GT30-300-300-0.23-0
GT30-300-300-0.23-0
    T-GLOBAL
    GT30 SHEET 300X300X0.23MM
GT30-300-300-0.23-0 数据手册
GT30 High Thermal Conductivity Glassfiber Reinforcement Features Natural tack Smooth surface & low thermal contact resistance Exceptional thermal performance at lower application pressures (20psi~400psi) Usable over a wide temperture range Simplified processing and reduced operating costs Complies with UL standards Properties Property GT30 Unit Test Method Colour Pink - Visual Reinforcement Fiberglass - - Thickness 0.23 (mm) - Op. Temp. Range -45 to 180 ˚C - Density 2.8 g/cm ASTM D792 Thermal Conductivity 3.0 W/mK ASTM D5470 Hardness 80 Shore A ASTM D2240 3 Breakdown Voltage AC 3000 V ASTM D149 Breakdown Voltage DC 5000 V ASTM D149 Dielectric Constant 6.0 1000 Hz ASTM D150 Thermal Impedance t=0.23mm ˚C in 2/W 20psi 0.38 psi ASTM D5470 t=0.23mm 50psi 0.28 psi ASTM D5470 t=0.23mm 100psi 0.25 psi ASTM D5470 t=0.23mm 200psi 0.32 psi ASTM D5470 t=0.23mm 400psi 0.30 psi ASTM D5470 TML ‹ 0.2 % % ASTM E595 Tensile Strength 100 psi ASTM D412 Elongation 30 % ASTM D412 UL Flammability V-0 - UL 94 Limited Warranty High Thermal Conductivity Glassfiber Reinforcement is guaranteed against detachment, under normal use, for 5 years from the purchase date. User shall be solely responsible for determining the suitability of TIM for the intended use, and the user assumes all risks and liabilities whatsoever in connection there with. Neither seller nor manufacturer shall be liable either in tort or in contract for any loss damage, including loss of profits or revenue arising out of the use or the inability to use a product. Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
GT30-300-300-0.23-0 价格&库存
很抱歉,暂时无法提供与“GT30-300-300-0.23-0”相匹配的价格&库存,您可以联系我们找货
