74HC160DB,112
74HC160DB,112
    NEXPERIA(安世)
    SSOP16_208MIL
    IC SYNC BCD DECADE COUNTR 16SSOP
74HC160DB,112 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS DATA SHEET For a complete data sheet, please also download: • The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications • The IC06 74HC/HCT/HCU/HCMOS Logic Package Information • The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines 74HC/HCT160 Presettable synchronous BCD decade counter; asynchronous reset Product specification File under Integrated Circuits, IC06 December 1990 Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 input (PE) disables the counting action and causes the data at the data inputs (D0 to D3) to be loaded into the counter on the positive-going edge of the clock (providing that the set-up and hold time requirements for PE are met). Preset takes place regardless of the levels at count enable inputs (CEP and CET). FEATURES • Synchronous counting and loading • Two count enable inputs for n-bit cascading • Positive-edge triggered clock • Asynchronous reset A LOW level at the master reset input (MR) sets all four outputs of the flip-flops (Q0 to Q3) to LOW level regardless of the levels at CP, PE, CET and CEP inputs (thus providing an asynchronous clear function). • Output capability: standard • ICC category: MSI GENERAL DESCRIPTION The look-ahead carry simplifies serial cascading of the counters. Both count enable inputs (CEP and CET) must be HIGH to count. The CET input is fed forward to enable the terminal count output (TC). The TC output thus enabled will produce a HIGH output pulse of a duration approximately equal to a HIGH level output of Q0. This pulse can be used to enable the next cascaded stage. The 74HC/HCT160 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74HC/HCT160 are synchronous presettable decade counters which feature an internal look-ahead carry and can be used for high-speed counting. Synchronous operation is provided by having all flip-flops clocked simultaneously on the positive-going edge of the clock (CP). The outputs (Q0 to Q3) of the counters may be preset to a HIGH or LOW level. A LOW level at the parallel enable The maximum clock frequency for the cascaded counters is determined by the CP to TC propagation delay and CEP to CP set-up time, according to the following formula: 1 fmax = --------------------------------------------------------------------------------------------------------t P ( max ) ( CP to TC ) + t SU (CEP to CP) QUICK REFERENCE DATA GND = 0 V; Tamb= 25 °C; tr = tf = 6 ns Notes TYPICAL SYMBOL PARAMETER tPHL tPLH propagation delay CP to Qn CP to TC MR to Qn MR to TC CET to TC CONDITIONS CL = 15 pF; VCC = 5 V propagation delay CP to Qn CP to TC CET to TC UNIT HC HCT 19 21 21 21 14 21 24 23 26 14 ns ns ns ns ns 19 21 14 21 20 7 ns ns ns fmax maximum clock frequency 61 31 MHz CI input capacitance 3.5 3.5 pF CPD power dissipation capacitance per package 39 34 pF December 1990 notes 1 and 2 2 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz fo = output frequency in MHz ∑ (CL × VCC2 × fo) = sum of outputs CL = output load capacitance in pF VCC = supply voltage in V 2. For HC the condition is VI = GND to VCC For HCT the condition is VI = GND to VCC − 1.5 V Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 ORDERING INFORMATION See “74HC/HCT/HCU/HCMOS Logic Package Information”. PIN DESCRIPTION PIN NO. SYMBOL NAME AND FUNCTION 1 MR asynchronous master reset (active LOW) 2 CP clock input (LOW-to-HIGH, edge-triggered) 3, 4, 5, 6 D0 to D3 data inputs 7 CEP count enable input 8 GND ground (0 V) 9 PE parallel enable input (active LOW) 10 CET count enable carry input 14, 13, 12, 11 Q0 to Q3 flip-flop outputs 15 TC terminal count output 16 VCC positive supply voltage Fig.1 Pin configuration. December 1990 Fig.2 Logic symbol. 3 Fig.3 IEC logic symbol. Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 Fig.4 Functional diagram. FUNCTION TABLE INPUTS OUTPUTS OPERATING MODE MR CP CEP CET PE Dn Qn TC reset (clear) L X X X X X L L parallel load H H ↑ ↑ X X X X I I I h L H L count H ↑ h h h X count (1) hold H X I X h X qn (1) (do nothing) H X X I h X qn L (1) Notes 1. The TC output is HIGH when CET is HIGH and the counter is at terminal count (HLLH). H = HIGH voltage level h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition L = LOW voltage level I = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition q = lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH CP transition X = don’t care ↑ = LOW-to-HIGH CP transition December 1990 4 Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 Fig.6 Fig.5 State diagram. Fig.7 Logic diagram. December 1990 5 Typical timing sequence: reset outputs to zero; preset to BCD seven; count to eight, nine, zero, one, two and three; inhibit. Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 DC CHARACTERISTICS FOR 74HC For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: standard ICC category: MSI AC CHARACTERISTICS FOR 74HC GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 min. typ. −40 to +85 max. min. max. −40 to +125 min. UNIT V WAVEFORMS CC (V) max. tPHL/ tPLH propagation delay CP to Qn 61 22 18 185 37 31 230 46 39 280 56 48 ns 2.0 4.5 6.0 Fig. 8 tPHL/ tPLH propagation delay CP to TC 69 25 20 215 43 31 270 54 46 325 65 55 ns 2.0 4.5 6.0 Fig. 8 tPHL propagation delay MR to Qn 69 25 20 210 42 36 265 53 45 315 63 54 ns 2.0 4.5 6.0 Fig. 9 tPHL propagation delay MR to TC 69 25 20 220 44 37 275 55 47 330 66 56 ns 2.0 4.5 6.0 Fig. 9 tPHL/ tPLH propagation delay CET to TC 47 17 14 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig. 10 tTHL/ tTLH output transition time 19 7 6 75 15 13 95 19 16 110 22 19 ns 2.0 4.5 6.0 Figs 8 and 10 tW clock pulse width HIGH or LOW 80 16 14 22 8 6 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig. 8 tW master reset pulse width LOW 80 16 14 28 10 8 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig. 9 trem removal time MR to CP 100 20 17 30 11 9 125 25 21 150 30 26 ns 2.0 4.5 6.0 Fig. 9 tsu set-up time Dn to CP 80 16 14 22 8 6 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig. 11 tsu set-up time PE to CP 135 27 23 41 15 12 170 34 29 205 41 35 ns 2.0 4.5 6.0 Fig. 11 December 1990 6 Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 min. typ. −40 to +85 −40 to +125 max. min. max. min. WAVEFORMS UNIT V CC (V) max. tsu set-up time CEP, CET to CP 200 40 34 63 23 18 250 50 43 300 60 51 ns 2.0 4.5 6.0 Fig. 12 th hold time Dn to CP 0 0 0 −17 −6 −5 0 0 0 0 0 0 ns 2.0 4.5 6.0 Figs 11 and 12 th hold time PE to CP 0 0 0 −41 −15 −12 0 0 0 0 0 0 ns 2.0 4.5 6.0 Figs 11 and 12 th hold time CEP, CET to CP 0 0 0 −58 −21 −17 0 0 0 0 0 0 ns 2.0 4.5 6.0 Figs 11 and 12 fmax maximum clock pulse frequency 6.0 30 35 18 55 66 4.8 24 28 4.0 20 24 MHz 2.0 4.5 6.0 Fig. 8 December 1990 7 Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 DC CHARACTERISTICS FOR 74HCT For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: standard ICC category: MSI Note to HCT types The value of additional quiescent supply current (∆ICC) for unit load of 1 is given in the family specifications. To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below. INPUT UNIT LOAD COEFFICIENT MR 0.95 CP 0.80 CEP 0.25 Dn 0.25 CET 1.05 PT 0.30 December 1990 8 Philips Semiconductors Product specification Presettable synchronous BCD decade counter; asynchronous reset 74HC/HCT160 AC CHARACTERISTICS FOR 74HCT GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 min. typ. −40 to +85 max. min. max. −40 to +125 min. WAVEFORMS UNIT V CC (V) max. tPHL/ tPLH propagation delay CP to Qn 25 43 54 65 ns 4.5 Fig. 8 tPHL propagation delay CP to TC 28 48 60 72 ns 4.5 Fig. 8 tPLH propagation delay CP to TC 23 39 49 59 ns 4.5 Fig. 8 tPHL propagation delay MR to Qn 27 50 63 75 ns 4.5 Fig. 9 tPHL propagation delay MR to TC 30 50 63 75 ns 4.5 Fig. 9 tPHL propagation delay CET to TC 17 35 44 53 ns 4.5 Fig. 10 tPLH propagation delay CET to TC 9 17 21 26 ns 4.5 Fig. 10 tTHL/ tTLH output transition time 7 15 19 22 ns 4.5 Figs 8 and 10 tW clock pulse width HIGH or LOW 16 8 20 24 ns 4.5 Fig. 8 tW master reset pulse width LOW 20 11 25 30 ns 4.5 Fig. 9 trem removal time MR to CP 20 9 25 30 ns 4.5 Fig. 9 tsu set-up time Dn to CP 18 10 25 30 ns 4.5 Fig. 11 tsu set-up time PE to CP 30 18 44 53 ns 4.5 Fig. 11 tsu set-up time CEP, CET to CP 50 30 63 75 ns 4.5 Fig. 12 th hold time Dn to CP 0 −8 0 0 ns 4.5 Figs 11 and 12 th hold time PE to CP 0 −13 0 0 ns 4.5 Figs 11 and 12 th hold time CEP, CET to CP 0 −21 0 0 ns 4.5 Figs 11 and 12 fmax maximum clock pulse frequency 16 28 13 11 MHz 4.5 Fig. 8 PACKAGE OUTLINES See “74HC/HCT/HCU/HCMOS Logic Package Outlines”. December 1990 9
74HC160DB,112 价格&库存
很抱歉,暂时无法提供与“74HC160DB,112”相匹配的价格&库存,您可以联系我们找货
