456-490
456-490
    BIVAR
    Molded
456-490 数据手册
REV. E F H 0.100 [2.5mm] TYP. F T DESCRIPTION Engineering Update w/o Changes Removed Material Code 457 SERIES H T PART NO. 457-510 .510 (13.0) 457-530 .530 (13.5) 457-550 .550 (14.0) 457-570 .570 (14.5) 457-590 .590 (15.0) .490 (12.4) 457-610 .610 (15.5) 457-630 .630 (16.0) 457-650 .650 (16.5) 457-670 .670 (17.0) 457-690 .690 (17.5) REF. F Ø.250 [Ø6.4mm] Ø.045 [Ø1.1mm] TYP. 0.134 [3.4mm] TYP. 450 SERIES H PART NO. 450-050 .050 (1.3) 450-060 .060 (1.5) 450-070 .070 (1.8) 450-080 .080 (2.0) 450-090 .090 (2.3) 450-100 .100 (2.5) 450-110 .110 (2.8) 450-120 .120 (3.0) 450-130 .130 (3.3) 450-140 .140 (3.6) 450-150 .150 (3.8) 450-160 .160 (4.1) 450-170 .170 (4.3) 450-180 .180 (4.6) 450-190 .190 (4.8) 450-200 .200 (5.1) Ø.055 [Ø1.4mm] THRU with Lead-In, both ends T F .010 (.25) .015 (.38) .020 (.51) .025 (.64) .030 (.76) .035 (.89) .040 (1.0) .045 (1.1) .030(.76) .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) 455 SERIES H T PART NO. 455-200 .200 (5.1) 455-210 .210 (5.3) 455-220 .220 (5.6) 455-230 .230 (5.8) 455-240 .240 (6.1) 455-250 .250 (6.4) 455-260 .260 (6.6) 455-270 .270 (6.9) .150(3.8) 455-280 .280 (7.1) 455-290 .290 (7.4) 455-300 .300 (7.6) 455-310 .310 (7.9) 455-320 .320 (8.1) 455-330 .330 (8.4) 455-340 .340 (8.6) 455-350 .350 (8.9) F .025 (.64) .030 (.76) .035 (.89) .040 (1.0) .045 (1.1) .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) .090 (2.3) .095 (2.4) .100 (2.5) 456 SERIES T F H PART NO. 456-350 .350 (8.9) .025 (.64) 456-360 .360 (9.1) .030 (.76) 456-370 .370 (9.4) .035 (.89) 456-380 .380 (9.7) .040 (1.0) 456-390 .390 (9.9) .045 (1.1) 456-400 .400 (10.2) .050 (1.3) 456-410 .410 (10.4) .055 (1.4) 456-420 .420 (10.7) .060 (1.5) .300(7.6) 456-430 .430 (10.9) .065 (1.7) 456-440 .440 (11.2) .070 (1.8) 456-450 .450 (11.4) .075 (1.9) 456-460 .460 (11.7) .080 (2.0) 456-470 .470 (11.9) .085 (2.2) 456-480 .480 (12.2) .090 (2.3) 456-490 .490 (12.4) .095 (2.4) 456-500 .500 (12.7) .100 (2.5) DATE APPROVED 02/23/04 05/21/16 M. C. J. C. F .010 (.25) .020 (.51) .030 (.76) .040 (1.0) .050 (1.3) .060 (1.5) .070 (1.8) .080 (2.0) .090 (2.3) .100 (2.5) 458 SERIES F H T PART NO. 458-700 .700 (17.8) .010 (.25) 458-720 .720 (18.3) .020 (.51) 458-740 .740 (18.8) .030 (.76) 458-760 .760 (19.3) .040 (1.0) 458-780 .780 (19.8) .050 (1.3) .680 (17.3) 458-800 .800 (20.3) .060 (1.5) 458-820 .820 (20.8) .070 (1.8) 458-840 .840 (21.3) .080 (2.0) 458-860 .860 (21.8) .090 (2.3) 458-880 .880 (22.4) .100 (2.5) 459 SERIES H T PART NO. .900 (22.9) 459-900 459-920 .920 (23.4) 459-940 .940 (23.9) .960 (24.4) 459-960 459-980 .980 (24.9) .880 (22.4) 459-1000 1.000 (25.4) 459-1020 1.020 (25.9) 459-1040 1.040 (26.4) 459-1060 1.060 (26.9) 459-1080 1.080 (27.4) F .010 (.25) .020 (.51) .030 (.76) .040 (1.0) .050 (1.3) .060 (1.5) .070 (1.8) .080 (2.0) .090 (2.3) .100 (2.5) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 M. Chen D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 02/28/03 DATE: 02/28/03 PART NO: FAX: (949) 951-3974 T-1 (3mm) & T-1 3/4 (5mm) MOLDED LED MOUNT REVISION: 45X-XXX CAGE CODE : 32559 F SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
456-490 价格&库存
很抱歉,暂时无法提供与“456-490”相匹配的价格&库存,您可以联系我们找货
  • 100+2.74656
  • 500+2.47825
  • 1000+2.20156
  • 10000+1.92606
  • 100+2.68891100+0.34804
  • 500+2.42700500+0.31414
  • 1000+2.156361000+0.27911
  • 10000+1.8857310000+0.24408
