TA4MSHF
TA4MSHF
    SWITCHCRAFT
    TA4MSHF
TA4MSHF 数据手册
4 1 3 5 1 3 2 1 2 4 2 7 1 5 1 6 1 6 2 4 2 5 2 5 3 4 PIN 3 PIN 7 6 3 3 4 8 7 PIN 6 PIN 5 PIN 3 4 8 PIN AS VIEWED FROM FRONT MATING VIEW MALE HOUSING MALE INSERT ASSEMBLY MALE INSULATOR CABLE CLAMP SPRING FLEX RELIEF TUBULAR INSULATOR HANDLE M ___ ____ SH ___ F TA ___ ___ ____ SPRING FLEX RELIEF TINI QG CORD PLUG NUMBER OF CONTACTS 3 - 3 CONTACTS 4 - 4 CONTACTS 5 - 5 CONTACTS 6 - 6 CONTACTS 7 - 7 CONTACTS 8 - 8 CONTACTS 0.62 15.8 REF 1.85 47.1 0.41 10.5 SHIELDED HANDLE 1.09 27.6 CONTACT PLATING BLANK - SILVER (STANDARD) AU - GOLD MALE TA3MSHF SHOWN 1. MATERIALS: HOUSING - COPPER ALLOY, NICKEL PLATED CONTACTS - COPPER ALLOY, SILVER OR GOLD PLATED INSERT - THERMOPLASTIC, DARK BROWN INSULATOR - THERMOPLASTIC, DARK BROWN CABLE CLAMP/GROUND TERMINAL - STEEL, ELECTRO-TIN PLATED TUBULAR INSULATOR - FISH PAPER HANDLE - COPPER ALLOY, NICKEL PLATED SPRING FLEX RELIEF - STAINLESS STEEL CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. NOTES: 2. THIS PRODUCT IS RoHS COMPLIANT. 0.24 6.2 FLEX RELIEF UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] SIZE WIDTH FINISH REV 27648 ECO NUMBER 01/28/16 DATE REVISIONS PC SPEC No. FIRST USED ON BY 07/15/09 TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME B LBS/M TEMPER MATERIAL DATE DRAWN A MULT BY BS SPEC No. SCALE 2:1 CHKD TJK 02/04/16 APVD TJK 02/04/16 MALE TINI QG SHIELDED W/ FLEX RELIEF, RoHS SHEET PART No. 1 OF TA_MSHF SERIES 1 REV A
TA4MSHF 价格&库存
很抱歉,暂时无法提供与“TA4MSHF”相匹配的价格&库存,您可以联系我们找货
TA4MSHF
    • 1+170.073531+22.01133
    • 10+144.5069510+18.70244
    • 25+135.4554525+17.53098
    • 50+128.9892450+16.69410
    • 100+122.83550100+15.89767
    • 300+113.68134300+14.71292
    • 500+109.66168500+14.19268
    库存:93
