NJM13403D1
NJM13403D1
    NJR(新日本无线)
    DIP14
    IC OPAMP GP 4 CIRCUIT 14DIP
NJM13403D1 数据手册
NJM13403 SINGLE SUPPLY QUAD OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM13403 is single-supply quad operational amplifier, which can operate from 2V supply. The features are low offset voltage, low bias current, high slew-rate, and free crossover distortion through the AB class output stage. The package lineup is DIP, DMP and others compact, so that the NJM13403 is suitable for audio for low voltage operation and any other kind of signal amplifier. ■ FEATURES ● Operating Voltage ● Slew Rate ● Operating Current ● Bipolar Technology ● Package Outline ■ PACKAGE OUTLINE ( +2V~+14V ) ( 1.2V/µs typ. ) ( 3.0mA typ. ) DIP14,DMP14,EMP14,SSOP14 ■ PIN CONFIGURATION PIN FUNCTION 1.A OUTPUT 2.A –INPUT 3.A +INPUT + 4.V 5.B +INPUT 6.B –INPUT 7.B OUTPUT 8.C OUTPUT 9.C -INPUT 10.C +INPUT 11.GND 12.D +INPUT 13.D -INPUT 14.D OUTPUT ■ EQUIVALENT CIRCUIT ( 1/4 Shown ) Ver.2003-03-19 -1- NJM13403 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL + V VID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS 15 14 -0.3~+14 ( DIP14 ) 700 ( DMP14 ) 300 ( EMP14 ) 300 ( SSOP14 ) 300 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ■ ELECTRICAL CHARACTERISTICS ( V+=5V,Ta=25˚C ) PARAMETER Operating Voltage Input Offset Voltage Input Offset Current Input Bias Current Large Signal Voltage Gain Maximum Output Voltage Swing Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Output Source Current Output Sink Current Operating Current Slew Rate Unity Gain Bandwidth Total Harmonic Distortion -2- SYMBOL Vopr VIO IIO IB AV VOM VICM CMR SVR ISOURCE ISINK ICC SR fT THD TEST CONDITION RS=0Ω RL≥2kΩ RL=2kΩ + - VIN =1V,VIN =0V + VIN =0V,VIN =1V RL=∞ + V /V =±2.5V,RL=2kΩ, AV=0dB,f=1kHz RL=2kΩ RL=2kΩ, AV=40dB, f=20kHz,VO=1.0Vrms MIN. 2 88 4.0 0~3.5 70 80 20 10 - TYP. 0.5 5 25 100 4.2 90 94 35 30 3.0 MAX. 14 4 50 150 5.0 UNIT V mV nA nA dB V V dB dB mA mA mA - 1.2 - V/µs - 2.0 - MHz - 0.2 - % Ver.2003-03-19 NJM13403 ■ TYPICAL CHARACTERISTICS Ver.2003-03-19 -3- NJM13403 ■ TYPICAL CHARACTERISTICS -4- Ver.2003-03-19 NJM13403 ■ TYPICAL CHARACTERISTICS Ver.2003-03-19 -5- NJM13403 ■ TYPICAL CHARACTERISTICS -6- Ver.2003-03-19 NJM13403 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2003-03-19 -7-
NJM13403D1 价格&库存
很抱歉,暂时无法提供与“NJM13403D1”相匹配的价格&库存,您可以联系我们找货
