EBJ26DMCN
EBJ26DMCN
    SULLINS
    CONN EDGECARD 52POS .150 SQ WW
EBJ26DMCN 数据手册
Female Card Edge .150” [3.81 mm] Contact Centers, .550” [13.97 mm] Insulator Height, Dip Solder/Wire Wrap Sullins Female Card Edge SPECIFICATIONS • • • • • • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board PBT, PPS or PA9T insulator Molded-in key available 3 Amps current rating for one contact energized 30 milli Ohms maximum at rated current UL Flammability Rating: 94V-0 READOUT POLARIZING KEY PLC-K1 .285” [7.24] EVEN NUMBER SIDE .150” [3.81] DUAL (D) .038” [0.97] .100” [2.54] KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) HALF LOADED (H) TERMINATION TYPE .620” [15.75] .025” [0.64] SQUARE POST, FITS Ø.040” [1.02] MINIMUM WIRE WRAP (MC) .220” [5.59] .025” [0.64] SQUARE POST, FITS Ø.040” [1.02] MINIMUM DIP SOLDER (SC) MOUNTING STYLE Ø.125” [3.18] #4-40 .250” [6.35] CLEARANCE HOLE (H) 68 THREADED INSERT (I) NO MOUNTING EARS (N) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .150” [3.81 mm] Contact Centers, .550” [13.97 mm] Insulator Height, Dip Solder/Wire Wrap PART NUMBER OPTIONS E B J 26 D MC H - Sxxx MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts N = No Mounting CONTACT FINISH - RoHS Compliant TERMINATION TYPE (Opposite Page) All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures Hairpin Bellows Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte MC = .025” [0.64 mm] Square Wire Wrap SC = .025” [0.64 mm] Square Dip Solder CONTACT CENTERS J = .150” [3.81 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual H = Half Loaded DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. REFER TO MOUNTING STYLE A B D E .297 [7.54] INSERTION DEPTH C .250 [6.35] .325 [8.26] .180 [4.57] .550 [13.97] REFER TO TERMINATION TYPE .150 [3.81] TYP. .150 [3.81] F 1 3 5 47 49 51 2 4 6 48 50 52 CONTACT MARKINGS 1 3 5 . . . 47 49 51 2 4 6 . . . 48 50 52 Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS INCHES MILLIMETERS A±.008 B±.008 C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 12/24 1.650 1.950 2.090 2.400 2.650 1.900 41.91 49.53 53.09 60.96 67.31 48.26 18/36* 2.550 2.850 2.990 3.300 3.550 2.800 64.77 72.39 75.95 83.82 90.17 71.12 22/44* 3.150 3.450 3.590 3.900 4.150 3.400 80.01 87.63 91.19 99.06 105.41 86.36 26/52 3.750 4.050 4.190 4.500 4.750 4.000 95.25 102.87 106.43 114.30 120.65 101.60 28/56* 4.050 4.350 4.490 4.800 5.050 4.300 102.87 110.49 114.05 121.92 128.27 109.22 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 69
EBJ26DMCN 价格&库存
很抱歉,暂时无法提供与“EBJ26DMCN”相匹配的价格&库存,您可以联系我们找货
