PKG.M0.2SL.LN
PKG.M0.2SL.LN
    LEMO(雷莫)
    PKG.M0.2SL.LN
PKG.M0.2SL.LN 数据手册
PKG.M0.2SL.LN www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 1P Termination type Female solder IP rating 50 AWG wire size 0.00 - 20.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts PAG.M0.2TL.AC65N Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PK*: Fixed receptacle with two nuts (back panel mounting) Keying 1 key (alpha=0; Plug: male contact; Receptacle: female contact) Housing Material PEI (Polyetherimide), gray Variant N : Black front nut Performance Configuration 1P.M02 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 1.3 mm (0.0512in) Bucket Dia.: 1.1 mm (0.04in) Max. Solid Conductor: 0.5 mm^2 (AWG 20) Max. Stranded Conductor: 0.5 mm^2 (AWG 20) R (max): 3.5 mOhm Test voltage (kV rms) Contact-contact: 1.2 Air clearance min.: 1.3 mm Creepage distance min.: 1.3 mm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): >2000 mating cycles Temp (min / max): -50°C / +170°C F ret (min): 50 N F ret (max): 150 N Steam sterilization: > 100 times (with potting on rear connection) DRAWINGS Dimensions A N a mm. 19.5 20.522.2 0-4.5 in. 0,77 0,81 0,00 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
PKG.M0.2SL.LN 价格&库存
很抱歉,暂时无法提供与“PKG.M0.2SL.LN”相匹配的价格&库存,您可以联系我们找货
