AT-5210-TT-R
AT-5210-TT-R
    PUIAUDIO
    AUDIO PIEZO TRANSDUCER 1-60V TH
AT-5210-TT-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 18 1 ~ 60 10 120,000 30% 105 1,000 200 -40 ~ +105 -40 ~ +105 PA6 Sn PLATED COPPER 14 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED RATED CURRENT (MAX) UPDATE ROHS AND ADD MANUAL SOLDER NOTE PARTS DATE CODE 19I AND AFTER HAVE AN IMPROVED PIEZO DESIGN TO REDUCE POTENTIAL SHORT CIRCUITS WHEN PART IS MOUNTED VERTICALLY 11/22/2006 10/6/2008 12/17/2010 1/25/2019 B.R. B.R. M.L. 10/8/2019 M.V. 2003, Projects Unlimited Inc. mA pF D dBA Hz C C grams 23.2 4.3 1.5 26 2.5 15.4 130 51.5 1.6 120 54.6 22.85 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. MANUAL SOLDER ONLY. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-5210-TT-R.idw Designed by Date Checked by Date Approved by J.D. 11/22/2006 D.F. 11/22/2006 R.W. Date Drawn Date 11/22/2006 10/6/2008 AT-5210-TT-R Transducer (Piezo) Edition Sheet - 1/1
AT-5210-TT-R 价格&库存
很抱歉,暂时无法提供与“AT-5210-TT-R”相匹配的价格&库存,您可以联系我们找货
AT-5210-TT-R
    • 1+46.49779
    • 10+41.87404
    • 100+38.60410
    • 500+35.77153
    • 1000+29.03378
    库存:21
