DESCRIPTION: M12 FEMALE - CABLE MOUNT - 4 POS.
SPECIFICATIONS:
ELECTRICAL:
RATED CURRENT:
RATED VOLTAGE:
INSULATION RESISTANCE:
CONTACT RESISTANCE:
WATER PROOF:
4A
250V
100 MOhms MIN.
10 mOhms MAX.
IP67
MATERIAL:
HOUSING:
CONTACT:
NUT:
SHELL:
O-RING:
MAIN BODY:
GLAND:
GLAND CAGE:
GLAND NUT:
PBT UL94V-0, BLACK
BRASS
ALUMINUM ALLOY
ALUMINUM ALLOY
EPDM, BLACK
ALUMINUM ALLOY
SILICONE, BLACK
POM, WHITE
ALUMINUM ALLOY
FINISH:
CONTACT:
NUT:
SHELL:
MAIN BODY:
GLAND NUT:
GOLD PLATED OVER 50u" NICKEL
NICKEL PLATED
NICKEL PLATED
NICKEL PLATED
NICKEL PLATED
ENVIRONMENT
OPERATION TEMPERATURE:
-40°C TO +85°C
MAX WIRE AWG:
22 AWG
858-004-203RKTY
1 = GOLD FLASH
4 = 10u" GOLD
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
DRAWN:
M. SIGMON
DATE:
03/07/2016
UNITS = INCHES [MM]
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
1
858-004-203RKTY
4
很抱歉,暂时无法提供与“858-004-203RKT1”相匹配的价格&库存,您可以联系我们找货
