HSS-1595-GO
HSS-1595-GO
    MAGNASPHERECORP
    SPACER FOR HSS PRY TAMPER MAGNET
HSS-1595-GO 数据手册
MAGNASPHERE expands its L2 series HSS product line to include the revolutionary L2C series of next generation sensors that meet and exceed UL634 Level 2 High Security Standard for installations where concealed sensors are desired for both NEW security and aesthetics. ULI HIGH SECURITY LEVEL 2 CUL HIGH SECURITY THE INSIDER THREAT IS REAL. Experts agree that the most devastating threats to government and corporate security have come from employees who were deemed trusted insiders. Armed with simple magnets unscrupulous insiders can disable even triple-balanced BMS magnetic contacts while the system is unarmed, and enter undetected at a later time, leaving no evidence of tamper. © MAGNASPHERE CORP. MAGNASPHERE L2C HSS Technology Only concealed contact to meet UL 634 Level 2 High Security Standard Resists permanent contact welding (power surges, stun guns, lightning) Incorporates patented removal (pry) tamper circuit Single and dual alarm contacts available Installs in one inch diameter hole or standard ANSI door cut out ANSI model a retrofit / upgrade to old 2757 / 67 BMS contacts Compatible with all control panels Highest level of security for every installation Competitively priced American made, built with MAGNASPHERE switch technology www.MAGNASPHERE.com CONSTRUCTION AND TECHNICAL SPECIFICATIONS L2C-XXX-A (ANSI Cut Out) Housing: Brass Fully Epoxy Potted Assembly Max Current: 0.25 A Resistive Operating Temperature: -40° C to +80°C Max Power: 0.250 W Suitable for Indoor Use Max Voltage: 30 VDC Max Actuation Gap: 0.125” * Intended for Connection to UL Listed Compatible Control Panels Single or Dual Closed Loop Contacts Removal Tamper Circuit: Closed Loop Hermetically Sealed Switch Contacts PATENTED DESIGN Wire Lead Type: Solid Color-Coded Lead Wires, 22 AWG #RE 39731, #6603378, # 7944334 & Other Patents Pending TAMPER BRACKET SWITCH MODULE .62 " 2.5 " 4.125 " MAGNET MODULE 4 7/8 " 2x #8 3.374 .9 " 1 1/8 " 1 1/4 " 3 1/2 " 2x #8 .08 " TYP. 1 1/8 " B .9 " * 0.0625” for UL624 Level 2 installation 1 1/4 " 1/32" SPACER(s) AS NEEDED P/N: 1317 Detail B MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial, and federal government security markets. The HSS’s leading-edge technology aims to set new industry standards for high security sensors while providing an affordable and more effective alternative to reed-based security contacts. To learn more about the MAGNASPHERE® L2 HSS High Security Sensor visit www.MAGNASPHERE.com or call 262-347-0711. © MAGNASPHERE CORP. | 03-2012 L2S-XXX-A-SCHM DRAFT www.MAGNASPHERE.com CONSTRUCTION AND TECHNICAL SPECIFICATIONS L2C-XXX (1” Diameter Concealed) Housing: Switch – ABS, Magnet - Brass Fully Epoxy Potted Assembly Max Current: 0.25 A Resistive Operating Temperature: -40° C to +80°C Max Power: 0.250 W Suitable for Indoor Use Max Voltage: 30 VDC Max Actuation Gap: 0.125” * Intended for Connection to UL Listed Compatible Control Panels Single or Dual Closed Loop Contacts Removal Tamper Circuit: Closed Loop Hermetically Sealed Switch Contacts PATENTED DESIGN Wire Lead Type: Solid Color-Coded Lead Wires, 22 AWG #RE 39731, #6603378, # 7944334, # 8487726 & Other Patents Pending 1 3/4 2 X #8 FLAT HEAD (UNDERCUT SCREWS) #22 AWG x 12" (6 WIRES MAX) TAMPER BRACKET SWITCH MODULE MAGNET MODULE .98 SIZED TO FIT 1” HOLE 1.02 1 1/4 .08 1 1/8 A 2 5/8 .94 1 1/4 * 0.0625” for UL624 Level 2 installation 1/32" SPACER(s) AS NEEDED P/N: 1221 Detail A MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial, and federal government security markets. The HSS’s leading-edge technology aims to set new industry standards for high security sensors while providing an affordable and more effective alternative to reed-based security contacts. To learn more about the MAGNASPHERE® L2 HSS High Security Sensor visit www.MAGNASPHERE.com or call 262-347-0711. © MAGNASPHERE CORP. | 03-2012 L2S-XXX-A-SCHM DRAFT www.MAGNASPHERE.com How the HSS L2C Removal Tamper Circuit Works The MAGNASPHERE HSS L2C Series are the only concealed devices available on the market that incorporate a secure anti-tamper circuit. This patented feature is available on both the ANSI cut out and the 1” diameter recessed versions of the L2C. L2C-XXX-A Models for Use in Standard ANSI Door Cut Out (Refer to product sheet for visual graphics) The Tamper bracket, containing the tamper switch actuating magnet is inserted into the ANSI cutout first, and secured with screws to the ANSI mounting tabs. The Switch module is incorporated into the brass cover plate and contains the Magnasphere alarm switch(es) which are oriented toward the face of the Switch cover plate towards the corresponding actuation magnet mounted in the door, and the Magnasphere tamper switch which is oriented in the opposite direction toward the magnet in the Tamper bracket. The cover plate is secured to the Tamper bracket via mounting holes that are inboard on the cover and is secured to corresponding mounting holes in the Tamper bracket. Any attempt to access the switch or wiring will require removing the Switch module/cover plate. As this is removed, the Tamper switch is moved away from magnet in the stationary tamper bracket, which results in an alarm condition. This Tamper bracket – Switch module/cover plate arrangement is also ideal when the device requires a periodic test of the tamper circuit. The tester need only loosen the mounting screws on the Switch module / cover plate, pull the module out from its seated position and the alarm switch will activate for the test. L2C-XXX Models for 1” Diameter Recessed Installation (Refer to product sheet for visual graphics) NOTE: The Tamper device, containing the tamper switch actuating magnet is a tapered “cap” that adheres to the switch housing via double sided tape pads, and aligns the tamper magnet opposite the tamper switch. The taper allows the switch / tamper assembly to be inserted into the 1” diameter mounting hole. Attempts to remove the switch assembly, will result in the reverse taper “barbs” of the tamper cap engaging the inside edge of the door frame, and pulling the tamper cap tape pads loose from the switch module. As this tamper cap / magnet releases from the switch module, an alarm signal is generated. The L2C switch module has locking side clips that make it extremely difficult to remove the switch module without damaging it. Therefore, removal of the switch to test the tamper circuit is not recommended. If the L2C is used in wood or aluminum door frame installations that require a test of the tamper circuit, this can be accomplished by using a specially magnetized L2C Tamper Test Magnet (Magnasphere part number 1384). Simply open the door (which removes the L2C actuating magnet) and place the Tamper Test Magnet beneath the switch – this will cause activation of the tamper switch for the test. © MAGNASPHERE CORP. www.MAGNASPHERE.com BLK Closed Loop BLK PRY TAMPER BLU Closed Loop BLU Model L2C-111-A Contact State Shown with Magnet in Place Model L2C-101-A L2C-A Wiring Schematics ALARM ALARM BLK Closed Loop BLK AUX WHT PRY TAMPER Closed Loop WHT BLU Closed Loop BLU ALARM BLK Closed Loop BLK PRY TAMPER YEL YEL Closed Loop Model L2C-111 Contact State Shown with Magnet in Place Model L2C-101 L2C Wiring Schematics ALARM BLK Closed Loop BLK AUX WHT PRY TAMPER Closed Loop WHT YEL Closed Loop YEL © MAGNASPHERE CORP. www.MAGNASPHERE.com
HSS-1595-GO 价格&库存
很抱歉,暂时无法提供与“HSS-1595-GO”相匹配的价格&库存,您可以联系我们找货
