PC94-300-300-0.25-0
PC94-300-300-0.25-0
    T-GLOBAL
    PC94 SHEET 300X300X0.25MM
PC94-300-300-0.25-0 数据手册
PC94 Non-Silicone Thermal Conductive Pad Version 3.160819 Non-Silicone Thermal Conductive Pad PC94 is a soft, non-silicone thermal interface pad designed to replace traditional thermal pads in silicone-sensitive applications. Typical uses include, set-top boxes, optical and automotive projects. PC94 can be provided in a range of different thicknesses and formats depending on the end use. Features Low contact thermal impedance Good thermal conductivity Silicone free Long term stability Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property PC94 Unit Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com VAT #: GB 116 662 714 Test Method Colour Red - - Visual Thickness (Available thickness range) 0.50 - 5.0 mm - ASTM D374 0.0098 - 0.1969 inch - ASTM D374 Thermal Conductivity 4.2 W/mK ± 10% ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 10.2 kV/mm - ASTM D149 Weight Loss ‹1 % - ASTM E595 Density 2.5 g/cm³ ± 0.2 ASTM D792 Working Temperature -30 to +125 ˚C - - Volume Resistance ›10 Ohm-cm - ASTM D257 Elongation 100 % - ASTM D412 Tensile Strength 2 Kgf/cm² - ASTM D412 Hardness 50 Shore 00 ± 10 ASTM D2240 10 Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tolerance Pressure (psi) R(°C-in²/W) Deflection (%) 10 0.75 23 20 0.64 34 40 0.31 43 PC94 Non-Silicone Thermal Conductive Pad Standard Weights & Dimensional Tolerance Size Thickness (mm) 0.50 0.80 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 100x100 12.50 20.00 25.00 37.50 50.00 62.50 75.00 87.50 100.00 112.50 125.00 253.13 281.25 150x150 28.13 45.00 56.25 84.38 112.50 140.63 168.75 196.88 225.00 300x300 112.50 180.00 225.00 337.50 450.00 562.50 675.00 787.50 900.00 1,012.50 1,125.00 320x320 128.00 204.80 256.00 384.00 512.00 640.00 768.00 896.00 1,024.00 1,152.00 1,280.00 * All measurements in mm Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com
PC94-300-300-0.25-0 价格&库存
很抱歉,暂时无法提供与“PC94-300-300-0.25-0”相匹配的价格&库存,您可以联系我们找货
