TARA5FX
TARA5FX
    SWITCHCRAFT
    TARA5FX
TARA5FX 数据手册
TOP HOUSING INSULATOR SOLDER TAB FOR GROUND TERMINAL PLUG ASSEMBLY FEMALE HOUSING SLIDE ASSEMBLY IN SEE NOTE 3 SEE NOTE 6 CONTACT WIRES 3 CONDUCTORS SHOWN SEE NOTE 5 SEE NOTE 7 CABLE CLAMP SEE NOTE 2 SEE NOTE 8 BOTTOM HOUSING CABLE GROUND WIRE TO SOLDER INTO FEMALE HOUSING TAB SEE NOTE 4 PART NUMBER SEQUENCE TARA _ F _ _ X PLUG HANDLE CONTACT PLATING BLANK - SILVER (STANDARD) AU - GOLD RIGHT ANGLE TINI QG CORD PLUG NO. OF CONTACTS 3 - 3 CONTACTS 4 - 4 CONTACTS 5 - 5 CONTACTS 6 - 6 CONTACTS 7 - 7 CONTACTS 8 - 8 CONTACTS BOOT 0.61 [15.4] 0.55 [14.0] 0.33 [8.3] FEMALE CABLE CLAMP SIZE (CABLE RANGE) D - [ 0.110 - 0.135] BLANK - [0.135 - 0.175] L - [ 0.175 - 0.205] 1.62 [41.0] 0.41 [10.4] 0.44 [11.2] 0.34 [8.6] 0.27 ID [6.9] 0.55 [13.9] INSTRUCTIONS: 1) CUT THE WIRES ACCORDINGLY AS SHOWN ABOVE. 2) RUN IT THROUGH INSULATOR AND SOLDER THE CONTACT WIRES TO THE PLUG ASSEMBLY. CONNECT THE INSULATOR TO THE PLUG ASSEMBLY. THE CONTACTS IN THE PLUG ASSEMBLY CAN WITHSTAND 2.0 LBS PULL OUT FORCE. 3) NOW SLIDE THE CONNECTED PLUG ASEMBLY, INSULATOR INTO THE TINI QG HOUSING. MAKE SURE THAT THE PLUG ASSEMBLY IS BUTTED UP AGAINST THE FRONT OF THE TINI QG HOUSING. 4) SOLDER THE GROUND TERMINAL WIRE TO THE TINI QG HOUSINGS'S LOWER THRU HOLE AS SHOWN. 5) SLIDE THE BOTTOM PLASTIC HOUSING UP TOWARDS THE FEMALE HOUSING. THIS HOUSING CAN BE INSTALLED 90 ORIENTATED OTHER WAY IF PREFERRED. 6) DROP AND SLIDE THE TOP RIGHT ANGLE HOUSING INTO THE GROVE SUCH AS IT LATCHES WITH THE BOTTOM PLASTIC AND FEMALE HOUSING. 7) SLIDE THE CABLE CLAMP THROUGH THE CABLE INTO THE TOP/BOT HOUSINGS AS SHOWN. 8) SCREW THE PLUG HANDLE TO 3 IN-LB MAX AND POP IN THE BOOT TO ASSEMBLE FULL PRODUCT. 0.91 CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 0.40 [10.2] 0.13 [3.2] 0.85 [21.6] GROUND TERMINAL WIRE WIRE STRIPPING DIMENSIONS SEE NOTE 1 1. ALL DIMENSIONS IN INCHES - TWO PLACE DECIMALS 0.01 - THREE PLACE DECIMALS 0.005 - ANGLES 1 - ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. 0D ADDED DIMENSIONS LAYOUT CHANGED 09/18/18 AM 0C ADDED PART NUMBERING SEQUENCE 09/25/17 AM * 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 0B EDITED LAYOUT 01/03/17 AM * 3. REMOVE ALL BURRS REV ECO NUMBER DATE REVISIONS BY * APVD DO NOT SCALE DRAWING SolidWorks CAD File SIZE WIDTH * FINISH SPEC No. FIRST USED ON DATE DRAWN 07/27/16 * * * AM TEMPER * * * MATERIAL SPEC No. * SCALE CHKD * * APVD * * NAME TINI QG, FEMALE RA RoHS B LBS/M * 1:1 * BY MULT ROUTING 146 112 SHEET PART No. 1 OF 1 TARA_FX SERIES_CD REV 0D
TARA5FX 价格&库存
很抱歉,暂时无法提供与“TARA5FX”相匹配的价格&库存,您可以联系我们找货
