A14696-04
A14696-04
    LAIRD(莱尔德)
    TPCM AL52 2 05 A0 12" X 18"
A14696-04 数据手册
T-pcm TM Al-52 (Formerly Thermaphase on Aluminum Foil) T-pcmTM A-l52 is a thermally conductive phase change material coated on both sides of aluminum foil. At temperatures greater than 52°C, T-pcmTM Al-52 changes into a molten state and, under low closure force, wets the heat sink and component surfaces to create a very thin, low thermal resistance interface. T-pcmTM Al-52 has great heat spreading characteristics and won’t flow from the interface. T-pcmTM Al-52 has superior thermal performance comparable to the highest performing grease and phase change products available. Since it is a free standing film it is easy to handle and is a great replacement for messy grease. T-pcmTM Al-52 is available as individual die cut parts, kiss cut parts on rolls or sheets, and uncut rolls. T-pcmTM Al-52 is available with or without adhesive. Typical Properties Color Thickness Inches (millimeters) Standard Coating Thickness per side Density Shelf Life UL Flammability Rating Maximum Use Temperature Phase Change Softening Temperature Thermal Impedance 5 psi 34.5 Kpa) Gray 0.003” (0.076mm) 0.0005” (0.013mm) 2.1 g/cc Indefinite 94 V0 200°C 52oC 0.03 oC-in2/ W 0.193 oC-cm2/W Thermaphase is a registered trademark of Laird Technologies, Thermal Products Division U.S. Patent Numbers 5,930,893 and 6,286,212 Cool Components make for Cool Products Our complete line of Thermal Interface Products can cool just about any application www.lairdtech.com Our customers are reminded that they bear the responsibility for testing Thermagon, Inc. materials for their proposed use. Any information furnished by Thermagon, Inc. and its agents is believed to be accurate and reliable, but our customers must bear all responsibility for the use and application of Thermagon, Inc. materials since Thermagon and its agents cannot be aware of all potential uses. Thermagon makes no warranties as to the fitness, merchantability, or suitability of any Thermagon, Inc. materials or products for any specific or general uses. Thermagon, Inc. shall not be liable for incidental or consequential damages of any kind. All Thermagon, Inc. products are sold pursuant to the Thermagon, Inc. domestic terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. A14652-00 Rev. B 10/14/04 EO #5092
A14696-04 价格&库存
很抱歉,暂时无法提供与“A14696-04”相匹配的价格&库存,您可以联系我们找货
