109R0812M4021
109R0812M4021
    SANYODENKI
    FAN80X25MM12VDCRBLS
109R0812M4021 数据手册
DC DC Fan San Ace 80 9R type DC Fan 80 mm sq. 80×80×25 mm Model 109R0812E401 is not certified. ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Yellow Sensor · Mass………………………………………… 110 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed SPL Operating temperature [V] [V] [A] [W] [min-1] [m3/min] [CFM] [Pa] [inchH2O] [dB (A)] [˚C] [h] 1.25 0.85 4.44 2.88 2.16 1.56 1.32 1.08 0.72 2600 2350 4500 3700 3400 2900 2600 2350 1850 0.92 0.83 1.5 1.31 1.2 1.03 0.92 0.83 0.65 32.5 29.3 53.0 46.3 42.4 36.4 32.5 29.3 23.0 28.4 22.5 80.4 57.8 48.0 35.3 28.4 22.5 14.7 0.114 0.09 0.323 0.232 0.193 0.142 0.114 0.09 0.059 26 23 40 35 34 29 26 23 20 -20 to +70 60000/60˚C (90000/40˚C) -20 to +60 40000/60˚C (70000/40˚C) -20 to +70 60000/60˚C (90000/40˚C) 7 to 13.8 0.25 0.17 0.37 0.24 0.18 0.13 0.11 0.09 0.06 20.4 to 26.4 0.2 4.8 4500 1.5 53.0 80.4 0.323 40 -20 to +60 40000/60˚C (70000/40˚C) 0.1 0.07 0.06 0.05 0.04 2.4 1.68 1.44 1.2 0.96 3400 2900 2600 2350 1850 1.2 1.03 0.92 0.83 0.65 42.4 36.4 32.5 29.3 23.0 48.0 35.3 28.4 22.5 14.7 0.193 0.142 0.114 0.09 0.059 34 29 26 23 20 -20 to +70 60000/60˚C (90000/40˚C) 0.1 4.8 4600 1.56 55.1 88.4 0.355 41 -20 to +60 0.06 2.88 3400 1.2 42.4 48.0 0.193 34 -20 to +70 109R0805F401 109R0805M401 109R0812G401 109R0812E401 109R0812S401 109R0812H401 109R0812F401 109R0812M401 109R0812L401 5 4.5 to 5.5 10.8 to 13.2 6 to 13.8 12 109R0824G401 109R0824S401 109R0824H401 109R0824F401 109R0824M401 109R0824L401 24 12 to 27.6 14 to 27.6 109R0848K401 48 109R0848S401 40.8 to 55.2 Max. airflow Max. static pressure Expected life 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) Note 1: Sensor and control options are available for selection. Refer to the table on p. 623. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 109R0805F401 109R0805M401 With pulse sensor Operating voltage range Operating voltage range (inch H O) (Pa) 0.125 0.050 0.025 0 0.40 0.14 40 5.5 V 5V 30 4.5 V 0.100 0.075 40 20 10 0.12 0.35 30 5.5 V 5V 4.5 V 0.10 0.08 20 Static pressure 0.150 0.16 Static pressure Static pressure 0.175 (inch H2O) (Pa) 2 50 0.06 0.04 10 0.5 0 10 20 1.0 30 Airflow 40 1.5 (m3/min) 50 (CFM) 0 0.30 0.25 0.20 0.15 0.10 0.05 0.02 0 With pulse sensor Operating voltage range (inch H O) (Pa) 2 0.200 109R0812G401 With pulse sensor 0 0.4 0 10 0.8 20 30 Airflow 1.2 (m3/min) 40 (CFM) 0 100 90 80 70 60 50 40 30 20 10 0 13.2 V 12 V 10.8 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0 (m3/min) 10 20 30 40 50 60 70 (CFM) Airflow CATALOG No. C1111B002 '21.9.IT 109 109R0812E401 109R0812S401 With pulse sensor Operating voltage range 109R0812H401 With pulse sensor Operating voltage range With pulse sensor Operating voltage range (inch H2O) (Pa) 0.30 0.25 80 13.8 V 60 0.20 0.15 0.10 0.05 0 12 V 40 20 6V 0 0.5 1.5 1.0 2.0 (m3/min) 0 10 20 30 40 50 60 70 (inch H2O) (Pa) 70 0.25 60 0.20 50 0.15 0.10 40 6V 30 20 0.05 10 0 0 0.5 10 109R0812M401 With pulse sensor 0.125 20 0.050 0.025 0 30 40 50 50 0.16 40 13.8 V 12 V 30 6V 10 0.5 0 10 20 0.050 6V 20 10 0 0.5 10 0.12 109R0812L401 1.0 30 40 0 1.5 (m3/min) 50 30 13.8 V 12 V 20 6V 10 0 0.4 0 (CFM) 0.8 20 10 109R0824S401 Operating voltage range 40 50 (CFM) 0.8 (m3/min) With pulse sensor 30 1.2 (m3/min) 40 0.10 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0 25 20 13.8 V 12 V 15 7V 10 5 0 0.2 0 (CFM) 0.4 10 5 Airflow With pulse sensor 30 (inch H2O) (Pa) 40 0.06 0.04 20 1.5 (m3/min) Operating voltage range 0.10 0.08 1.0 Airflow With pulse sensor Airflow 109R0824G401 0.075 0 0.02 0 13.8 V 12 V 30 (CFM) 0.14 20 40 0.100 0 1.5 (m3/min) (inch H2O) (Pa) 0.100 0.075 1.0 Operating voltage range Static pressure Static pressure 0.150 0.125 50 Airflow (inch H2O) (Pa) 0.175 0.150 0.025 0 (CFM) Operating voltage range 0.200 0.175 12 V Airflow 109R0812F401 0.200 13.8 V Static pressure Static pressure 0.35 100 Static pressure 0.40 Static pressure 0.30 (inch H2O) (Pa) 0.6 15 20 25 30 (CFM) Airflow 109R0824H401 With pulse sensor Operating voltage range With pulse sensor Operating voltage range (inch H2O) (Pa) 0.30 0.25 0.20 0.15 0.10 0.05 0 26.4 V 24 V 20.4 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0 (m3/min) (inch H2O) (Pa) 70 0.25 60 0.20 50 0.15 0.10 24 V 12 V 30 20 0.05 10 0 0 0.5 0 10 109R0824M401 With pulse sensor 20 0.16 0.050 0.025 0 40 27.6 V 24 V 30 12 V 20 10 50 0 0.5 10 20 27.6 V 24 V 30 0.075 0.050 12 V 20 10 0 0.5 0 (CFM) 10 0.12 109R0824L401 With pulse sensor 1.0 30 40 1.5 (m3/min) 50 Airflow CATALOG No. C1111B002 '21.9.IT (CFM) 0 30 40 50 (CFM) 0.8 (m3/min) With pulse sensor (inch H2O) (Pa) 30 27.6 V 24 V 20 12 V 0.06 0.04 20 1.5 (m3/min) Operating voltage range 40 0.10 0.08 1.0 Airflow 10 0.02 0 110 40 0.14 0.100 0.075 30 40 0.100 0 1.5 (m3/min) (inch H2O) (Pa) 50 Static pressure 0.125 1.0 Operating voltage range (inch H2O) (Pa) 0.150 0.125 50 Airflow Operating voltage range 0.175 0.150 0.025 Airflow 0.200 0.175 40 10 20 30 40 50 60 70 (CFM) 109R0824F401 0.200 27.6 V Static pressure Static pressure 0.35 0.30 100 90 80 70 60 50 40 30 20 10 0 Static pressure 0.40 Static pressure (inch H2O) (Pa) Static pressure DC DC Fan 80 mm sq. ■ Airflow - Static Pressure Characteristics 0 0.4 0 10 0.8 20 30 Airflow 1.2 (m3/min) 40 (CFM) 0.10 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0 25 20 27.6 V 24 V 15 14 V 10 5 0 0.2 0 5 0.4 10 15 0.6 20 Airflow 25 30 (CFM) 109R0848S401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) Static pressure 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 0.30 110 100 90 80 70 60 50 40 30 20 10 0 55.2 V 48 V 40.8 V 0.5 1.0 1.5 Static pressure 0.45 With pulse sensor DC Fan 80 mm sq. 109R0848K401 DC ■ Airflow - Static Pressure Characteristics 60 0.20 50 0.15 0.10 55.2 V 48 V 40 40.8 V 30 20 0.05 10 0 0 2.0 (m3/min) 0 10 20 30 40 50 60 70 70 0.25 0.5 0 (CFM) 10 Airflow ■ Dimensions (unit: mm) 20 1.0 30 1.5 (m3/min) 40 50 (CFM) Airflow (With ribs) 80±0.5 4-ø4.3±0.3 Mounting hole 71.5±0.3 25±0.5 (3) (3) +30 300 0 71.5±0.3 80±0.5 Lead wire AWG24 UL 1007 (10) Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 71.5±0.3 4-ø4.5 78.5 71.5±0.3 0 ø9 78.5 ■ Options Finger guards page: p. 584 Model no.: 109-049E, 109-049H, 109-049C Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1002G page: p. 592 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 111
109R0812M4021
物料型号:San Ace 80 9R型,例如109R0812E401。
器件简介:这是一款80×80×25 mm尺寸的直流风扇,具有塑料框架和塑料叶轮,具有UL 94V-0和UL 94V-1的阻燃等级。
引脚分配:红色为正极,黑色或蓝色为传感器线,黄色为负极。
参数特性: - 电机保护功能:包括锁定转子烧毁保护和反极性保护。 - 耐电压:在50/60 Hz,500 VAC下持续1分钟。 - 绝缘电阻:10 MΩ或更高。 - 声压级:在空气入口1米处测量。 - 存储温度:-30至+70°C(非凝结)。 - 重量:110克。
功能详解:风扇具有预期寿命表,不同型号的风扇在不同条件下的预期寿命不同。部分型号配备有脉冲传感器。
应用信息:适用于需要直流风扇的各种应用场景。
封装信息:提供了风扇的尺寸和安装孔的参考尺寸,以及通风口的尺寸。
109R0812M4021 价格&库存
很抱歉,暂时无法提供与“109R0812M4021”相匹配的价格&库存,您可以联系我们找货
