H-480C
H-480C
    BIVAR
H-480C 数据手册
REV. B C 0.080 [2.0mm] TYP. 0.200 [5.1mm] 0.100 [2.5mm] DATE APPROVED 02/27/04 05/28/16 M. C. J. C. DESCRIPTION Engineering Update w/o Changes Removed Material Code & P/N Correction 0.550 [14.0mm] 0.080 [2.0mm] 0.470 [11.9mm] 0.470 [11.9mm] 0.300 [7.6mm] 0.400 [10.2mm] 0.200 [5.1mm] 0.100 [2.5mm] 0.180 [4.6mm] 0.280 [7.1mm] 0.130 [3.3mm] Holder Faces Ø.032+.003 -.002 TYP. 0.380 [9.7mm] 0.480 [12.2mm] 0.100 [2.5mm] 0.190 [4.8mm] 0.100 [2.5mm] 0.200 [5.1mm] 0.300 [7.6mm] Recommended Mounting Holes 0.100 [2.5mm] STANDARD TOLERANCE DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. ± .1 ± .01 ± .005 DESIGNED: S. Irving 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ® ( UNLESS OTHERWISE SPECIFIED ) CHECKED: D. Green ANGULAR X° ± 1° DATE: 05/28/99 DATE: 02/27/04 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: QUAD-LEVEL 2X3mm LED HOLDER REVISION: PART NO: H-480C CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-480C 价格&库存
很抱歉,暂时无法提供与“H-480C”相匹配的价格&库存,您可以联系我们找货
