ERA.1S.408.CLL
www.lemo.com
SUMMARY
# Wires
High voltage
1
Image is for illustrative purpose only
Series
1S
Termination type
Female solder High-Voltage
IP rating
50
AWG wire size
30.00 - 22.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FFR.1S.408.CLAE61
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
8.29 g
Performance
Configuration
1S.408 : 1 High Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
6 Amps
Specifications
Contact Type: Solder
Test voltage (kV DC) 18
Test voltage (kV AC) 12.7
Rear of connector must be protected: ATUM
Creepage distance min.: 20.4 mm
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
E
L
M
e
mm.
14
7.5
29.9
1.5
M12x1.0
in.
0,55
0,30
1,18
0,06
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.1S.M12.4
2/3
3/3
很抱歉,暂时无法提供与“ERA.1S.408.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+473.234821+61.22015
- 10+402.2522710+52.03747
- 30+372.2604730+48.15758
- 50+359.0939050+46.45428
- 100+341.97237100+44.23935
- 250+320.59536250+41.47391
