TG4040S-100-100-1.0-0
    T-GLOBAL
    TG2030 SHEET 100X100X1MM
TG4040S-100-100-1.0-0 数据手册
TG4040S High Performance Thermal Interface Materials Features Low hardness Naturally tacky Lowoil bleed Applications Electronic components: IC / CPU / MOS LED / M/B / P/S / Heat Sink / LCD-TV / Notebook PC / PC / Telecom Device / Wireless Hub etc.... DDR II Module / DVD Applications / Hand-Set applications etc... Properties Property TG4040S Unit Test Method Colour Blue - Visual - Construction Silicone Gel - Optimum Temp. Range -45 to 200 ºC - Density 2.6 g/cm Thermal Conductivity 4.2 W/mK ASTM D5470 ASTM D792 Shore 00 20 - ASTM D2250 t=1.0mm Thermal impedance @10psi 0.55 2 K-in /W ASTM D575 t=1.0mm Thermal impedance @50psi 0.41 K-in2/W ASTM D575 t=1.0mm Thermal impedance @100psi 0.33 2 K-in /W ASTM D575 t=1.0mm Percent Deflection % @10psi 30 % ASTM D575 t=1.0mm Percent Deflection % @50psi 56 % ASTM D575 t=1.0mm Percent Deflection % @100psi 79 % ASTM D575 Breakdown Voltage 14 KV/mm ASTM D149 Volume Resistance 1012 Ohm-cm ASTM D257 3 Total Mass Loss ‹0.4 % ASTM E595 Tensile Strength 15 PSI ASTM D412 Elongation 50 % ASTM D412 Flammability Rating V-0 - UL 94 REACH/RoHS Compliant Yes - REACH / RoHS TML TESTING REPORT 150°C 24h Items A B VC Unit Before Baking After Baking Volatile g No.1 No. 2 No.3 8.0238 8.0609 8.7119 Testing Data No. 4 No. 5 8.5320 8.2350 Average 𝑉𝐶% = g 8.0087 8.0466 8.6946 8.5151 8.2190 - % 0.19 0.18 0.20 0.20 0.19 0.19 𝐴−𝐵 𝑋100%% 𝐴 Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TG4040S-100-100-1.0-0 价格&库存
很抱歉,暂时无法提供与“TG4040S-100-100-1.0-0”相匹配的价格&库存,您可以联系我们找货
