DC Fan
60×60×15 mm
San Ace 60 9P type
■ General Specifications
・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C,
rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 547.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black or Blue
Sensor
Yellow
・ Mass ……………………………………………… 60 g
■ Specifications
The models listed below have ribs and pulse sensors.
Rated voltage Operating voltage range Rated current Rated input
Model no.
[V]
109P0605H701
109P0605M701
109P0612K701
109P0612S701
109P0612H701
109P0612M701
109P0612B701
109P0624J701
109P0624S701
109P0624H701
109P0624M701
[V]
5
4.5 to 5.5
10.2 to 13.8
12
7 to 13.8
10.2 to 13.8
24
14 to 27.6
20.4 to 27.6
0.26
0.15
0.26
0.15
0.09
0.07
0.05
0.14
0.08
0.06
0.04
Rated speed
Max. airflow
[W]
[min-1]
[m³/min]
1.3
0.75
3.12
1.8
1.08
0.84
0.6
3.36
1.92
1.44
0.96
4100
3100
6500
5000
4100
3100
2200
6200
5000
4100
3100
0.4
0.3
0.62
0.48
0.4
0.3
0.21
0.61
0.48
0.4
0.3
[A]
[CFM]
14.1
10.6
21.9
17.0
14.1
10.6
7.42
21.5
16.9
14.1
10.6
Max. static pressure
[Pa]
[inchH²O]
38.2
22.6
99.3
58.8
38.2
22.6
11.7
86.5
58.8
38.2
22.6
SPL
Operating temperature Expected life
[dB (A)]
0.153
0.091
0.399
0.236
0.153
0.091
0.047
0.347
0.236
0.153
0.091
32
25
45
36
32
25
21
44
36
32
25
[˚C]
[h]
-20 to +70
60000/60˚C
-20 to +60
40000/60˚C
-20 to +70
60000/60˚C
-20 to +60
40000/60˚C
-20 to +70
60000/60˚C
The following sensor and control options are available for selection.
Available for all models. Without sensor
Lock sensor
■ Airflow - Static Pressure Characteristics
109P0605H701
109P0605M701
With pulse sensor
0.12
0.10
0.05
5.5 V
40
5V
30
4.5 V
0.10
0.08
5.5 V
5V
0.06
0.04
4.5 V
10
0.02
10
0.1
0.2
0.3
0.4
0 2 4 6 8 10 12 14 16
Airflow
風量
62
Static静圧
pressure
Static静圧
pressure
0.15
(inch H2O) (Pa)
(inch H2O) (Pa)
60
0.5 (m3/min)
(CFM)
With pulse sensor
Static静圧
pressure
(inch H2O) (Pa)
0.20
109P0612K701
With pulse sensor
4
0.2
6
0.3
0.4 (m3/min)
8 10 12 14
Airflow
風量
(CFM)
0.55
0.50
0.45
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
120
110
100
90
80
70
60
50
40
30
13.8 V
12 V
10.2 V
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8
10
15
風量
Airflow
25
(m3/min)
30 (CFM)
(inch H2O) (Pa)
(inch H2O) (Pa)
80
60
0.25
70
0.20
50
0.15
40
0.10
13.8 V
60
Static静圧
pressure
Static静圧
pressure
0.30
12 V
10.2 V
30
10
0 2 4 6 8 10 12 14 16 18 20
Airflow
風量
0.20
0.15
0.10
0.05
0.1 0.2 0.3 0.4 0.5 0.6 (m3/min)
109P0612B701
109P0612M701
With pulse sensor
0.16
13.8 V
40
12 V
30
7V
0.2
0.3
0.4
15
13.8 V
0.04
10
0.02
5
12 V
10.2 V
109P0624H701
2
4
6
Airflow
風量
8
10
0.2
6
0.3
0.4 (m3/min)
8 10 12 14
Airflow
風量
(CFM)
With pulse sensor
24 V
80
14 V
60
60
0.20
50
0.15
40
0.10
0.05
0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min)
5
10
15
Airflow
風量
25
(CFM)
80
70
27.6 V
24 V
14 V
30
(m3/min)
0 2 4 6 8 10 12 14 16 18 20 22 (CFM)
風量
Airflow
With pulse sensor
(inch H2O) (Pa)
0.16
40
0.14
50
27.6 V
40
24 V
30
14 V
2
Static静圧
pressure
Static静圧
pressure
0.05
100
0.10
0.30
27.6 V
40
0.10
10
(inch H2O) (Pa)
109P0624M701
With pulse sensor
(inch H2O) (Pa)
0.15
0.20
0.04
120
(CFM)
0.20
0.30
0.3 (m3/min)
0.2
0.1
0.40
10.2 V
0.06
Static静圧
pressure
Static静圧
pressure
Static静圧
pressure
0.06
12 V
109P0624S701
With pulse sensor
0.50
0.08
(CFM)
Airflow
風量
13.8 V
30
0.10
0.5 (m3/min)
(inch H2O) (Pa)
0.08
0.12
0.02
(inch H2O) (Pa)
40
0.14
109P0624J701
With pulse sensor
(inch H2O) (Pa)
50
(CFM)
With pulse sensor
DC Fan 60 mm sq.
109P0612H701
With pulse sensor
Static静圧
pressure
109P0612S701
DC
0.12
27.6 V
30
0.10
0.08
24 V
20.4 V
0.06
0.04
10
0.02
0.1
0.2
0.3
0.4
0.5 (m3/min)
Airflow
風量
(CFM)
4
0.2
6
0.3
0.4 (m3/min)
8 10 12 14
Airflow
風量
(CFM)
63
■ Dimensions (unit: mm)
+1
60 0
(4)
50±0.3
(4)
Lead
wire
リード線
AWG24
UL 1007
+50
300 0
50±0.3
+1
60 0
4-ø4.3±0.3
Mounting
取付用穴
hole
+1
15 0
(10)
Rotating
direction
回転方向
Airflow
direction
風吹出方向
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
4-ø4.5
58
50±0.3
58
50±0.3
3
ø6
■ Options
Finger guards
page: p. 532
Model no.: 109-139E, 109-139H
Resin filter kits
Model no.: 109-1003G
page: p. 540
Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI),
109-1003F30 (30PPI), 109-1003F40 (40PPI)
64
Resin finger guards
page: p. 539
很抱歉,暂时无法提供与“109P0624S7D01”相匹配的价格&库存,您可以联系我们找货
