8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
E
2565
ADDED 'R' & 'A' MATERIAL OPTION
4/6/2012
JH
2868
UPDATE 'BOM' ON PRODUCTION DRAWING, MIN HOLE
ON PCB
F
F
2X
E
F
11/26/2013
KV
D
C
B
A
.125 3.18
E
+.005
+0.13
.370
9.40
- .015
- 0.38
(.025 0.64 ) DEPTH
FROM TOP OF INSULATOR
TO TOP OF PIN
FITS EDGECARDS THAT
ACCEPT .062[1.57] PCB'S
A
D
D
.540±.010 13.72±0.25
.250 6.35
.030 0.76
.200 5.08
ROW SPACING
.025 0.64
A
_ _C_ _M_ _D
C
SECTION A-A
SCALE 3 : 1
MW = .125±.025 3.18±0.64
MS = .190 .025 [4.83 0.64]
MM = .560 .025 [14.22 0.64]
.100 2.54
C
C
.125 3.18
A
.100 2.54
.200 5.08
.100 2.54
B
B
.043 1.09 MIN (FOR 'MM' TERMINATION)
.040 [1.02] MIN (FOR 'MW' OR 'MS' TERMINATION)
RECOMMENDED PCB LAYOUT
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
8
7
6
5
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
_ _C_ _M_ _ _ (MW, MS, MM)
CAGE CODE
54453
SCALE: 4:1
3
A
MALE, EDGECARD, .100 CC
2
DWG. NO.
C11051
SHEET 1 OF 3
1
REV
F
FILE NAME: C11051, _ _C_ _M_ _ _, (MW, MS, MM)
8
7
F
4
5
6
2X #4-40
THREADED
INSERTS
E
1
2
3
C
F
E
E
_ _C_ _M_ _T
_ _C_ _M_ _N
D
D
2X
.125 3.18
C
C
C
C
2X
.125 3.18
.125 3.18
.125 3.18
B
B
2X #4-40
THREADED
INSERTS
_ _C_ _M_ _Z
_ _C_ _M_ _V
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
3
A
2
DWG. NO.
C11051
SHEET 2 OF 3
1
REV
F
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11051
SHEET 3 OF 3
1
REV
F
很抱歉,暂时无法提供与“ECC28MMMD”相匹配的价格&库存,您可以联系我们找货
