74HC193; 74HCT193
Presettable synchronous 4-bit binary up/down counter
Rev. 7 — 8 September 2021
Product data sheet
1. General description
The 74HC193; 74HCT193 is a 4-bit synchronous binary up/down counter. Separate up/down
clocks, CPU and CPD respectively, simplify operation. The outputs change state synchronously
with the LOW-to-HIGH transition of either clock input. If the CPU clock is pulsed while CPD is held
HIGH, the device will count up. If the CPD clock is pulsed while CPU is held HIGH, the device will
count down. Only one clock input can be held HIGH at any time to guarantee predictable behavior.
The device can be cleared at any time by the asynchronous master reset input (MR); it may also
be loaded in parallel by activating the asynchronous parallel load input (PL). The terminal count up
(TCU) and terminal count down (TCD) outputs are normally HIGH. When the circuit has reached
the maximum count state of 15, the next HIGH-to-LOW transition of CPU will cause TCU to go
LOW. TCU will stay LOW until CPU goes HIGH again, duplicating the count up clock. Likewise,
the TCD output will go LOW when the circuit is in the zero state and the CPD goes LOW. The
terminal count outputs can be used as the clock input signals to the next higher order circuit in
a multistage counter, since they duplicate the clock waveforms. Multistage counters will not be
fully synchronous, since there is a slight delay time difference added for each stage that is added.
The counter may be preset by the asynchronous parallel load capability of the circuit. Information
present on the parallel data inputs (D0 to D3) is loaded into the counter and appears on the outputs
(Q0 to Q3) regardless of the conditions of the clock inputs when the parallel load (PL) input is LOW.
A HIGH level on the master reset (MR) input will disable the parallel load gates, override both
clock inputs and set all outputs (Q0 to Q3) LOW. If one of the clock inputs is LOW during and after
a reset or load operation, the next LOW-to-HIGH transition of that clock will be interpreted as a
legitimate signal and will be counted. Inputs include clamp diodes. This enables the use of current
limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Input levels:
• For 74HC193: CMOS level
• For 74HCT193: TTL level
Synchronous reversible 4-bit binary counting
Asynchronous parallel load
Asynchronous reset
Expandable without external logic
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V.
Specified from -40 °C to +85 °C and -40 °C to +125 °C.
74HC193; 74HCT193
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC193D
Temperature
range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74HCT193D
74HC193PW
74HCT193PW
4. Functional diagram
15
11
5
4
14
1
D0
PL
D1
9
D2
D3
TCU
CPU
COUNTER
CPD
MR
TCD
12
13
FLIP-FLOPS
Q0
3
Fig. 1.
10
Q1
2
Q2
6
Fig. 2.
11
5
4
14
15
1
10
9
C3
2+
G1
1G2
R
D1
D2
D3
11
15
1
10
9
5
12
TCU
CPD
4
13
TCD
001aag405
Functional diagram
D0
CPU
14
3
2
6
7
MR
Q0
Q1
Q2
Q3
Q3
7
PL
001aag409
Logic symbol
CTR4
3
2
6
7
3D
2CT = 0
1CT = 15
13
12
001aag410
Fig. 3.
IEC logic symbol
74HC_HCT193
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 24
74HC193; 74HCT193
Nexperia
D0
D1
D2
D3
PL
CPU
TCU
SD
T
SD
Q
FF1
RD
T
Q
SD
Q
FF2
RD
T
Q
SD
Q
FF3
RD
T
Q
Q
FF4
RD
Q
TCD
CPD
MR
Q0
Fig. 4.
Q1
Q2
Q3
001aag412
Logic diagram
74HC_HCT193
Product data sheet
3 / 24
74HC193; 74HCT193
Nexperia
5. Pinning information
5.1. Pinning
74HC193
74HCT193
D1
1
16 VCC
Q1
2
15 D0
Q0
3
14 MR
CPD
4
13 TCD
CPU
5
12 TCU
Q2
6
11 PL
Q3
7
GND
8
74HC193
74HCT193
D3
1
2
16 VCC
15 D0
Q0
3
14 MR
CPD
4
13 TCD
CPU
5
12 TCU
Q2
6
11 PL
Q3
7
10 D2
GND
8
10 D2
9
D1
Q1
D3
001aag407
001aag406
Fig. 5.
9
Pin configuration for SOT109-1 (SO16)
Fig. 6.
Pin configuration for SOT403-1 (TSSOP16)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
D0, D1, D2, D3
15, 1, 10, 9
data input
Q0, Q1, Q2, Q3
3, 2, 6, 7
flip-flop output
CPD
4
count down clock input; LOW-to-HIGH, edge triggered
CPU
5
count up clock input; LOW-to-HIGH, edge triggered
GND
8
ground (0 V)
PL
11
asynchronous parallel load input (active LOW)
TCU
12
terminal count up (carry) output (active LOW)
TCD
13
terminal count down (borrow) output (active LOW)
MR
14
asynchronous master reset input (active HIGH)
VCC
16
supply voltage
74HC_HCT193
Product data sheet
4 / 24
74HC193; 74HCT193
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = LOW-to-HIGH clock transition.
Operating mode
Inputs
Outputs
MR
PL
CPU CPD D0
D1
D2
D3
Q0
Q1
Q2
Q3
TCU TCD
H
X
X
L
X
X
X
X
L
L
L
L
H
L
H
X
X
H
X
X
X
X
L
L
L
L
H
H
L
L
X
L
L
L
L
L
L
L
L
L
H
L
L
L
X
H
L
L
L
L
L
L
L
L
H
H
L
L
L
X
H
H
H
H
H
H
H
H
L
H
L
L
H
X
H
H
H
H
H
H
H
H
H
H
Count up
L
H
H
X
X
X
X
count up
H [1] H
Count down
L
H
H
X
X
X
X
count down
H
Reset (clear)
Parallel load
[1]
[2]
H [2]
TCU = CPU at terminal count up (HHHH)
TCD = CPD at terminal count down (LLLL).
74HC_HCT193
Product data sheet
5 / 24
74HC193; 74HCT193
Nexperia
MR(1)
PL
D0
D1
D2
D3
CPU(2)
CPD(2)
Q0
Q1
Q2
Q3
TCU
TCD
CLEAR
PRESET
14
15
COUNT UP
1
2
1
14
COUNT DOWN
13
001aag411
(1) Clear overrides load, data and count inputs.
(2) When counting up, the count down clock input (CPD) must be HIGH, when counting down the count up clock
input (CPU) must be HIGH.
Sequence:
Clear (reset outputs to zero);
Load (preset) to binary thirteen;
Count up to fourteen, fifteen, terminal count up, zero, one and two;
Count down to one, zero, terminal count down, fifteen, fourteen and thirteen.
Fig. 7.
Typical clear, load and count sequence
74HC_HCT193
Product data sheet
6 / 24
74HC193; 74HCT193
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
VO = -0.5 V to VCC + 0.5 V
[1]
±20
mA
±25
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Conditions
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC193
74HCT193
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC
supply voltage
VI
74HC_HCT193
Product data sheet
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
7 / 24
74HC193; 74HCT193
Nexperia
9. Static characteristics
Table 6. Static characteristics type 74HC193
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
Tamb = 25 °C
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
IO = -20 μA; VCC = 2.0 V
1.9
2.0
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
V
IO = 20 μA; VCC = 2.0 V
V
IO = 20 μA; VCC = 4.5 V
V
IO = 20 μA; VCC = 6.0 V
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
V
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
±0.1
μA
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 6.0 V
8.0
μA
Ci
input capacitance
3.5
pF
74HC_HCT193
Product data sheet
8 / 24
74HC193; 74HCT193
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.84
V
5.34
V
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
VI = VIH or VIL
II
±1.0
μA
ICC
supply current
80
μA
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
Tamb = -40 °C to +125 °C
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
VI = VIH or VIL
II
±1.0
μA
ICC
supply current
160
μA
74HC_HCT193
Product data sheet
9 / 24
74HC193; 74HCT193
Nexperia
Table 7. Static characteristics type 74HCT193
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 °C
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
LOW-level input
voltage
1.2
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
V
IO = -4.0 mA
3.98
4.32
V
VOL
LOW-level output
voltage
IO = 20 μA
V
IO = 4.0 mA
0.15
0.26
V
II
VI = VCC or GND; VCC = 5.5 V
±0.1
μA
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 5.5 V
8.0
μA
ΔICC
additional supply
current
per input pin;
VI = VCC - 2.1 V; other inputs at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
pin Dn
35
126
μA
pins CPU, CPD
140
504
μA
pin PL
65
234
μA
pin MR
105
378
μA
3.5
pF
Ci
input capacitance
VIH
HIGH-level input
voltage
2.0
V
VIL
LOW-level input
voltage
0.8
V
VOH
HIGH-level output
voltage
IO = -20 μA
4.4
V
IO = -4.0 mA
3.84
V
IO = 20 μA
0.1
V
IO = 4.0 mA
0.33
V
VOL
LOW-level output
voltage
II
±1.0
μA
ICC
supply current
80
μA
ΔICC
additional supply
current
per input pin;
pin Dn
157.5
μA
pins CPU, CPD
630
μA
pin PL
292.5
μA
pin MR
472.5
μA
74HC_HCT193
Product data sheet
10 / 24
74HC193; 74HCT193
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VIH
HIGH-level input
voltage
2.0
V
VIL
LOW-level input
voltage
0.8
V
VOH
HIGH-level output
voltage
IO = -20 μA
4.4
V
IO = -4.0 mA
3.7
V
IO = 20 μA
0.1
V
IO = 4.0 mA
0.4
V
VOL
LOW-level output
voltage
II
±1.0
μA
ICC
supply current
160
μA
ΔICC
additional supply
current
per input pin;
pin Dn
171.5
μA
pins CPU, CPD
686
μA
pin PL
318.5
μA
pin MR
514.5
μA
74HC_HCT193
Product data sheet
11 / 24
74HC193; 74HCT193
Nexperia
10. Dynamic characteristics
Table 8. Dynamic characteristics type 74HC193
Symbol Parameter
Conditions
25 °C
Min
tpd
propagation
delay
CPU, CPD to Qn; see Fig. 8 [1]
-40 °C to +85 °C
Typ Max
-40 °C to +125 °C Unit
Min
Max
Min
Max
VCC = 2.0 V
63
215
270
325
ns
VCC = 4.5 V
23
43
54
65
ns
VCC = 6.0 V
18
37
46
55
ns
VCC = 2.0 V
39
125
155
190
ns
VCC = 4.5 V
14
25
31
38
ns
VCC = 6.0 V
11
21
26
32
ns
VCC = 2.0 V
39
125
155
190
ns
VCC = 4.5 V
14
25
31
38
ns
VCC = 6.0 V
11
21
26
32
ns
VCC = 2.0 V
69
220
275
330
ns
VCC = 4.5 V
25
44
55
66
ns
VCC = 6.0 V
47
56
ns
VCC = 2.0 V
58
200
250
300
ns
VCC = 4.5 V
21
40
50
60
ns
VCC = 6.0 V
17
34
43
51
ns
VCC = 2.0 V
69
210
265
315
ns
VCC = 4.5 V
25
42
53
63
ns
VCC = 6.0 V
45
54
ns
VCC = 2.0 V
80
290
365
435
ns
VCC = 4.5 V
29
58
73
87
ns
VCC = 6.0 V
23
49
62
74
ns
VCC = 2.0 V
74
285
355
430
ns
VCC = 4.5 V
27
57
71
86
ns
VCC = 6.0 V
22
48
60
73
ns
VCC = 2.0 V
80
290
365
435
ns
VCC = 4.5 V
29
58
73
87
ns
VCC = 6.0 V
23
49
62
74
ns
CPU to TCU; see Fig. 9
CPD to TCD; see Fig. 9
PL to Qn; see Fig. 10
MR to Qn; see Fig. 11
Dn to Qn; see Fig. 10
PL to TCU, PL to TCD;
see Fig. 13
MR to TCU, MR to TCD;
see Fig. 13
Dn to TCU, Dn to TCD;
see Fig. 13
74HC_HCT193
Product data sheet
12 / 24
74HC193; 74HCT193
Nexperia
Symbol Parameter
Conditions
25 °C
Min
tTHL
tTLH
tW
-40 °C to +85 °C
Typ Max
Min
Max
Min
Max
HIGH to LOW see Fig. 11
output
VCC = 2.0 V
transition time
VCC = 4.5 V
19
75
95
110
ns
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
LOW to HIGH see Fig. 11
output
VCC = 2.0 V
transition time
VCC = 4.5 V
19
75
95
110
ns
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
100
22
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
6
21
26
ns
VCC = 2.0 V
100
25
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
7
21
26
ns
VCC = 2.0 V
100
19
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
6
21
26
ns
VCC = 2.0 V
50
8
65
75
ns
VCC = 4.5 V
10
3
13
15
ns
VCC = 6.0 V
9
2
11
13
ns
VCC = 2.0 V
50
75
ns
VCC = 4.5 V
10
15
ns
VCC = 6.0 V
9
13
ns
VCC = 2.0 V
80
22
100
120
ns
VCC = 4.5 V
16
8
ns
VCC = 6.0 V
14
6
17
ns
VCC = 2.0 V
ns
VCC = 4.5 V
ns
VCC = 6.0 V
ns
VCC = 2.0 V
80
22
100
120
ns
VCC = 4.5 V
16
8
ns
VCC = 6.0 V
8
6
17
ns
pulse width
CPU, CPD; HIGH or LOW;
see Fig. 8
MR HIGH; see Fig. 11
PL LOW; see Fig. 10
trec
recovery time
PL to CPU, CPD; see Fig. 10
MR to CPU, CPD;
see Fig. 11
tsu
th
set-up time
hold time
Dn to PL; see Fig. 12;
CPU = CPD = HIGH
CPU to CPD, CPD to CPU;
see Fig. 14
74HC_HCT193
Product data sheet
13 / 24
74HC193; 74HCT193
Nexperia
Symbol Parameter
fmax
maximum
frequency
CPD
[1]
[2]
power
dissipation
capacitance
Conditions
25 °C
-40 °C to +85 °C
Min
Typ Max
Min
Max
Min
Max
VCC = 2.0 V
4.0
13.5
3.2
2.6
MHz
VCC = 4.5 V
16
13
MHz
VCC = 6.0 V
24
49
19
15
MHz
24
pF
CPU, CPD; see Fig. 8
VI = GND to VCC; VCC = 5 V; [2]
fi = 1 MHz
tpd is the same as tPHL and tPLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of outputs.
Table 9. Dynamic characteristics type 74HCT193
Symbol Parameter
Conditions
25 °C
Min
tpd
propagation
delay
-40 °C to +85 °C
Typ Max
Min
Max
Min
Max
VCC = 4.5 V
23
43
54
65
ns
15
27
34
41
ns
15
27
34
41
ns
26
46
58
69
ns
22
40
50
60
ns
27
46
58
69
ns
31
55
69
83
ns
29
55
69
83
ns
VCC = 4.5 V
VCC = 4.5 V
VCC = 4.5 V
VCC = 4.5 V
VCC = 4.5 V
see Fig. 13
VCC = 4.5 V
see Fig. 13
VCC = 4.5 V
see Fig. 13
tTHL
tTLH
VCC = 4.5 V
32
58
73
87
ns
output
VCC = 4.5 V
transition time
7
15
19
22
ns
output
VCC = 4.5 V
transition time
7
15
19
22
ns
74HC_HCT193
Product data sheet
14 / 24
74HC193; 74HCT193
Nexperia
Symbol Parameter
Conditions
25 °C
Min
tW
pulse width
-40 °C to +85 °C
Typ Max
Min
Max
Min
Max
see Fig. 8
VCC = 4.5 V
25
11
31
38
ns
25
30
ns
25
30
ns
10
2
13
15
ns
10
15
ns
16
8
ns
ns
16
7
ns
16
13
MHz
26
pF
VCC = 4.5 V
PL LOW; see Fig. 10
VCC = 4.5 V
trec
recovery time
VCC = 4.5 V
MR to CPU, CPD;
see Fig. 11
VCC = 4.5 V
tsu
set-up time
CPU = CPD = HIGH
VCC = 4.5 V
th
hold time
VCC = 4.5 V
see Fig. 14
VCC = 4.5 V
fmax
CPD
[1]
[2]
maximum
frequency
power
dissipation
capacitance
VI = GND to VCC - 1.5 V;
VCC = 5 V; fi = 1 MHz
VCC = 4.5 V
[2]
2
2
2
74HC_HCT193
Product data sheet
15 / 24
74HC193; 74HCT193
Nexperia
10.1. Waveforms and test circuit
1/fmax
VI
CPU, CPD
input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
001aag413
VOL
Measurement points are given in Table 10.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 8.
The clock (CPU, CPD) to output (Qn) propagation delays, the clock pulse width, and the maximum clock
pulse frequency
VI
CPU, CPD
input
VM
GND
tPHL
tPLH
VOH
TCU, TCD
output
VM
VOL
001aag414
Fig. 9.
The clock (CPU, CPD) to terminal count output (TCU, TCD) propagation delays
VI
Dn input
VM
GND
VI
PL input
VM
GND
VI
CPU, CPD
input
t rec
tW
VM
GND
t PLH
t PHL
VOH
Qn output
VM
VOL
001aag415
Fig. 10. The parallel load input (PL) and data (Dn) to Qn output propagation delays and PL removal time to clock
input (CPU, CPD)
74HC_HCT193
Product data sheet
16 / 24
74HC193; 74HCT193
Nexperia
VI
MR input
VM
GND
tW
CPU, CPD
input
t rec
VI
VM
GND
t PHL
VOH
90 %
VM
Qn output
10 %
VOL
t THL
t TLH
001aag416
Fig. 11. The master reset input (MR) pulse width, MR to Qn propagation delays, MR to CPU, CPD removal time and
output transition times
VI
VM
Dn input
GND
tsu
VI
th
tsu
th
VM
PL input
GND
VOH
Qn output
VOL
001aag417
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 12. The data input (Dn) to parallel load input (PL) set-up and hold times
PL, MR, Dn
input
VI
VM
GND
tPLH
tPHL
VOH
TCU, TCD
output
VM
VOL
001aag418
Fig. 13. The data input (Dn), parallel load input (PL) and the master reset input (MR) to the terminal count outputs
74HC_HCT193
Product data sheet
17 / 24
74HC193; 74HCT193
Nexperia
VI
CPU or CPD
input
VM
GND
th
VI
CPD or CPU
input
VM
GND
001aag419
Fig. 14. The CPU to CPD or CPD to CPU hold times
Table 10. Measurement points
Type
Input
Output
VM
VI
VM
74HC193
0.5 × VCC
GND to VCC
0.5 × VCC
74HCT193
1.3 V
GND to 3 V
1.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VCC
VO
DUT
RT
RL
S1
open
CL
001aad983
Test data is given in Table 11.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistor
S1 = Test selection switch
Fig. 15. Test circuit for measuring switching times
Table 11. Test data
Type
Input
S1 position
Load
VI
tr, tf
CL
RL
tPHL, tPLH
74HC193
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
74HCT193
3V
6 ns
15 pF, 50 pF
1 kΩ
open
74HC_HCT193
Product data sheet
18 / 24
74HC193; 74HCT193
Nexperia
11. Application information
data input
D0 D1 D2 D3
D0 D1 D2 D3
up clock
CPU
TCU
CPU
TCU
down clock
CPD
IC1 TCD
CPD
IC2 TCD
PL
asynchronous
parallel load
reset
MR
PL
Q0 Q1 Q2 Q3
carry
borrow
MR
Q0 Q1 Q2 Q3
data output
001aag420
Fig. 16. Application for cascaded up/down counter with parallel load
74HC_HCT193
Product data sheet
19 / 24
74HC193; 74HCT193
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 17. Package outline SOT109-1 (SO16)
74HC_HCT193
Product data sheet
20 / 24
74HC193; 74HCT193
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 18. Package outline SOT403-1 (TSSOP16)
74HC_HCT193
Product data sheet
21 / 24
74HC193; 74HCT193
Nexperia
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT193 v.7
20210908
Product data sheet
74HC_HCT193 v.6
Modifications:
74HC_HCT193 v.6
20210205
Modifications:
74HC_HCT193 v.5
20160129
Modifications:
74HC_HCT193 v.4
20130624
Modifications:
74HC_HCT193 v.3
20070523
Modifications:
74HC_HCT193_CNV v.2
74HC_HCT193
Product data sheet
Section 2 updated.
Type number 74HCT193DB (SOT338-1/SSOP16) removed.
Product data sheet
74HC_HCT193 v.5
Type number 74HC193DB (SOT338-1/SSOP16) removed.
Section 7: Derating values for Ptot total power dissipation updated.
Product data sheet
74HC_HCT193 v.4
Type numbers 74HC193N and 74HCT193N (SOT38-4) removed.
Product data sheet
74HC_HCT193 v.3
74HC_HCT193_CNV v.2
General description updated.
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Family specification included.
19970828
Product specification
22 / 24
74HC193; 74HCT193
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT193
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
23 / 24
74HC193; 74HCT193
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Functional diagram.......................................................2
5. Pinning information......................................................4
5.1. Pinning.........................................................................4
5.2. Pin description............................................................. 4
6. Functional description................................................. 5
7. Limiting values............................................................. 7
8. Recommended operating conditions..........................7
9. Static characteristics....................................................8
10. Dynamic characteristics.......................................... 12
10.1. Waveforms and test circuit...................................... 16
11. Application information............................................19
12. Package outline........................................................ 20
13. Abbreviations............................................................ 22
14. Revision history........................................................22
15. Legal information......................................................23
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 8 September 2021
74HC_HCT193
Product data sheet
24 / 24
