NJM4565
DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM4565 is a high-gain, wide-bandwidth, dual low noise
operational amplifier capable of driving 20V peak-to-peak into
400Ω loads. The NJM4565 is good characteristics compared to
the NJM4560.
■ FEATURES
● Operating Voltage
● Wide Gain Bandwidth Product
● Slew Rate
● Package Outline
● Bipolar Technology
( ±4V~±18V )
( 4MHz typ. )
( 4V/µs typ. )
DIP8, DMP8, EMP8, SSOP8, SIP8
■ PIN CONFIGURATION
NJM4565D
NJM4565M
NJM4565E
NJM4565V
■ PACKAGE OUTLINE
NJM4565D
NJM4565M
NJM4565E
NJM4565V
NJM4565L
NJM4565L
PIN FUNCTION
1.A OUTPUT
2.A –INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B –INPUT
7.B OUTPUT
8.V
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
Ver.2007-03-05
-1-
NJM4565
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
+ V /V
VID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 18
± 30
± 15 ( note )
( DIP8 ) 500
( DMP8 ) 300
( EMP8 ) 300
( SSOP8 ) 250
( SIP8 ) 800
-40~+85
-40~+125
UNIT
V
V
V
mW
˚C
˚C
( note ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS
( Ta=25˚C,V+/V-=±15V )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Input Resistance
Large Signal Voltage Gain
Maximum Output Voltage Swing 1
Maximum Output Voltage Swing 2
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Operating Current
Slew Rate
Equivalent Input Noise Voltage
-2-
SYMBOL
VIO
IIO
IB
RIN
AV
VOM1
VOM2
VICM
CMR
SVR
ICC
SR
GB
VNI
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
RL≥2kΩ
IO=25mA
RS≤10kΩ
RS≤10kΩ
RIAA,RS=2.2kΩ,30kHz LPF
MIN.
0.3
86
± 12
± 10
± 12
70
76.5
TYP.
0.5
2
50
5
100
± 14
± 11.5
± 14
90
90
4.5
4
10
1.2
MAX.
3.0
50
200
7
UNIT
mV
nA
nA
MΩ
dB
V
V
V
dB
dB
mA
V/µs
MHz
µVrms
Ver.2007-03-05
NJM4565
■ TYPICAL CHARACTERISTICS
Ver.2007-03-05
-3-
NJM4565
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2007-03-05
很抱歉,暂时无法提供与“NJM4565M”相匹配的价格&库存,您可以联系我们找货
