EM211806VL
EM211806VL
    EATON(伊顿)
    P=5.08mm
    接线端子 间距:5.08mm 1x6P 自由悬挂
EM211806VL 数据手册
Plug & Header EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks Series EM2118 Series Pluggable Terminal Block with Flanges; (Mates with EM2218 Series); 5.08 Centers SPECIFICATIONS: Rating: 16A, 300V EM211803H Center Spacing: 0.20" (5.08mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Phosphor Bronze Screw Size: M 2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Torque Rating: 7.0 lb-in. Construction: Mold-to-Length Dimensions - in (mm) Agency Information: File E62622; CE Certified EM211814VL Compliance References Edge Connectors, One-Sided Boards HORIZONTAL Poles L (mm) L (Inch) Poles L (mm) L (Inch) 2 3 4 5 6 7 8 9 10 11 12 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 71.12 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 13 14 15 16 17 18 19 20 21 22 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 0.71" (18.00) L 0.32" (8.20) 0.59" (15.0) Ø.11" (2.70) 0.10" (2.54) 0.20" (5.08) 0.39" (9.80) Ø.11" (2.70) VERTICAL 0.49" (12.5) L 0.20" (5.08) 0.10" (2.54) 1.02" (25.8) WIRE ENTRY WIRE ENTRY 0.32" (8.20) 0.32" (8.20) LEFT Part Numbering System En Mn 2n 1n 1n 8 qq n Series # of Positions 02 to 22 1.02" (25.8) RIGHT Inches (Millimeters) Orientation Wire Entry q q V - Vertical H - Horizontal L - Left wire entry R - Right wire entry (specify for V orientation) Mating Header: EM2218 pg. 98 For additional product information, visit www.eaton.com/connectors 96
EM211806VL
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现四路模拟信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN-16封装,尺寸为4x4mm。
EM211806VL 价格&库存
很抱歉,暂时无法提供与“EM211806VL”相匹配的价格&库存,您可以联系我们找货
EM211806VL
  • 100+37.79469100+4.89285
