TG6050-107-53-3
TG6050-107-53-3
    T-GLOBAL
    TG6050107X53X3MM
TG6050-107-53-3 数据手册
TG6050 Ultra-Soft Thermal Conductive Pad Version 2.130218 Ultra-Soft Thermal Conductive Pad TG6050 is an ultra-soft, silicone based thermal interface material. TG6050 has a low thermal impedance, conforms readily to surfaces due to its low hardness and provides a high dielectric breakdown voltage. TG6050 can be provided in various thicknesses and formats, such as custom die cuts, standard sheets or log rolls depending on the end application. Features Superior thermal conductivity Highly compressible Naturally tacky Low Shore 00 hardness Low oil bleed Electrically insulating Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property TG6050 Unit Tolerance Test Method Colour Red - - Visual 0.5 - 5.0 mm - ASTM D374 0.0197 - 0.0787 Inch - ASTM D374 Thermal Conductivity 6 W/mK ±0.6 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 13 kV/mm ±1.3 ASTM D149 Weight Loss ‹1 % - ASTM E595 Thickness Density 3.2 g/cm³ ±0.2 ASTM D792 Working Temperature -45 to 200 ˚C - - Volume Resistance ›10¹² Ohm-cm - ASTM D257 Elongation 50 % ±13 ASTM D412 Tensile Strength 0.5 Kgf/cm² ±2 ASTM D412 Hardness 60 Shore 00 ±15 ASTM D2240 Shelf Life 36 months - - Shelf Life with adhesive (can be requalified for further 12) 12 months - - Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 TG6050 Ultra-Soft Thermal Conductive Pad Standard Weights & Dimensional Tolerance Size Thickness (mm) 0.50 0.80 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 100x100 16.00 25.60 32.00 48.00 64.00 80.00 96.00 112.00 128.00 144.00 160.00 150x150 36.00 57.60 72.00 108.00 144.00 180.00 216.00 252.00 288.00 324.00 360.00 300x300 144.00 230.40 288.00 432.00 576.00 720.00 864.00 1,008.00 1,152.00 1,296.00 1,440.00 320x320 163.84 262.14 327.68 491.52 655.36 819.20 983.04 1,146.88 1,310.72 1,474.56 1,638.40 * All measurements in mm Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 Data * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TG6050-107-53-3 价格&库存
很抱歉,暂时无法提供与“TG6050-107-53-3”相匹配的价格&库存,您可以联系我们找货
