FN385-6-..
FN385-6-..
    SCHAFFNER(夏弗纳)
    PWR ENT MOD RCPT IEC320-C14 PNL
FN385-6-.. 数据手册
DATA SHEET IEC Inlet Filters FN380 Versatile Filtered Power Entry Module Rated currents up to 6 A Approvals & Compliances Single or dual-fuse holder Fuses Ø6.3 x 32 mm Ø5 x 20 mm 2-pole rocker switch General purpose application Optional medical versions (B type) Performance indicators The FN 380 power entry module combines an IEC inlet, a mains filter with a single or dual fuse holder and a 2-pole rocker switch. Choosing FN 380 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, fuse options, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and Benefits Good conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Front or snap-in mounting Single or dual-fuse holder USA Ø6.3 x 32 mm or EU Ø5 x 20 mm fuses Technical Specifications 2-pole rocker switch 250 VAC, 50/60 Hz Operating frequency 50 to 400 Hz DC to 400 Hz Portable electrical and electronic equipment Rated currents 2 to 6 A @ 40°C max High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec EDP and office equipment Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Flammability corresponding to UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) 550,000 hours Function 2-pole, dark not illuminated Marking I - 0 Electrical specifications Inrush current 51 A 6,000 on-off operations according to UL 1054, TV 5 10,000 on-off operations according to ENEC Mechanical life 50,000 cycles Consumer goods Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical equipment Typical electrical schematic (single fuse) Typical electrical schematic (dual fuse) Switch ratings * Typical Applications Maximum continuous operating voltage Europe (ENEC) 6 A (4 A), 250 VAC* USA (UL) 6 A, 125 VAC; 4 A, 250 VAC; 1/10 HP Canada (CSA) 6 A, 125 VAC; 4 A, 250 VAC; 1/10 HP Value in () relates to the inductive current charge: cos φ=0.65 N' H H' J J' external connection required P' G G' I I' 2 IEC Inlet Filters Schaffner Group DATA SHEET 04. Jul 2022 Filter Selection Table Filter* Rated current Leakage current** Inductance*** Capacitance*** Resistance*** Fuses**** Weight @ 40°C (25°C) @ 230 VAC/50 Hz L Cx Cy R [A] [μA] [mH] [nF] [nF] [kΩ] [Qty] [g] FN 380-2-2 z 2 (2.4) 373 0.70 47 FN 380-4-2 z 4 (4.8) 373 0.30 47 2.2 1 55 2.2 1 FN 380-6-2 z 6 (7.2) 373 0.18 55 47 2.2 1 55 FN 382-2-2 z 2 (2.4) 373 FN 382-4-2 z 4 (4.8) 373 0.70 47 2.2 2 55 0.30 47 2.2 2 55 FN 382-6-2 z 6 (7.2) 373 0.18 47 2.2 2 55 FN 388-2-2 z FN 388-4-2 z 2 (2.4) 373 0.70 47 2.2 2 60 4 (4.8) 373 0.30 47 2.2 2 60 FN 388-6-2 z 6 (7.2) 373 0.18 47 2.2 2 60 FN 389-2-2 z 2 (2.4) 373 2.00 47 2.2 2 70 FN 389-4-2 z 4 (4.8) 373 0.80 47 2.2 2 70 FN 389-6-2 z 6 (7.2) 373 0.50 47 2.2 2 70 FN 382 B-2-2 z 2 (2.4) 2 0.70 47 1000 2 55 FN 382 B-4-2 z 4 (4.8) 2 0.30 47 1000 2 55 FN 382 B-6-2 z 6 (7.2) 2 0.18 47 1000 2 55 FN 385 B-2-2 z 2 (2.4) 2 2.00 47 1000 2 65 FN 385 B-4-2 z 4 (4.8) 2 0.80 47 1000 2 65 FN 385 B-6-2 z 6 (7.2) 2 0.50 47 1000 2 65 FN 389 B-2-2 z 2 (2.4) 2 2.00 47 1000 2 70 FN 389 B-4-2 z 4 (4.8) 2 0.80 47 1000 2 70 FN 389 B-6-2 z 6 (7.2) 2 0.50 47 1000 2 70 * Select the requested fuse holder for fuse EUR-1 or USA-1 (z). ** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. *** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% **** Filters are delivered without fuse. Product selector FN 380 / FN 382 / FN 385 3 IEC Inlet Filters Schaffner Group Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym FN 380/FN 382/FN 388 FN 385/FN 389 Mechanical Data FN 380/FN 382/FN 385 FN 388/FN 389 Connection designation Output terminal (Filter and Fuse) I I' J J' G' G H' H single fuse P' Output terminal (Switch) N' external connections Blade terminals of switch acc. DIN 46 244-A4.8-0.8 (do not connect by soldering) Panel cut out DATA SHEET 04. Jul 2022 4 IEC Inlet Filters Schaffner Group DATA SHEET Dimensions FN 380 FN 382 FN 385 FN 388 FN 389 Tolerances A 32 32 32 50 50 ±0.3 B 58 58 58 58 58 ±0.3 40 40 ±0.1 C D 51 51 61 51 61 F 5.5 5.5 5.5 5.5 5.5 Ø3.3 Ø3.3 H J 12.5 12.5 12.5 12.5 12.5 M R ≤2 R ≤2 R ≤2 R ≤2 R ≤2 ±0.1 N 55.9*/56.2** 55.9*/56.2** 55.9*/56.2** 55.9*/56.2** 55.9*/56.2** +0.2/-0 P 28.5 28.5 28.5 +0.2/-0 28.5 28.5 R M3 M3 S 90° 90° 9 9 U 9 9 9 * For a back panel thickness between 0.8 and 2.0 mm ** For a back panel thickness between 2.1 and 3.2 mm All dimensions in mm; 1 inch=25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. 04. Jul 2022 5 IEC Inlet Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 04. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN385-6-..
物料型号:FN380系列,包括FN380、FN382、FN385、FN388和FN389。
器件简介:FN380系列是一个多功能的过滤电源输入模块,提供高达6A的额定电流,可选择单或双保险丝座,以及2极摇臂开关。
引脚分配:文档中提供了详细的电气原理图,包括单保险丝和双保险丝配置。
参数特性:包括最大连续操作电压、操作频率、额定电流、高压测试电压、保护类别、温度范围、设计标准、耐燃性、MTBF、电气规格、机械寿命和开关额定值。
功能详解:FN380系列提供了良好的传导衰减性能,基于具有高饱和电阻和出色热性能的电感。提供了前部或卡入式安装选项,单或双保险丝座,以及2极摇臂开关。
应用信息:适用于便携式电子设备、消费品、EDP和办公设备、单相电源、开关电源、测试和测量设备以及医疗设备。
封装信息:提供了详细的尺寸数据和公差,以及IEC插头类型和连接定义。
FN385-6-.. 价格&库存
很抱歉,暂时无法提供与“FN385-6-..”相匹配的价格&库存,您可以联系我们找货
FN385-6-..
  • 1+364.583621+43.57432
  • 10+297.1712210+35.51732
  • 25+273.9878425+32.74649
  • 40+262.8109940+31.41066
  • 80+247.1606780+29.54016
  • 280+244.88035280+29.26762
库存:40
