9RF type
Reversible Flow Fan
■ Features
Reduces the required number of fans
・Wind direction of the fan can be switched so fewer fans are
required. It therefore contributes to reducing equipment costs
and saving space.
It is suitable for the ventilation of houses, beverage vending
machines, food display cases, LED lights, and other places
where multiple fans are used to blow air in opposite directions.
・Controlling of rotational speed and wind direction can be
performed by external PWM signals to deliver an appropriate
rotational speed, contributing to reducing noise and saving
energy.
Equivalent cooling performance in both directions
・It delivers approximately the same airflow and static pressure in
both blowing directions, so ventilation management is easy.
92 mm × 38 mm
φ
■ Specifications
The following nos. have PWM controls and pulse sensors.
Model no.
9RF0912P1H001
9RF0924P1H001
Operating Expected
Operating
PWM
Rated current Rated input Rated speed Max. airflow Max. static pressure SPL
Airflow Rated voltage
temperature
life
voltage range duty cycle
[A]
[W]
[min-1] [m3/min] [CFM] [Pa] [inchH2O] [dB(A)]
direction
[V]
(Note)
[h]
[V]
Forward
Reverse
Forward
Reverse
12
24
10.2 to 13.8
20.4 to 27.6
100
0.17
2.0
5,500
1.20
42.4
156
0.63
39
2.0
5,300
1.20
42.4
146
0.59
43
100
0.09
2.2
5,500
1.20
42.4
156
0.63
39
2.2
5,300
1.20
42.4
146
0.59
43
-20 to +70
40,000 / 60 ℃
(70,000 / 40 ℃)
Note PWM frequency: 25 kHz
Models with the following sensor specifications are also available as options:
Without sensor
Please contact us for availability of the following sensor specifications as it depends on the model:
Lock sensor
■ Common Specifications
□ Material ・・・・・・・・・・・・・・・・・・・・・・・・・・ Frame, Impeller: Plastics (Flammability: UL94V-0)
□ Expected life ・・・・・・・・・・・・・・・・・・・・・ Refer to specifications
(L10: Survival rate: 90% at 60 ℃, rated voltage, and continuously run in a free air state)
Expected life at 40 ℃ ambient is just reference value.
□ Motor protection system ・・・・・・・・・・ Current blocking function and reverse polarity protection
□ Dielectric strength ・・・・・・・・・・・・・・・・ 50 / 60 Hz, 500 VAC, 1 minute (between lead conductor and frame)
□ Sound pressure level (SPL) ・・・・・・・・ Expressed as the value at 1 m from air inlet side
□ Operating temperature ・・・・・・・・・・・・ Refer to specifications (Non-condensing)
□ Storage temperature ・・・・・・・・・・・・・・ -30 ℃ to +70 ℃ (Non-condensing)
ーBlack Sensor: Yellow Control: Brown
□ Lead wire ・・・・・・・・・・・・・・・・・・・・・・・・ +Red ○
□ Mass ・・・・・・・・・・・・・・・・・・・・・・・・・・・・・ Approx. 150 g
■ Airflow - Static Pressure Characteristics
Forward
(Pa)
PWM duty cycle 100%
→ Static pressure
160
0.60
0.55 140
0.50
0.45
Reverse
(inch H2O)
10.2 V / 20.4 V
120
0.40 100
0.35
80
0.30
0.25 60
0.20
40
0.15
0.10
0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3 / min)
5 10 15 20 25 30 35 40 45 50 (CFM)
→ Airflow
9RF0912P1H001
9RF0924P1H001
Voltage: 12 VDC / 24 VDC
(min-1)
6,000
5,500 min-1
4,000
2,000
Forward
Reverse
4,000
5,300 min-1
100 (%)
PWM duty cycle
9RF0912P1H001
9RF0924P1H001
PWM duty cycle 0%
13.8 V / 27.6 V
12 V / 24 V
10.2 V / 20.4 V
120
0.40 100
0.35
80
0.30
0.25
60
0.20
0.15
→ Airflow
9RF0912P1H001
9RF0924P1H001
■ PWM Duty - Speed Characteristics Example
Speed
0.45
0.05
0.50
0.10
(Pa)
160
0.60
0.55 140
13.8 V / 27.6 V
12 V / 24 V
→ Static pressure
(inch H2O)
φ
92 mm × 38 mm
■ PWM Input Signal Example
Input signal waveform
VIH = 4.75 to 5.25 V VIL = 0 to 0.4 V
VIH
T1
VIL
T1
When control terminal is open,
fan rotational speed is the same as when PWM duty cycle is 100%.
Either TTL input, open collector or open drain can be used for
PWM control input signal.
T
■ Example of Connection Schematic
DC fan input voltage
Inside of DC fan
10 kΩ
Control
PWM input signal
Isource
20 kΩ
Isink
■ Specifications for Pulse Sensors
Output circuit: Open collector
Rated voltage 12 V fan
VCE=+13.8 V max.
IC=5 mA max. [VOL=VCE (SAT)=0.6 V max.]
Inside of DC fan
Sensor
Pull-up resistor
Pull-up voltage
IC
Rated voltage 24 V fan
VCE=+27.6 V max.
Sensor output
(VCE)
Output waveform (Need pull-up resistor)
In case of steady running
T1 to 4≒ (1/4) T0
(One revolution)
T0
T1
VOH
VOL
0V
1
PWM duty cycle (%) = T ×100
PWM frequency 25 (kHz) =
T
Current source (Isource) = 1 mA max.(when control voltage is 0 V)
Current sink (Isink) = 1 mA max.(when control voltage is 5.25 V)
Control terminal voltage = 5.25 V max. (when control terminal is open)
T2
T1 to 4≒ (1/4) T0=60/4N (sec)
N=Fan speed (min-1)
T3
T4
■ Dimensions (unit: mm)
4-φ3.5±0.3
Mounting hole
300
+30
Airflow direction
(Forward)
Airflow direction
(Reverse)
89±0.5
Lead wire
AWG26
UL1007
(3.5)
7
85
0.
0.
85
7
(3.5)
38±0.5
φ92±0.5
Rotating direction (Forward)
Rotating direction (Reverse)
■ Reference Dimension of Mounting Holes and Vent Opening (unit: mm)
Impeller side, Nameplate side
45°
φ8
8
45°
4-φ3.5
85 50
0.
3
3.5
4-R
3
0.
85
■ Option (unit: mm)
Finger guard
Model: 109-1147
Surface treatment: Nickel-chrome plating (Color: silver)
3.5±0.5
3.5±0.3
φ1.6
(φ8
5)
.6
77
φ1.6
φ
18
75
+0.5
88.8 -1
3.5±0.5
φ
6
Notice
φ1.6
+1
4 0
Mass: 21 g
●Please read the "Safety Precautions" on our website before using the product.
●The products shown in this catalog are subject to Japanese Export Control Law. Diversion contrary to the law of exporting country is prohibited.
●For protecting fan bearings against electrolytic corrosion near strong electromagnetic noise sources,
we provide effective countermeasures such as Electrolytic Corrosion Proof Fans and EMC guards. Contact us for details.
3-33-1 Minami-Otsuka, Toshima-ku, Tokyo 170-8451, Japan TEL: +81 3 5927 1020
http://www.sanyodenki.com
The names of companies and/or their products specified in this catalog are the trade names, and/or trademarks and/or registered trademarks of such respective companies.
“San Ace” is a trademark of SANYO DENKI CO.,LTD.
CATALOG No. C1067B002 ‘17.1
Specifications are subject to change without notice.
很抱歉,暂时无法提供与“9RF0912P1H001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+378.62629
- 10+370.70136
- 50+359.57938
