TG4040S-100-100-5.0-0 数据手册
TG4040S
High Performance Thermal Interface
Materials
Features
Low hardness
Naturally tacky
Lowoil bleed
Applications
Electronic components: IC / CPU / MOS
LED / M/B / P/S / Heat Sink / LCD-TV / Notebook PC / PC / Telecom Device / Wireless Hub etc....
DDR II Module / DVD Applications / Hand-Set applications etc...
Properties
Property
TG4040S
Unit
Test Method
Colour
Blue
Visual
Construction
Silicone Gel
Optimum Temp. Range
-45 to 200
ºC
Density
2.6
g/cm
Thermal Conductivity
4.2
W/mK
ASTM D5470
ASTM D792
Shore 00
ASTM D2250
t=1.0mm Thermal impedance @10psi
0.55
2
K-in /W
ASTM D575
t=1.0mm Thermal impedance @50psi
0.41
K-in2/W
ASTM D575
t=1.0mm Thermal impedance @100psi
0.33
2
K-in /W
ASTM D575
t=1.0mm Percent Deflection % @10psi
30
ASTM D575
t=1.0mm Percent Deflection % @50psi
56
ASTM D575
t=1.0mm Percent Deflection % @100psi
79
ASTM D575
Breakdown Voltage
14
KV/mm
ASTM D149
Volume Resistance
1012
Ohm-cm
ASTM D257
3
Total Mass Loss
‹0.4
ASTM E595
Tensile Strength
15
PSI
ASTM D412
Elongation
50
ASTM D412
Flammability Rating
V-0
UL 94
REACH/RoHS Compliant
Yes
REACH / RoHS
TML TESTING REPORT 150°C 24h
Items
A
B
VC
Unit
Before
Baking
After
Baking
Volatile
g
No.1
No. 2
No.3
8.0238
8.0609
8.7119
Testing Data
No. 4
No. 5
8.5320
8.2350
Average
𝑉𝐶% =
g
8.0087
8.0466
8.6946
8.5151
8.2190
0.19
0.18
0.20
0.20
0.19
0.19
𝐴−𝐵
𝑋100%%
𝐴
Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TG4040S-100-100-5.0-0 价格&库存
很抱歉,暂时无法提供与“TG4040S-100-100-5.0-0”相匹配的价格&库存,您可以联系我们找货
