MXD6240AU
MXD6240AU
    MEMSIC(美新)
    SENSORTIPOVERAUTONOMOSVIBR
MXD6240AU 数据手册
Powerful Sensing Solutions www.memsic.com Accelerometers Inclinometers Magnetometers Flow Sensors Inertial Systems 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Accelerometers Patented Thermal Accelerometer Technology Part Number Thermal accelerometer uses heated gas as “proof mass” Typical Applications: • • • • • • • • • • • Inclination Sensing Electronic Stability Control Motorcycle Tip-Over Car Alarm Headlight Leveling Navigation Assist Digital Cameras Keystone Correction Display Orientation Platform Stabilization . . . and many more Axes Range Output (+/- g) NEW M XD6240AU 2 (XY) 8 1-pin NEW M XC6244AU 2 (XY) 8 I2C M XP7205V F 2 (XY) 5 SPI M XP7205V W 2 (XZ) 5 SPI M XR 7305V F 2 (XY) 5 Analog M XR 7250V W 2 (XZ) 5 Analog M XR 9150M Z 3 (XYZ) 5 Analog M XC6245XU 2 (XY) 2 I2C M XC6232xM P 2 (XY) 2 I2C M XC6255XU 2 (XY) 2 I2C M XC6255XC 2 (XY) 2 I2C M XC6235xQ B 2 (XY) 1.5 I2C M XC6232xEP 2 (XY) 1.5 I2C M XR 6500M P 2 (XY) 1.7 Analog M XR 9500M Z 3 (XYZ) 1.7 Analog M XR 7900CF 2 (XY) 1 Analog M XA2500EL 2 (XY) 1 Analog M XR 2999EL 2 (XY) 0.5 Analog NEW * Partial Product List – For more complete list go to: http://www.memsic.com/accelerometers/ 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com MEMSIC’s unique thermal technology uses heated gas molecules to detect acceleration and is the fundamental principle behind our accelerometer IC products.  This technology offers several advantages over the solid proof-mass structure, including: • • • • • • No measurable resonance (immunity to vibration) Virtually indestructible (50,000g shock tolerance) No stiction No detectable hysteresis Excellent zero-g offset stability Sensor & electronics integrated onto monolithic IC Sensitivity Offset Drift Bandwidth Noise (mg/ºC) (Hz) (mg rms) N/A (Tip Over Comparator, 8 prog. angles) Supply Voltage Size Temp. Comp. (V) (mm) (ON OFF) 2.7 – 5.5 3x3 On Vibration Filter Other Features 1024 c/g 0.1 11 1.5 2.7 – 5.5 3x3 On Prog Vibration Filter 800 c/g 0.1 29 2.7 4.5 - 5.2 5x5 On AEC-Q100 800 c/g 0.1 29 2.7 4.5 - 5.3 5.5 x 5.5 On AEC-Q100 0.25 V/g 0.3 27 3.1 4.5 - 5.3 5x5 On AEC-Q100 0.25 V/g 0.3 27 3.1 4.5 - 5.3 5.5 x 5.5 On AEC-Q100 0.15 V/g 1.0 17 2.5 2.7 - 3.6 7x7 On True 3-axis perf. 1024 c/g 0.1 11 1.5 2.7 – 3.6 3x3 On Low Offset T.C. 512 c/g 0.8 17 0.7 2.7 - 3.6 5x5 On Temp Output 64 c/g 0.3 10 0.6 2.5 - 5.5 3x3 On Low Cost 8-bit 64 c/g 0.6 10 0.9 2.5 - 5.5 1.2 x 1.7 On Ultra-small size 512 c/g 0.1 8 0.4 2.7 - 3.6 5x5 Off Temp Output 512 c/g 0.8 17 2.9 2.7 - 3.6 5.5 x 5.5 Off Temp Output 0.5 V/g 1.5 17 1.6 2.7 - 3.6 5x5 On 0.5 V/g 1.0 17 2.5 2.7 - 3.6 7x7 On True 3-axis perf. 0.9 V/g 0.1 19 1.3 4.5 - 5.3 5x5 Off AEC-Q100 0.5 V/g 0.4 17 0.8 3.0 - 5.5 5x5 Off Temp Output 1 V/g 0.4 17 0.8 3.0 - 5.3 5x5 Off Temp Output * For more complete info go to: http://www.memsic.com/accelerometers/ 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Magnetometers MEMSIC offers magnetic sensor components for high performance OEM applications, as well as rugged magnetic modules for applications where a turnkey solution is required. MEMSIC magnetometers are used in millions of cell phones and tablets, due to their exceptional noise, wide dynamic range, and low power consumption. MEMSIC’s family of magnetometer components are available in both dual-axis and three-axis versions. They are based on anisotropic magnetoresistive (AMR) Permalloy technology sensors, which have superior accuracy and response time characteristics, while consuming significantly less power than alternative technologies. The MEMSIC magnetometers are ideal for electronic compass, GPS navigation and magnetic field detection applications. MEMSIC simplifies sensor integration by providing calibration and Electronic Compass libraries, reducing design complexity and accelerating time-to-market. The Electronic Compass libraries provide a highly accurate tilt compensated electronic compass with calibration that supports MEMSIC’s latest generation of ultra low noise, low power magnetometers. High compass accuracy is enabled by the high performance and low noise of MEMSIC’s AMR sensors. These libraries leverage MEMSIC’s many years of experience as an IMU developer to provide a high performance Electronic Compass that will address the most demanding applications. Part Number Axes FSR Interface Sensitivity (+/- G) Noise Supply Voltage Supply Current* (mG rms) (V) (mA) M M C246xM T 2 6 I2C 4096 c/G 0.8 1.62 - 3.6 0.05 M M C328xM A 3 8 I2C 512 c/G 1.0 1.62 - 3.6 0.3 M M C5883M A 3 8 I2C 4096 c/G 0.6 1.62 - 3.6 0.1 M M C3416xPJ 3 16 I2C 2048 c/G 1.5 1.62 - 3.6 0.02 M M C3524xPJ 3 24 I2C 1024 c/G 2.0 1.62 - 3.6 0.02 M M C3530K J 3 30 I2C 1024 c/G 1.5 1.62 - 3.6 0.02 NEW * Measured @ 7 conv/sec 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Typical Applications: • • • • • • • Sleep Mode Size Automotive Qualified S/R Offset Nulling Call X Call X Mobile Handsets/Tablets Wearables Head-Mounted Displays PND‘s Electronic Compass Detecting small magnetic fields …and many more (mm) X 2x2 X 2x2 X 3x3 X 1.6 x 1.6 X X 1.6 x 1.6 X X 1.4 x 1.4 X 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Flow Sensors MEMSIC’s flow sensors offer class leading dynamic range, power consumption, ease-of-use and integration. These sensors are designed to serve the need for mass flow sensing in applications such as process control, HVAC, medical, chemical, food and beverage, natural gas metering, and others. The MEMS mass flow sensing technology offers many advantages over traditional diaphragm gas flow measurement, including but not limited to: • • • • • • • High rangeability (turn-down ratio) High accuracy Excellent low flow sensitivity Direct mass flow sensing Low pressure drop Very low power consumption No moving parts for long term reliability Flow Upstream Thermalsensor MEMSIC’s mass flow sensing module is based on patented MEMS thermal technology. Heater Downstream Thermalsensor We are pleased to introduce two flow sensor product lines: MFC2000 and MFM2000. The MFC2000 is a rugged flow sensor capable of high inlet pressure up to 8 bar and available in PPSU or Aluminum. The MFM2000 is a low pressure drop sensor intended for low pressure medical ventilation and natural gas metering applications and can be configured with different types of inlet and outlet. Both can be offered with I2C or SPI interface. Modular MFM2000 bi-directional flow sensor. MFC2000 bi-directional flow sensor. Flow Range Accuracy (SLM) (% m.v.) Pressure Drop (mbar) M FC2000 +/- 30 3% M FM 2070 +/-70 M FM 2100 M FM 2250 Part Number Oper. Mode Supply Voltage (mA) (V) 4 5 2.7 to 5.5 3% 1.5 5 2.7 to 5.5 +/- 100 3% 1.5 5 2.7 to 5.5 +/- 250 3% 6.4 5 2.7 to 5.5 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Differential Pressure Sensors MEMSIC’s new MDP200 product family of thermal differential pressure sensors has excellent performance for a wide variety of applications. Features include: • • • • • • • • +/- 500 Pa (Custom Range Available) Digital I2C 16 bit Resolution ±1.5% Accuracy Full Scale or +/- 3.0% of reading Barb Fittings or Manifold Mount Straight or Right Angle Pins > 0.25% Linearity Manifold Mount Straight Pins Barb Mount 90 Degree Pins The MDP200 has high accuracy, high stability, and is competitively priced. The MDP200 is perfect for medical, industrial, and HVAC applications. MEMSIC’s new MDP200 series product family is modular and highly configurable. This includes options for barb or manifold mount. Industrial Applications Part Number M DP200 Medical Applications Flow Range Accuracy (Pa) (% m.v.) +/-500 3% Output I2C/Analog Oper. Mode Supply Voltage (mA) (V) 5 2.7 to 5.5 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Inertial Measurement Units • • • • Patented SmartSensingTM Technology enables high accuracy and low bias drift Selection of 6-axis (gyro/accel) and 9-axis (gyro/accel/mag) sensor configurations Standard interfaces support remote mount (RS-232/422) and embedded (SPI/UART) applications Rugged enclosures for demanding environments and miniature modules for direct µP integration IMU800 Part Number IMU440 Gyro Range (+/- °/s) IMU350 Accel Mag Range Range (+/- g) (+/- G) Gyro Bias (°/hr) IMU380 Accel Interface Bias (µg) RS-232 10 RS-422 RS-232 10 RS-422 SPI 10 UART SPI 10 UART IMU800CA-200 200 2 - 3 IMU800CA-210 200 10 - 3 NEW IMU480ZA-400 400 8 - 5 NEW IMU480ZA-409 400 8 4 5 IMU440CA-200 200 4 - 10 10 RS-232 IMU440CA-400 400 10 - 20 10 RS-232 IMU380ZA-200 200 4 - 10 20 IMU380ZA-209 200 4 4 10 20 IMU380ZA-400 400 8 - 10 20 IMU380ZA-409 400 8 4 10 20 IMU350CA-300 300 3 - 12 50 IMU280ZA-200 200 4 - 30 50 NEW SPI UART SPI UART SPI UART SPI UART RS-232 RS-422 SPI UART Package Standalone Standalone Embedded Embedded IP66 Rated IP66 Rated Embedded Embedded Embedded Embedded Standalone Embedded Module 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Attitude Heading Reference Systems (AHRS) Inertial Navigation Systems (INS) • • • • Patented SmartSensingTM technology combines EKF algorithms to achieve highest accuracy Flexible AHRS and INS system configurations with internal and external GPS receiver options Standard interfaces support remote mount (RS-232/422) and embedded (SPI/UART) applications Rugged enclosures for demanding environments and miniature modules for direct µP integration AHRS500 Part Number AHRS380 INS380 NAV440 Attitude and Heading Reference System (AHRS) Attitude Heading Gyro Accel Mag Interface Accuracy Accuracy Range Range Range (°) (°) (+/- °/s) (+/- g) (+/- G) AHRS500CA-324 1.0 2.0 200 10 1 RS-232 RS-422 AHRS440CA-200 0.2 1.0 200 4 1 RS-232 AHRS440CA-400 0.2 1.0 400 10 1 RS-232 NEW AHRS380SA-200 0.2 1.0 200 4 4 NEW AHRS380SA-400 0.2 1.0 400 8 4 AHRS380ZA-200 0.2 1.0 200 4 4 AHRS380ZA-400 0.2 1.0 400 8 4 RS-232 RS-422 RS-232 RS-422 SPI UART SPI UART Package IP67 Rated IP66 Rated IP66 Rated Standalone Standalone Embedded Embedded Inertial Navigation Systems (GPS/INS) Part Number Position Velocity Attitude Heading GPS Interface Accuracy Accuracy Accuracy Accuracy Receiver (m CEP) (m/s) (°) (°) NAV440CA-200 2.5 0.4 0.2 1.0 NEW INS380SA-200 2.5 0.1 0.2 1.0 NEW INS380ZA-200 2.5 0.1 0.2 1.0 Internal RS-232 Package IP66 Rated RS-232 Standalone RS-422 SPI External Embedded UART Internal 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Inclinometers • • • • Patented SmartSensingTM technology enables high accuracy in static and dynamic conditions Programmable Tilt Alarm features for safety system applications Analog and digital interfaces for easy integration into control systems Selection of enclosures to support a wide variety of operating environments CXTLA01 Part Number CXTLA02-AL # Operating of Axes Condition CXTILT02-EC Range Resolution Output (+/- °) (° rms) Vin MTLT1xxD Interface Enclosure (V) NEW MTLT101D 2(XY) Dynamic 180 0.1 Digital 9-32 RS-232 IP67 Plastic NEW MTLT105D 2(XY) Dynamic 180 0.5 Digital 9-32 RS-232 IP67 Plastic NEW MTLT101S 2(XY) Static 180 0.1 Digital 9-32 RS-232 IP67 Plastic NEW MTLT105S 2(XY) Static 180 0.5 Digital 9-32 RS-232 IP67 Plastic NEW MTLT110S 2(XY) Static 180 1.0 Digital 9-32 RS-232 IP67 Plastic CXTILT02EC 2(XY) Static 75 0.05 Digital 8-30 RS-232 Aluminium CXTA02-AL-T 2(XY) Static 75 0.05 Analog 6-30 Analog Aluminium CXTA02-T 2(XY) Static 75 0.05 Analog 6-30 Analog CXTLA02-AL-T 2(XY) Static 20 0.03 Analog 6-30 Analog Aluminium CXTA01-T 1(XY) Static 75 0.05 Analog 6-30 Analog Nylon CXTLA02-T 2(XY) Static 20 0.03 Analog 6-30 Analog Nylon CXTLA01-T 1(XY) Static 20 0.03 Analog 6-30 Analog Nylon Nylon 2016 MEMSIC, Inc. Powerful Sensing Solutions www.memsic.com Inertial Systems Applications Precision Farming Mobile Surveying Stability Control Green Energy Ruggedized Construction Powerful Sensing Solutions www.memsic.com About Memsic Founded in 1997, MEMSIC is focused on the development of products and solutions based on highly differentiated MEMS technology. We combine this MEMS technology with system integration and algorithms to deliver Powerful Sensing Solutions, which enable our customers to develop world-class products for a wide range of industrial, automotive, avionics, medical and consumer applications. Customer Support: MEMSIC offers world-class support to help our customers achieve their design goals and reduce time to market. Our application engineers and experts are available to solve complex sensor designs, and to provide complete turnkey solutions. We also offer powerful design tools and evaluation systems for our products. Quality Certifications and Policies: MEMSIC‘s Quality Management System is certified to ISO 9001:2008 and to ISO/TS 16949:2009. The Environmental Management System is certified to ISO 14001:2004. Product/Process Change Notice (PCN) policy is in compliance with JESD46C. Product Discontinuance Notice (PDN) policy is in compliance with JESD48A. Corporate Locations: Corporate Headquarters: One Tech Drive, Andover MA 01810 Systems Division: 3180 De La Cruz Blvd., Santa Clara CA 95054 For a complete list of sales and distribution locations and contacts please see our web site. Learn more @ www.memsic.com 2016 MEMSIC, Inc. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: MEMSIC: IMU480ZA-409 IMU480ZA-209 MXD6240AU-B MXD6240AU
MXD6240AU 价格&库存
很抱歉,暂时无法提供与“MXD6240AU”相匹配的价格&库存,您可以联系我们找货
