Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
DATA SHEET
For a complete data sheet, please also download:
• The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Information
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines
74HC/HCT160
Presettable synchronous BCD
decade counter; asynchronous
reset
Product specification
File under Integrated Circuits, IC06
December 1990
Presettable synchronous BCD decade
counter; asynchronous reset
74HC/HCT160
input (PE) disables the counting action and causes the
data at the data inputs (D0 to D3) to be loaded into the
counter on the positive-going edge of the clock (providing
that the set-up and hold time requirements for PE are met).
Preset takes place regardless of the levels at count enable
inputs (CEP and CET).
FEATURES
• Synchronous counting and loading
• Two count enable inputs for n-bit cascading
• Positive-edge triggered clock
• Asynchronous reset
A LOW level at the master reset input (MR) sets all four
outputs of the flip-flops (Q0 to Q3) to LOW level regardless
of the levels at CP, PE, CET and CEP inputs (thus
providing an asynchronous clear function).
• Output capability: standard
• ICC category: MSI
GENERAL DESCRIPTION
The look-ahead carry simplifies serial cascading of the
counters. Both count enable inputs (CEP and CET) must
be HIGH to count. The CET input is fed forward to enable
the terminal count output (TC). The TC output thus
enabled will produce a HIGH output pulse of a duration
approximately equal to a HIGH level output of Q0. This
pulse can be used to enable the next cascaded stage.
The 74HC/HCT160 are high-speed Si-gate CMOS devices
and are pin compatible with low power Schottky TTL
(LSTTL). They are specified in compliance with JEDEC
standard no. 7A.
The 74HC/HCT160 are synchronous presettable decade
counters which feature an internal look-ahead carry and
can be used for high-speed counting.
Synchronous operation is provided by having all flip-flops
clocked simultaneously on the positive-going edge of the
clock (CP).
The outputs (Q0 to Q3) of the counters may be preset to a
HIGH or LOW level. A LOW level at the parallel enable
The maximum clock frequency for the cascaded counters
is determined by the CP to TC propagation delay and CEP
to CP set-up time, according to the following formula:
1
fmax = --------------------------------------------------------------------------------------------------------t P ( max ) ( CP to TC ) + t SU (CEP to CP)
QUICK REFERENCE DATA
GND = 0 V; Tamb= 25 °C; tr = tf = 6 ns
Notes
TYPICAL
SYMBOL PARAMETER
tPHL
tPLH
propagation delay
CP to Qn
CP to TC
MR to Qn
MR to TC
CET to TC
CONDITIONS
CL = 15 pF;
VCC = 5 V
propagation delay
CP to Qn
CP to TC
CET to TC
UNIT
HC
HCT
19
21
21
21
14
21
24
23
26
14
ns
ns
ns
ns
ns
19
21
14
21
ns
ns
ns
fmax
maximum clock
frequency
61
31
MHz
CI
input capacitance
3.5
3.5
pF
CPD
power dissipation
capacitance per
package
39
34
pF
December 1990
notes 1 and 2
2
1. CPD is used to determine the
dynamic power dissipation
(PD in µW):
PD = CPD × VCC2 × fi +
∑ (CL × VCC2 × fo)
where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of
outputs
CL = output load capacitance in
pF
VCC = supply voltage in V
2. For HC the condition is
VI = GND to VCC
For HCT the condition is
VI = GND to VCC − 1.5 V
74HC/HCT160
ORDERING INFORMATION
See “74HC/HCT/HCU/HCMOS Logic Package Information”.
PIN DESCRIPTION
PIN NO.
SYMBOL
NAME AND FUNCTION
1
MR
asynchronous master reset (active LOW)
2
CP
clock input (LOW-to-HIGH, edge-triggered)
3, 4, 5, 6
D0 to D3
data inputs
7
CEP
count enable input
8
GND
ground (0 V)
9
PE
parallel enable input (active LOW)
10
CET
count enable carry input
14, 13, 12, 11
Q0 to Q3
flip-flop outputs
15
TC
16
VCC
positive supply voltage
Fig.1 Pin configuration.
December 1990
Fig.2 Logic symbol.
3
Fig.3 IEC logic symbol.
74HC/HCT160
Fig.4 Functional diagram.
FUNCTION TABLE
INPUTS
OUTPUTS
OPERATING MODE
MR
CP
CEP
CET
PE
Dn
Qn
TC
reset (clear)
L
X
X
X
X
X
L
L
parallel load
H
H
X
X
X
X
I
I
I
h
L
H
L
count
H
h
h
h
X
count
(1)
hold
H
X
I
X
h
X
qn
(1)
(do nothing)
H
X
X
I
h
X
qn
L
(1)
Notes
1. The TC output is HIGH when CET is HIGH and the counter is at terminal count (HLLH).
H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition
L = LOW voltage level
I = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition
q = lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH CP
transition
X = don’t care
↑ = LOW-to-HIGH CP transition
December 1990
4
74HC/HCT160
Fig.6
Fig.5 State diagram.
Fig.7 Logic diagram.
December 1990
5
Typical timing sequence: reset outputs to zero;
preset to BCD seven; count to eight, nine, zero,
one, two and three; inhibit.
74HC/HCT160
DC CHARACTERISTICS FOR 74HC
For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”.
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL PARAMETER
+25
min. typ.
−40 to +85
max. min. max.
−40 to +125
min.
UNIT V
WAVEFORMS
CC
(V)
max.
tPHL/ tPLH
propagation delay
CP to Qn
61
22
18
185
37
31
230
46
39
280
56
48
ns
2.0
4.5
6.0
Fig. 8
tPHL/ tPLH
propagation delay
CP to TC
69
25
43
31
270
54
46
325
65
55
ns
2.0
4.5
6.0
Fig. 8
tPHL
propagation delay
MR to Qn
69
25
42
36
265
53
45
315
63
54
ns
2.0
4.5
6.0
Fig. 9
tPHL
propagation delay
MR to TC
69
25
44
37
275
55
47
330
66
56
ns
2.0
4.5
6.0
Fig. 9
tPHL/ tPLH
propagation delay
CET to TC
47
17
14
150
30
26
190
38
33
225
45
38
ns
2.0
4.5
6.0
Fig. 10
tTHL/ tTLH
output transition time
19
7
6
75
15
13
95
19
16
110
22
19
ns
2.0
4.5
6.0
Figs 8 and 10
tW
clock pulse width
HIGH or LOW
80
16
14
22
8
6
100
120
24
ns
2.0
4.5
6.0
Fig. 8
tW
master reset pulse width
LOW
80
16
14
28
10
8
100
120
24
ns
2.0
4.5
6.0
Fig. 9
trem
removal time
MR to CP
100
30
11
9
125
25
21
150
30
26
ns
2.0
4.5
6.0
Fig. 9
tsu
set-up time
Dn to CP
80
16
14
22
8
6
100
120
24
ns
2.0
4.5
6.0
Fig. 11
tsu
set-up time
PE to CP
135
27
23
41
15
12
170
34
29
205
41
35
ns
2.0
4.5
6.0
Fig. 11
December 1990
6
74HC/HCT160
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL PARAMETER
+25
min. typ.
−40 to +85
−40 to +125
max. min. max.
min.
WAVEFORMS
UNIT V
CC
(V)
max.
tsu
set-up time
CEP, CET to CP
200
40
34
63
23
18
250
50
43
300
60
51
ns
2.0
4.5
6.0
Fig. 12
th
hold time
Dn to CP
−17
−6
−5
ns
2.0
4.5
6.0
Figs 11 and 12
th
hold time
PE to CP
−41
−15
−12
ns
2.0
4.5
6.0
Figs 11 and 12
th
hold time
CEP, CET to CP
−58
−21
−17
ns
2.0
4.5
6.0
Figs 11 and 12
fmax
maximum clock pulse
frequency
6.0
30
35
18
55
66
4.8
24
28
4.0
MHz
2.0
4.5
6.0
Fig. 8
December 1990
7
74HC/HCT160
DC CHARACTERISTICS FOR 74HCT
ICC category: MSI
Note to HCT types
The value of additional quiescent supply current (∆ICC) for unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD COEFFICIENT
MR
0.95
CP
0.80
CEP
0.25
Dn
0.25
CET
1.05
PT
0.30
December 1990
8
74HC/HCT160
AC CHARACTERISTICS FOR 74HCT
Tamb (°C)
TEST CONDITIONS
74HCT
SYMBOL PARAMETER
+25
min. typ.
−40 to +85
max. min. max.
−40 to +125
min.
WAVEFORMS
UNIT V
CC
(V)
max.
tPHL/ tPLH
propagation delay
CP to Qn
25
43
54
65
ns
4.5
Fig. 8
tPHL
propagation delay
CP to TC
28
48
60
72
ns
4.5
Fig. 8
tPLH
propagation delay
CP to TC
23
39
49
59
ns
4.5
Fig. 8
tPHL
propagation delay
MR to Qn
27
50
63
75
ns
4.5
Fig. 9
tPHL
propagation delay
MR to TC
30
50
63
75
ns
4.5
Fig. 9
tPHL
propagation delay
CET to TC
17
35
44
53
ns
4.5
Fig. 10
tPLH
propagation delay
CET to TC
9
17
21
26
ns
4.5
Fig. 10
tTHL/ tTLH
7
15
19
22
ns
4.5
Figs 8 and 10
tW
clock pulse width
HIGH or LOW
16
8
ns
4.5
Fig. 8
tW
LOW
25
30
ns
4.5
Fig. 9
trem
removal time
MR to CP
25
30
ns
4.5
Fig. 9
tsu
set-up time
Dn to CP
18
10
25
30
ns
4.5
Fig. 11
tsu
set-up time
PE to CP
30
18
44
53
ns
4.5
Fig. 11
tsu
set-up time
CEP, CET to CP
50
30
63
75
ns
4.5
Fig. 12
th
hold time
Dn to CP
−8
ns
4.5
Figs 11 and 12
th
hold time
PE to CP
−13
ns
4.5
Figs 11 and 12
th
hold time
CEP, CET to CP
−21
ns
4.5
Figs 11 and 12
fmax
maximum clock pulse
frequency
16
28
13
11
MHz
4.5
Fig. 8
PACKAGE OUTLINES
See “74HC/HCT/HCU/HCMOS Logic Package Outlines”.
December 1990
9
很抱歉,暂时无法提供与“74HC160DB,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.691602000+0.34990
