NAU8224YG
NAU8224YG
    NUVOTON(新唐)
    WFQFN20_EP
    NAU8224YG
NAU8224YG 数据手册
NAU8224 3.1W Stereo Filter-Free Class-D Audio Amplifier with 2 wire interface gain control 1 GENERAL DESCRIPTION The NAU8224 is a stereo high efficiency filter-free Class-D audio amplifier, which is capable of driving a 4Ω load with up to 3.1W output power. This device provides chip enable pin with extremely low standby current and fast start-up time of 3.4ms. The NAU8224 features a highly flexible 2 wire interface with many useful gain settings. The gain can be selected from 24dB to -62dB (plus mute) by using 2 wire interface and GS pin. The NAU8224 is ideal for the portable applications of battery drive, as it has advanced features like 87dB PSRR, 91% efficiency, ultra-low quiescent current (i.e. 2.1mA at 3.7V for 2 channels) and superior EMI performance. It has the ability to configure the inputs in either single-ended or differential mode. NAU8224 is available in Miniature QFN-20 package. FEATURES  Low Quiescent Current: • 2.1mA at 3.7V for 2 channels • 3.2mA at 5V for 2 channels  Gain Setting with 2 wire interface and GS pin • 24dB to -62dB (plus mute) Applications  Notebooks / Tablet PCs  Personal Media Players / Portable TVs  MP3 Players  Portable Game Players  Digital Camcorders  Powerful Stereo Class-D Amplifier: • 2ch x 3.1W (4Ω @ 5V, 10% THD+N) • 2ch x 1.26W (4Ω @ 3.7V, 1% THD+N) • 2ch x 1.76W (8Ω @ 5V, 10% THD+N) • 2ch x 0.76W (8Ω @ 3.7V, 1% THD+N)     Low Output Noise: 20 µVRMS @0dB gain 87dB PSRR @217Hz Low Current Shutdown Mode Click-and Pop Suppression NAU8224 Datasheet Rev1.0 Page 1 of 34 Aug, 2012 INL IPL Left Gain Stage 24dB to -62dB and mute Left Driver Class D Modulator GS Current / Thermal Protection SCLK VSS SDIO INR IPR Right Gain Stage 24dB to -62dB and mute Class D Modulator Right Driver NAU8224 VDD EN Figure 1: NAU8224Block Diagram OUTRP 1 VDD 2 VSS OUTRN VDD OUTLN VSS 20 19 18 17 16 Pinout- QFN 20 (TOP VIEW) NAU8224 Stereo Class D QFN 20-Pin 15 OUTLP 14 VDD 13 SDIO 11 INL IPL 10 5 9 INR VSS SCLK 8 12 VDD 4 7 EN GS 3 6 NC IPR 2 Part Number Dimension Package Package Material NAU8224YG 4mm x 4mm QFN-20 Pb-Free NAU8224 Datasheet Rev1.0 Page 2 of 34 Aug, 2012 Pin Descriptions QFN Name Type 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 OUTRP VDD NC EN INR IPR GS VDD VSS IPL INL SCLK SDIO VDD OUTLP VSS OUTLN VDD OUTRN VSS Ex-Pad Analog Output Supply NC Digital Input Analog Input Analog Input Analog Input Supply Supply Analog Input Analog Input Digital Input Digital I/O Supply Analog Output Supply Analog Output Supply Analog Output Supply Analog Input Functionality Right Channel Positive BTL Output Power Supply No Connect Chip Enable (High = Enable; Low = PD) Right Channel Negative Input Right Channel Positive Input 5 Selectable Gain Setting (0dB / 6dB / 12dB / 18dB / 24dB) Power Supply Ground Left Channel Positive Input Left Channel Negative Input I2C Serial Clock I2C serial data Input & Output Power Supply Left Channel Positive BTL Output Ground Left Channel Negative BTL Output Power Supply Right Channel Negative BTL Output Ground Thermal Tab (must be connected to VSS, QFN-20 package, only) Notes 1. Pins designated as NC (Not Internally Connected) should be left as no-connection Table 1: NAU8224 Pin description NAU8224 Datasheet Rev1.0 Page 3 of 34 Aug, 2012 3 Electrical Characteristics Conditions: EN = VDD = 5V, VSS = 0V, Av = 12dB ZL = ∞, Bandwidth = 20Hz to 22kHz, TA = 25 °C Parameter Symbol Power Delivered Output Power (per channel) Pout Comments/Conditions ZL = 4Ω + 33µH THD + N = 10% ZL = 4Ω + 33µH THD + N = 1% ZL = 8Ω + 68µH THD + N = 10% ZL = 8Ω + 68µH THD + N = 1% Parameter Chip Enable (EN) Voltage Enable High Voltage Enable Low Input Leakage Current Thermal and Current Protection Thermal Shutdown Temperature Thermal Shutdown Hysteresis Short circuit Threshold Gain Setting Voltage Gain Differential Input Resistance NAU8224 Datasheet Rev1.0 Symbol VEN_H VEN_L Min VDD = 5.0V VDD = 3.7V VDD = 5.0V VDD = 3.7V VDD = 5.0V VDD = 3.7V VDD = 5.0V VDD = 3.7V Comments/Conditions VDD = 2.5V to 5.5V VDD = 2.5V to 5.5V Typ 3.1 1.57 2.46 1.26 1.76 0.95 1.41 0.76 Min Typ RIN Max Units 0.4 +1 V V µA 130 15 2.1 ILIMIT Tie GS to VSS GS Connect VSS through 100k ± 5% Tie GS pin to VDD GS Connect VDD through 100k ± 5% Floating Node AV = 24dB AV = 18dB AV = 12dB AV = 6dB AV = 0dB Page 4 of 34 Units W 1.4 -1 AV Max °C °C A 24 18 12 6 dB 0 35 70 140 280 558 kΩ Aug, 2012 Electrical Characteristics (continued) Conditions: EN = VDD = 5V, VSS = 0V, Av = 12dB, ZL = ∞, Bandwidth = 20Hz to 22kHz, TA = 25 °C Parameter Symbol Comments/Conditions Min Typ Max Units Normal Operation Quiescent Current Consumption IQUI Shut Down Current Oscillator Frequency Efficiency Start Up Time Output Offset Voltage Common Mode Rejection Ratio IOFF fOSC η Tstart VOS CMRR Click-and-Pop Suppression DC PSRR AC PSRR* Power Supply Rejection Ratio VDD = 3.7V VDD = 5V EN = 0 2.1 3.17 0.1 300 91 3.4 ±1 80 -72 fIN = 1kHz Into Shutdown (ZL=8Ω) A Weighted VDD = 2.5V to 5.5V VRIPPLE = 0.2Vpp@217Hz** VRIPPLE = 0.2Vpp@1KHz VRIPPLE = 0.2Vpp@10KHz fIN = 1kHz, ZL = 8Ω + 68µH *Measured with 0.1uF capacitor on VDD and Battery supply Symbol ±4 dBV 98 dB 87 dB 74 54 Channel Crosstalk Parameter mA mA µA kHz % msec mV dB -101 dB ** Measured with 2.2uF input capacitor. Comments/Conditions Min Typ Max Units Noise Performance Av = 0dB (A-weighted) Av = 6dB (A-weighted) Av = 12dB (A-weighted) Av = 18dB (A-weighted) Av = 24dB (A-weighted) 20 21 27 36 52 µVRMS The following setup is used to measure the above parameters VDD 0.47uF + + Audio Precision Output - NAU8224 ZL AUX0025 Low pass filter Audio Precision Input - 0.47uF NAU8224 Datasheet Rev1.0 Page 5 of 34 Aug, 2012 Digital Serial Interface Timing TSTAH TSDIOS TSDIOH TSTAH SDIO TSCKH TFALL SCLK TRISE TSCKL TSTAS TSTOS Two wire control mode timing Symbol Description Min Typ Max Unit TSTAH SDIO falling edge to SCLK falling edge hold timing in START / Repeat START condition 600 - - ns TSTAS SCLK rising edge to SDIO falling edge setup timing in Repeat START condition 600 - - ns TSTOS SCLK rising edge to SDIO rising edge setup timing in STOP condition 600 - - ns TSCKH SCLK High Pulse Width 600 - - ns TSCKL SCLK Low Pulse Width 1,300 - - ns TRISE Rise Time for all 2-wire Mode Signals - - 300 ns TFALL Fall Time for all 2-wire Mode Signals - - 300 ns TSDIOS SDIO to SCLK Rising Edge DATA Setup Time 100 - - ns TSDIOH SCLK falling Edge to SDIO DATA Hold Time 0 - 600 ns Digital Serial Interface Electrical Characteristics NAU8224 Datasheet Rev1.0 Page 6 of 34 Aug, 2012 Condition Min Typ. Max. Unit Input Leakage Current SCLK, SDIO -1 - +1 µA Input High Voltage VIH 0.7 VDD 5.5 V Input low Voltage VIL VSS 0.3 VDD V VOH (SCLK, SDIO) 0.9 VDD VDD = 5.5V V VOL (SCLK, SDIO) 0.2 VDD SDIO, SCLK; pull up resistor value Test Conditions V 50k IOL = 1 mA Ohm Absolute Maximum Ratings Condition Min Max Units -0.50 +5.50 V Industrial operating temperature -40 +85 °C Storage temperature range -65 +150 °C Analog supply CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely influence product reliability and result in failures not covered by warranty. Operating Conditions Condition Symbol Min Typical Max Units Analog supply range VDD 2.50 3.7 5.50 V Ground VSS NAU8224 Datasheet Rev1.0 Page 7 of 34 0 V Aug, 2012 5 Special Feature Description The NAU8224 offers excellent quantity performance as high efficiency, high output power and low quiescent current. It also provides the following special features. 5.1 Gain Setting with 2 wire interface control The NAU8224 has a GS pin, which can control five selectable gain settings (i.e. 0dB / 6dB / 12dB / 18dB / 24dB). GS Pin Configuration Internal Gain (dB) GS tie to VSS 24 GS connect to VSS through 100kΩ ± 5% resistor 18 GS tie to VDD 12 GS connect to VDD through 100kΩ ± 5% resistor 6 Floating (open node) 0 The NAU8224 provides 2 wire register programmable volume control in addition to the GS pin selectable gain selection. The possible gain values by using these two controls are listed in the table below: NAU8224 Datasheet Rev1.0 Page 8 of 34 Aug, 2012 VLCRTL[5:0 ] GAINDEC[4:0]=0x0 1 GAINDEC[4:0]=0x0 2 GAINDEC[4:0]=0x0 4 GAINDEC[4:0]=0x0 8 GAINDEC[4:0]=0x1 0 Reg 0x1B (GS pin set to 0dB position) (GS pin set to 6dB position) (GS pin set to 12dB position) (GS pin set to 18dB position) (GS pin set to 24dB position) 0x0 0 dB 6 dB 12 dB 18 dB 24 dB 0x1 -2 dB 4.1 dB 10.4 dB 17 dB Not used 0x2 -4 dB 2.2dB 8.8 dB 16 dB Not used 0x3 -6 dB 0.4 dB 7.1dB 15 dB Not used 0x4 -8 dB -1.6 dB 5.4 dB 13.7 dB Not used 0x5 -10 dB -3.5 dB 3.6 dB 12.4 dB Not used 0x6 -12 dB -5.6 dB 1.7 dB 10.9 dB Not used 0x7 -14 dB -7.5 dB -0.2 dB 9.4 dB Not used 0x8 -16 dB -9.5 dB -2 dB 7.9 dB Not used 0x9 -18dB -11.4 dB -3.9 dB 6.2 dB Not used 0xA -20dB -13.4 dB -5.8 dB 4.5 dB Not used 0xB -22dB -15.4 dB -7.8 dB 2.7 dB Not used 0xC -24dB -17.3 dB -9.7 dB 0.9 dB Not used 0xD -26 dB -19.3 dB -11.7 dB -0.9 dB Not used 0xE -28 dB -21.3 dB -13.6 dB -2.8 dB Not used 0xF -30 dB -23.3 dB -15.6 dB -4.7 dB Not used 0x10 -32 dB -25.3 dB -17.6 dB -6.6 dB Not used 0x11 -34 dB -27.3 dB -19.3 dB -7.3 dB Not used 0x12 -36 dB -29.1 dB -20.4 dB -7.3 dB Not used 0x13 -38 dB -30.7 dB -20.5 dB -7.2 dB Not used 0x14 -40 dB -32.2 dB -20.2 dB -7.1 dB Not used 0x15 -42 dB -33.7 dB -20 dB -7.1 dB Not used 0x16 -44 dB -35.1 dB -19.8 dB -7.1 dB Not used 0x17 -46 dB -36.6 dB -19.7 dB -7.1 dB Not used 0x18 -48 dB -36 dB -19.6 dB -7.0 dB Not used 0x19 -50 dB -35.2 dB -19.5 dB -7.0 dB Not used 0x1A -52 dB -34.6 dB -19.5 dB -7.0 dB Not used 0x1B -54 dB -34.2 dB -19.4 dB -7.0 dB Not used 0x1C -56 dB -33.9 dB -19.4 dB -7.0 dB Not used 0x1D -58 dB -33.7 dB -19.4 dB -7.0 dB Not used 0x1E -60dB -33.5 dB -19.4 dB -7.0 dB Not used 0x1F -62 dB -33.4 dB -19.3 dB -7.0 dB Not used 0x3F Mute Mute Mute Mute Mute NAU8224 Datasheet Rev1.0 Page 9 of 34 Aug, 2012 5.1.1 2-Wire-Serial Control and Data Bus (I2C Style Interface) The serial interface provides a 2-wire bidirectional read/write data interface similar to and typically compatible with standard I2C protocol. This protocol defines any device that sends CLK onto the bus as a master, and the receiving device as slave. The NAU8224 can function only as a slave device. An external clock drives the device, and in accordance with the protocol, data is sent to or from the device accordingly. All functions are controlled by means of a register control interface in the device. 5.1.2 2-Wire Protocol Convention All 2-Wire interface operations must begin with a START condition, which is a HIGH-to-LOW transition of SDIO while SCLK is HIGH. All 2-Wire interface operations are terminated by a STOP condition, which is a LOW to HIGH transition of SDIO while SCLK is HIGH. A STOP condition at the end of a read or write operation places the serial interface in standby mode. An acknowledge (ACK), is a software convention is used to indicate a successful data transfer. The transmitting device releases the SDIO bus after transmitting eight bits to allow for the ACK response. During the ninth clock cycle, the receiver pulls the SDIO line LOW to acknowledge the reception of the eight bits of data. Following a START condition, the master must output a device address byte. This consists of a 7-bit device address, and the LSB of the device address byte is the R/W (Read/Write) control bit. When R/W= 1, this indicates the master is initiating a read operation from the slave device, and when R/W=0, the master is initiating a write operation to the slave device. If the device address matches the address of the slave device, the slave will output an ACK during the period when the master allows for the ACK signal. SDIO SCLK STOP START START and STOP signals Not Acknowledge SDIO Acknowledge SCLK 8 1 9 2 ...7 Acknowledge and NOT Acknowledge NAU8224 Datasheet Rev1.0 Page 10 of 34 Aug, 2012 0 1 0 1 0 1 0 R/W Device Address Byte A7 A6 A5 A4 A3 A2 A1 A0 Control Address Byte D7 D6 D5 D4 D3 D2 D1 D0 Data Byte Slave Address Byte, Control Address Byte, and Data Byte 5.1.3 2-Wire Write Operation A Write operation consists of a two-byte instruction followed by a Data Byte. A Write operation requires a START condition, followed by a valid device address byte with R/W= 0, a valid control address byte, data byte, and a STOP condition. The NAU8224 is permanently programmed with “010 1010” (0x2A) as the Device Address. If the Device Address matches this value, the NAU8224 will respond with the expected ACK signaling as it accepts the data being transmitted into it. R/W Device Address = 0101010 0 SDIO 1 0 1 0 1 0 Device ACK 0=W Control (REG) Address = A7..A0 A7 A0 DATA BYTE = D7... D0 D7 A6...A1 START SCLK Device ACK 1 2 3 4 5 6 7 8 9 2 ...7 D0 D6...D1 8 1 Device ACK 9 STOP 8 1 9 2 ...7 Write Sequence 5.1.4 2-Wire Single Read Operation A Read operation consists of a three-byte Write instruction followed by a Read instruction of data byte. The bus master initiates the operation issuing the following sequence: a START condition, device address byte with the R/W bit set to “0”, and a Control Register Address byte. This indicates to the slave device which of its control registers is to be accessed. The NAU8224 is permanently programmed with “010 1010” (0x2A) as its device address. If the device address matches this value, the NAU8224 will respond with the expected ACK signaling as it accepts the Control Register Address being transmitted into it. After this, the master transmits a second START condition, and a second instantiation of the same device address, but now with R/W=1. After again recognizing its device address, the NAU8224 transmits an ACK, followed by a one byte value containing the data from the selected control register inside the NAU8224. During this phase, the master generates the ACK signaling with byte transferred from the NAU8224. NAU8224 Datasheet Rev1.0 Page 11 of 34 Aug, 2012 Device Address[6:0] = 0101010 SDIO Write ACK ACK REG Addr[7:0] Device ID [6:0] Read ACK 8 9 SCLK START 1 2 ….. 7 8 9 1 9 Repeat START 1 2 ….. 8 2 ….. 7 Host should not drive ACK right before host wants to issue STOP. Read Data[7:0] of REG “Addr” 1 2 ….. 8 9 STOP Read Sequence 5.1.5 2-Wire Timing The NAU8224 is compatible with serial clock speeds defined as “standard mode” with SCLK 0 - 100 kHz, and “fast mode” with SCLK 0 - 400 kHz. At these speeds, the total bus line capacitance load is required to be 400 pF or less. Open collector drivers are required for the serial interface. Therefore, the bus line rise time is determined by the total serial bus capacitance and the VDD pull-up resistors. The NAU8224 defaults to a weak pull up (typical 50 k ohm) for applications with no external pull up resistor. 5.2 Register Map The NAU8224 contains the registers as shown in the table below. Addr Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Default (Hex) GAINDEC[4:0] 04 1B Note (Hex) VOLCTRL[5] NAU8224 Datasheet Rev1.0 VOLCTRL[4] VOLCTRL[3] VOLCTRL[2] Page 12 of 34 VOLCTRL[1] VOLCTRL[0] 01 RO 00 RW Aug, 2012 5.3 Register Map Details 0x04:REGGAIN This register is a read only register and can be used to check the function of the GAIN pin. Bit Default Function when read ‘1’ GAINDEC[4] 0 24 dB Gain setting enabled GAINDEC[3] 0 18 dB Gain setting enabled GAINDEC[2] 0 12 dB Gain setting enabled GAINDEC[1] 0 6 dB Gain setting enabled GAINDEC[0] 0 0 dB Gain setting enabled 0x1B: VOLCTRL[5:0] This register can be used to adjust the output volume. Bit Default VOLCTRL[5] 0 Adjust Output Volume VOLCTRL[4] 0 Adjust Output Volume VOLCTRL[3] 0 Adjust Output Volume VOLCTRL[2] 0 Adjust Output Volume VOLCTRL[1] 0 Adjust Output Volume VOLCTRL[0] 0 Adjust Output Volume 5.4 Function when set to ‘1’ Device Protection The NAU8224 includes device protection for three operating scenarios. They are 1. 2. 3. 5.4.1 Thermal Overload Short circuit Supply under voltage Thermal Overload Protection When the device internal junction temperature reaches 130°C, the NAU8224 will disable the output drivers. When the device cools down and a safe operating temperature of 115°C has been reached for at least about 47ms, the output drivers will be enabled again. NAU8224 Datasheet Rev1.0 Page 13 of 34 Aug, 2012 5.4.2 Short Circuit Protection If a short circuit is detected on any of the pull-up or pull-down devices on the output drivers for at least 14µs, the output drivers will be disabled for 47ms. The output drivers will then be enabled again and check for the short circuit. If the short circuit is still present, the output drivers are disabled after 14µs. This cycle will continue until the short circuit is removed. The short circuit threshold is set at 2.1A. 5.4.3 Supply under Voltage Protection If the supply voltage drops under 2.1V, the output drivers will be disabled while the NAU8224 control circuitry still operates. This will avoid the battery supply to drag down too low before the host processor can safely shut down the devices on the system. If the supply drops further below 1.0V the internal power on reset activated and puts the entire device in power down state. 5.5 Power up and Power down Control When the supply voltage ramps up, the internal power on reset circuit gets triggered. At this time all internal circuits will be set to power down state. The device can be enabled by setting the EN pin high. Upon setting the EN pin high, the device will go through an internal power up sequence in order to minimize ‘pops’ on the speaker output. The complete power up sequence will take about 3.4ms. The device will power down in about 30µs, when the EN pin is set low. It is important to keep the input signal at zero amplitude or enable the mute condition in order to minimize the ‘pops’ when the EN pin is toggled. . NAU8224 Datasheet Rev1.0 Page 14 of 34 Aug, 2012 6 Typical Operating Characteristics Conditions: EN = VDD = 5V, VSS = 0V, Av = 12dB, ZL = ∞, Bandwidth = 20Hz to 22kHz, TA = 25°C, unless otherwise noted Efficiency(%) Efficiency Vs Output Power (VDD = 5.0V) 100 90 80 70 60 50 40 30 20 10 0 ZL=4Ω+33uH ZL=8Ω+68uH 0 1 2 3 Output Power(W) 4 Efficiency Vs Output Power (VDD = 3.7V) Efficiency(%) 100 90 80 70 60 50 40 30 20 10 0 ZL=4Ω+ 33uH ZL=8Ω +68uH 0 0.5 1 1.5 Output Power(W) NAU8224 Datasheet Rev1.0 2 Page 15 of 34 Aug, 2012 THD+N vs Frequency (VDD = 3.7V, ZL= 8Ω + 68uH) THD+N(%) 1 Pout 0.2W Pout 0.4W 0.1 0.01 0.001 20 200 2000 20000 Frequency(Hz) THD+N vs Frequency (VDD = 4.2V, ZL= 8Ω + 68uH) THD+N(%) 1 Pout 0.2W Pout 0.6W 0.1 0.01 0.001 20 200 2000 20000 Frequency(Hz) NAU8224 Datasheet Rev1.0 Page 16 of 34 Aug, 2012 THD+N vs Frequency (VDD = 5V, ZL= 8Ω + 68uH) THD+N(%) 1 Pout 0.2W Pout 1.2W 0.1 0.01 0.001 20 200 2000 20000 Frequency(Hz) THD+N vs Pout (VDD = 3.7V, ZL = 8Ω + 68uH) 100 f 100Hz f 1kHz f 6kHz THD+N (%) 10 1 0.1 0.01 0.001 0 0.5 1 1.5 Pout (W) NAU8224 Datasheet Rev1.0 Page 17 of 34 Aug, 2012 THD+N vs Pout (VDD = 4.2V, ZL= 8Ω + 68uH) 100 THD+N (%) 10 1 f 100Hz f 1kHz f 6kHz 0.1 0.01 0.001 0 0.5 1 Pout (W) 1.5 2 THD+N vs Pout (VDD = 5V, ZL=8Ω + 68uH) 100 THD+N (%) 10 1 f 100Hz f 1kHz f 6kHz 0.1 0.01 0.001 0 1 Pout (W) NAU8224 Datasheet Rev1.0 2 3 Page 18 of 34 Aug, 2012 THD+N vs Frequency (VDD = 3.7V, ZL= 4Ω + 33uH) 1 THD+N(%) Pout 0.2W Pout 0.8W 0.1 0.01 0.001 20 200 2000 20000 Frequency(Hz) THD+N vs Frequency (VDD = 4.2V, ZL= 4Ω + 33uH) THD+N(%) 1 Pout 0.2W Pout 1W 0.1 0.01 0.001 20 200 2000 20000 Frequency(Hz) NAU8224 Datasheet Rev1.0 Page 19 of 34 Aug, 2012 THD+N vs Frequency (VDD = 5V, ZL= 4Ω + 33uH) 1 THD+N(%) Pout 1.5W Pout 2W 0.1 0.01 0.001 20 200 2000 Frequency (Hz) 20000 THD+N vs Pout (VDD = 3.7V, ZL= 4Ω + 33uH) 100 THD+N (%) 10 1 f = 100Hz f = 1kHz f = 6kHz 0.1 0.01 0.001 0 1 2 3 Pout (W) NAU8224 Datasheet Rev1.0 Page 20 of 34 Aug, 2012 THD+N vs Pout (VDD = 4.2V, ZL= 4Ω + 33uH) 100 THD+N (%) 10 1 f = 100Hz f = 1kHz f = 6kHz 0.1 0.01 0.001 0 1 2 3 Pout (W) THD+N vs Pout (VDD = 5V, ZL= 4Ω + 33uH) 100 THD+N (%) 10 1 0.1 f = 100Hz f = 1kHz f = 6kHz 0.01 0.001 0 1 2 3 4 Pout (W) NAU8224 Datasheet Rev1.0 Page 21 of 34 Aug, 2012 Gain 0dB Gain 6dB Gain 12dB Gain 18dB Gain 24dB Gain vs Frequency 30 25 Gain (dB) 20 15 10 5 0 -5 -10 20 200 2000 20000 Frequency (Hz) Crosstalk vs Frequency 0 Left to Right Right to Left Level (dB) -20 -40 -60 -80 -100 -120 20 200 2000 20000 Frequency (Hz) NAU8224 Datasheet Rev1.0 Page 22 of 34 Aug, 2012 PSRR (dB) AC PSRR vs Supply Voltage 0 -10 -20 -30 -40 -50 -60 -70 -80 -90 -100 PSRR @Gain 0dB, 1KHz 2.5 3.5 4.5 5.5 6.5 Supply Voltage (V) PSRR (dB) AC PSRR vs Frequency 0 -10 -20 -30 -40 -50 -60 -70 -80 -90 -100 PSRR @ Gain 0dB 20 200 2000 20000 Frequency (Hz) NAU8224 Datasheet Rev1.0 Page 23 of 34 Aug, 2012 NAU8224 Datasheet Rev1.0 Page 24 of 34 Aug, 2012 SupplyVoltage vs SupplyCurrent 3.5 Supply Current(mA) 3 2.5 2 1.5 1 0.5 0 2.5 3.5 4.5 Supply Voltage (V) NAU8224 Datasheet Rev1.0 5.5 Page 25 of 34 Aug, 2012 7 7.1 Application Information Application diagram VDD 10uF 0.1uF 10uF Shutdown Control OUTRP 2 VDD 3 NC 4 EN 5 INR 0.47uF 6 Right Single ended input 1 VSS OUTLP VDD 14 NAU8224 Stereo Class D SDIO 13 QFN 20-Pin SCLK 12 INL 0.47uF VDD 15 0.1uF 10uF SDIO SCLK 11 0.47uF Left Single ended input IPR 7 GS 8 VDD 9 VSS 10 IPL VDD 20 VSS 19 OUTRN 18 VDD 17 OUTLN 16 0.1uF 0.47uF VDD VDD 100k OPTIONAL 10uF 0.1uF 100k OPTIONAL P.S. GS Pin – The 100kΩ resistors are optional. GS can be floating for internal gain setting = 0dB. Please refer Section 6.1 (Gain Setting) for the detailed explanation. NAU8224 Datasheet Rev1.0 Page 26 of 34 Aug, 2012 7.2 Component selection Coupling Capacitors An ac coupling capacitor (Cin) is used to block the dc content from the input source. The input resistance of the amplifier (Rin) together with the Cin will act as a high pass filter. So depending on the required cut off frequency the Cin can be calculated by using the following formula 𝐶𝐶𝑖𝑖𝑖𝑖 = 1/2𝜋𝜋𝑅𝑅𝑖𝑖𝑖𝑖 𝑓𝑓𝑐𝑐 Where 𝑓𝑓𝑐𝑐 is the desired cut off frequency of the High pass filter. Input Cin Amplifier Output Rin(Input Resistance) Bypass Capacitors Bypass capacitors are required to remove the ac ripple on the VDD pins. The value of these capacitors depends on the length of the VDD trace. In most cases, 10uF and 0.1uF are enough to get the good performance. 7.3 Layout considerations The NAU8224 QFN package uses an exposed pad on the bottom side of the package to dissipate excess power from the output drivers. This pad must be soldered carefully to the PCB for proper operation of the NAU8224. This pad is internally connected to Vss. A typical layout is shown below. NAU8224 Datasheet Rev1.0 Page 27 of 34 Aug, 2012 The PCB has to be designed in such a manner that it should have nine vias in 3x3 grid under NAU8224. The vias should have hole size of 12mil and a spacing of 30mils. The pad size of the vias is 24mils. The vias on the top side of the board should be connected with a copper pour that has an area of 2mm x 2mm, centered underneath the NAU8224. The nine vias should connect to copper pour area on the bottom of the PCB. It is preferred to pour the complete bottom side of the board with Vss. Also good PCB layout and grounding techniques are essential to get the good audio performance. It is better to use low resistance traces as these devices are driving low impedance loads. The resistance of the traces has a significant effect on the output power delivered to the load. In order to dissipate more heat, use wide traces for the power and ground lines. 7.4 Class D without filter The NAU8224 is designed for use without any filter on the output line. That means the outputs can be directly connected to the speaker in the simplest configuration. This type of filter less design is suitable for portable applications where the speaker is very close to the amplifier. In other words, this is preferable in applications where the length of the traces between the speaker and amplifier is short. The following diagram shows this simple configuration. OUTLP OUTLN NAU8224 outputs connected to speaker without filter circuit 7.5 Class D with filter In some applications, the shorter trace lengths are not possible because of speaker size limitations and other layout reasons. In these applications, the long traces will cause EMI issues. There are two types of filter circuits available to reduce the EMI effects. These are ferrite bead and LC filters. Ferrite Bead filter The ferrite bead filters are used to reduce the high frequency emissions. The typical circuit diagram is shown in the figure. Ferrite Bead OUTLP 1nF Ferrite Bead OUTLN 1 nF NAU8224 Datasheet Rev1.0 Page 28 of 34 Aug, 2012 NAU8224 outputs connected to speaker with Ferrite Bead filter The characteristic of ferrite bead is such that it offers higher impedance at high frequencies. For better EMI performance select ferrite bead which offers highest impedance at high frequencies, so that it will attenuate the signals at higher frequencies. Usually the ferrite beads have low impedance in the audio range, so it will act as a pass through filter in the audio frequency range. LC filter The LC filter is used to suppress the low frequency emissions. The following diagram shows the NAU8224 outputs connected to the speaker with LC filter circuit. RL is the resistance of the speaker coil. OUTLP L RL C OUTLN L C NAU8224 outputs connected to speaker with LC filter L Input Output R C Standard Low pass LCR filter The following are the equations for the critically damped (ζ = 0.707) standard low pass LCR filter 2𝜋𝜋𝑓𝑓𝑐𝑐 = 1 �√𝐿𝐿𝐿𝐿� 𝑓𝑓𝑐𝑐 is the cutoff frequency 𝜁𝜁 = 0.707 = NAU8224 Datasheet Rev1.0 𝐿𝐿 1 ∗� 𝐶𝐶 2𝑅𝑅 Page 29 of 34 Aug, 2012 The L and C values for differential configuration can be calculated by duplicating the single ended configuration values and substituting RL = 2R. 7.6 NAU8224 EMI performance The NAU8224 includes a spread spectrum oscillator for reduced EMI. The PWM oscillator frequency typically sweeps in a range of 300 kHz +/- 15 kHz in order to spread the energy of the PWM pulses over a larger frequency band. In addition, slew rate control on the output drivers allows the application of ‘filter less’ loads, while suppressing EMI at high frequencies. The below graph shows the EMI performance of NAU8224 with ferrite beads and speaker cable length of 30cm. NAU8224 Datasheet Rev1.0 Page 30 of 34 Aug, 2012 8 8.1 Package Dimensions QFN20L 4X4 MM^2, Pitch:0.50 MM TOP VI EW 15 BOTTOM VI EW 11 16 11 10 10 6 6 15 16 20 20 1 NAU8224 Datasheet Rev1.0 5 5 Page 31 of 34 1 Aug, 2012 9 Ordering Information Part Number Dimension Package Package Material NAU8224YG 4x4 mm QFN-20 Green NAU8224 _ _ Package Material: G = Pb-free Package Package Type: Y NAU8224 Datasheet Rev1.0 = 20-Pin QFN Package Page 32 of 34 Aug, 2012 REVISION HISTORY VERSION DATE PAGE DESCRIPTION Rev1.0 Aug, 2012 N/A Preliminary Revision Table 1: Revision History NAU8224 Datasheet Rev1.0 Page 33 of 34 Aug, 2012 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. NAU8224 Datasheet Rev1.0 Page 34 of 34 Aug, 2012
NAU8224YG 价格&库存
很抱歉,暂时无法提供与“NAU8224YG”相匹配的价格&库存,您可以联系我们找货
