 459.00 612.00 320x320 174.08 278.53 348.16 522.24 696.32 * All measurements in weights are in gr ** All sizes are in mm T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com VAT #: GB 116 662 714 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use.
TGX-74-18-0.5 价格&库存
很抱歉,暂时无法提供与“TGX-74-18-0.5”相匹配的价格&库存,您可以联系我们找货
