FIT0333
FIT0333
    DFROBOT
    Module
    FLEXIBLE SOLAR PANEL (1.5V 250MA
FIT0333 数据手册
  Flexible Solar Panel (1.5v 250mA) SKU:FIT0333 INTRODUCTION Light, thin and versatile solar panel at 1.5V/250MA. Unlike regular solar panels, it is truly flexible to be bent, sewed or treated in the clothing to match any kind of surface line. A good choice for DIY enthusiasts in selecting an alternative power source. Clean energy, in a compact size and a versatile form. The black edges can be easily cut or sewed, and the solar panel is waterproof. APPLICATIONS    Travelling Business office Outdoor camping SPECIFICATION              Operating Voltage: 1.5V Operating Current: 250mA Open circuit voltage: 2.0V Short circuit current: 420mA Power: 0.5W Use of the environment: -40 Ԩ ~ 80 Ԩ Performance: corrosion, moisture Size: Length 165mm (plus black edges 195mm) X Width 38mm (plus black edges 58mm) X thickness 0.5mm. Weight: 18 g ± 2 grams. Packaging Material: durable, high transmittance ETFE film Adhesive: weather, high transmittance fast curing EVA film Battery Type: Flexible triple junction amorphous silicon thin film solar cells Note: The above refers to the electrical performance parameters measured under standard test conditions, namely: light intensity 1000W / ㎡, spectrum AM1.5, cell temperature 25 Ԩ. SHIPPING LIST  Flexible Solar Panel(1.5V 250mA) x1 Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-999.html 4-27-17
FIT0333 价格&库存
很抱歉,暂时无法提供与“FIT0333”相匹配的价格&库存,您可以联系我们找货
FIT0333
    • 1+358.990711+46.66763
    库存:1
