REV.
B
C
D
0.240 [6.1mm]
DIA
DESCRIPTION
Engineering Update w/o Changes
Removed Part Numbers
Removed Material Code
DATE
APPROVED
02/26/04
05/08/15
05/28/16
M. C.
J. C.
J. C.
0.200 [5.1mm]
0.170 [4.3mm]
0.085 [2.2mm]
0.100 [2.5mm]
0.025 [0.6mm] SQ.
TYP.
L
Cathode I.D. Mark
1 (H-13XC-1-XXX)
2 (H-13XC-2-XXX)
C/L
0.130 [3.3mm]
Holder Faces
0.210 [5.3mm]
Ø.032+.003
-.002
TYP.
0.172 [4.4mm] Holder Pitch
0.100 [2.5mm] LED Lead
H-130C
H-131C
H-132C
H-133C
Recommended Mounting Holes
PART NO.
ID
MARK
DIA
H-133C-1-120
1
.128 [3.3mm]
H-133C-2-120
2
.150 [3.8mm]
H-131C-1-140
H-132C-1-140
H-133C-1-140
1
.128 [3.3mm]
H-131C-2-140
2
.150 [3.8mm]
H-130C-1-160
H-131C-1-160
1
.128 [3.3mm]
H-131C-2-160
2
.150 [3.8mm]
H-130C-1-180
H-131C-1-180
H-132C-1-180
H-133C-1-180
1
.128 [3.3mm]
H-131C-2-180
2
.150 [3.8mm]
H-130C SERIES
H-131C SERIES
H-132C SERIES
H-130C-1-120
H-131C-1-120
H-132C-1-120
H-130C-2-120
H-131C-2-120
H-130C-1-140
H-133C SERIES
C/L
L
.120 [3.0mm]
.250 [6.4mm]
.140 [3.6mm]
.270 [6.9mm]
.160 [4.1mm]
.290 [7.4mm]
.180 [4.6mm]
.310 [7.9mm]
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-0, BLACK.
DESIGNED:
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
± .1
± .01
± .005
M. Chen
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T-1 (3mm) LED HOLDER
INTERLOCKING VARIABLE CENTERLINE
DATE:
01/21/03
DATE:
01/21/03
PART NO:
REVISION:
H-13XC-X-XXX
CAGE CODE : 32559
D
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-131C-2-120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+4.05082100+0.52432
- 500+3.64923500+0.47234
- 1000+3.238911000+0.41923
- 10000+2.8373210000+0.36725
- 国内价格
- 100+4.13720
- 500+3.72636
- 1000+3.30713
- 10000+2.89748
