15050VA-48M-EA-YY
15050VA-48M-EA-YY
    NMBTECHNOLOGIESCORPORATION
    FAN AXIAL 172X50.8MM 48VDC WIRE
15050VA-48M-EA-YY 数据手册
5920VL (150 X Ø172 X 50L) NMBTC.COM / 818.341.3355 General Specifications Expected Life Motor Protection: Failure Rate: 10% 25°C 100,000 Hours (D00) Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Outline Characteristic Curves inch Units: (mm) In H2O (Pa) Static Pressure .169 (8 F4.3± 0.2) LOT NO. 6.77 (F172) 6.38 (162.0± 0.6) NAME PLATE 2.1 (55 8 .5˚ ) Ps AIR 8. 2.1 ) .5˚ (55 P-Q Curve 1.00 250 25000 0.80 200 20000 0.60 150 15000 0.40 100 10000 0.20 50 5000 0.00 0 0 2 0 4 50 100 6 150 200 8 250 300 10 (m3/min) 350 CFM DC Axial Fans 11.8 min (300) ROTATION .55 (14.0) Air Flow 5.90 (150) .37 (9.4) .55 4-(14.0) 2.0 (50.8± 0.2) .37 (9.4) Panel Cut-outs Material 6 16 .54 6± 0. 5. (F1 94 51 ) 8. ) 6.3 ± 0.2 (F 62 (F1 8 ) 6.3 ± 0.2 62 .177 4 – (F4.5) (F1 2 (5 .18 5. 5˚ ) Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG22, +Red, -Black 2) .177 4 – (F4.5) .39 4 – () .55 4 – (14) .177 4 – (F4.5) 8 2.1 ˚) .5 (55 8 2.1 ˚) .5 (55 2.1 (55 8 .5˚) 5.75 (146) 5.75 (146) INLET SIDE OUTLET SIDE Rated Operating Current Input Speed Max. Max. Static Noise MODEL Voltage Voltage Power Air Flow Pressure Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 5920VL-07W-B10- DXX 48 36 ~ 56 0.28 13.44 5920VL-07W-B20- DXX 48 36 ~ 56 0.33 15.84 5920VL-07W-B30- DXX 48 36 ~ 56 0.37 5920VL-07W-B40- DXX 48 36 ~ 56 5920VL-07W-B50- DXX 48 5920VL-07W-B60- DXX 48 Rotation: Clockwise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 2550 194.5 5.51 .43 106 51.0 830 2850 213.2 6.04 .53 131 54.0 830 17.76 3150 236.5 6.70 .61 152 57.0 830 0.41 19.68 3350 251.0 7.11 .67 167 59.0 830 36 ~ 56 0.44 21.10 3500 263.3 7.46 .74 184 61.0 830 36 ~ 56 0.52 25.00 3750 283.1 8.02 .85 211 63.0 830 Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air X.X
15050VA-48M-EA-YY 价格&库存
很抱歉,暂时无法提供与“15050VA-48M-EA-YY”相匹配的价格&库存,您可以联系我们找货
